Old 10-07-2012, 10:30 AM   #106
therivermonster OP
therivermonster's Avatar
Oddometer: 322
Originally Posted by ebrabaek View Post
Home Depot..... Spray bottle...... Fill with acetone..... A few squishes..... Just like if you are misting flowers..... Done.
Thanks, Earling! I'm all set with the acetone sprayer for the exhaust mold and layup. I'll report back on how it works.
Originally Posted by 100mpg View Post
the clear CF. Any paint design over the CF doesn't look right to me.
400 is a good start. When I painted my little trailer I went up to 2000 (wet, with a touch of soap in it) after every coat of paint and clear. The result with a super smooth finish and that is what you need to make a good plug and mold. Let me brag...I mean show you what I mean.
From this
To this. With spray cans.
I have thought about using this trailer to make a form to create a longer version of this to tow behind my pickup when going camping. I like the wheels tucks under the body.
That little trailer is awesome, 100! Very nice job! It's kind of amazing what quality you can get with rattle can paint.
I hear ya about getting an A1 finish for a plug which brings us to my next post. Read below.
Twin-Shocker, are you with me??
“Behold, I am sending you out as sheep in the midst of wolves, so be wise as serpents and innocent as doves."
My Virgin ADV Trip
, Rocks Flyin', Me Cryin', and God Looking On - A WABDR Adventure, Fun With Carbon Fiber
therivermonster is online now   Reply With Quote
Old 10-07-2012, 10:40 AM   #107
therivermonster OP
Oddometer: 322
Exhaust Shroud Plug Finishing...
I took some time this morning to finish the exhaust shroud plug. I wanted an A1 finish as it's called.
This is a sample of the finish before I started sanding and polishing. Notice the nice orange peel finish.
Next I sanded with 800, 1500, 2000, then buffed with buffing compound, then polish. The results are fantastic.
The overhead lights reflect almost like a mirror.
So we went from a semi rough (nicked, scratched) shroud, to a smoothed, and polished plug.
The idea is that when I paint on the coat of epoxy onto the plug when I begin to make the mold, the very smooth shiney surface of the plug will be transfered to the epoxy surface. That smooth, shiney mold surface will then in turn allow me to creat a CF part that also has a very smooth and shiney surface. The finish work shows through to all parts. We'll see how it goes...
Comming soon... Making the mold from the polished shroud plug. Good times!!!
My Virgin ADV Trip
Old 10-07-2012, 10:53 AM   #108
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Very nice work! I am really enjoying your thread!
I find it simply amazing what I can learn by reading the threads in this forum. Thanks for taking the time to post up as you go.
Keep up the good work!
kirkster70 is offline   Reply With Quote
Old 10-07-2012, 11:00 AM   #109
therivermonster OP
Oddometer: 322
Thanks, Kirkster! I am really enjoying doing this stuff and sharing it with you all. Don't forget to check out all the resources on the first page for WAY mor learning. Ebrabaek's posts are my primary motivation. He has done a lot for the DIY composites scene here on ADV and TT.
If you are thinking about giving this a shot, do it! Don't wait any longer. If it looks hard to you, it's not. I'm serious about this. Like Nike says, Just Do It!
If you have any questions about how to get started, just post them up here on the thread.
My Virgin ADV Trip
Old 10-07-2012, 12:22 PM   #110
100mpg
This sentance intent
100mpg's Avatar
Oddometer: 17,369
thanks!
and POW! You hit a home run. That looks fantastic and will make a great mold. Did you notice how the 2000g paper was smooth then suddenly started to "stick" to the surface? I am only guessing but it seems that the last of the orange peel creates a suction to the sandpaper and it suddenly disappears and become like glass. I knew I was almost done sanding when that happened!
I am looking forward to seeing the finished part.
I
Next I sanded with 800, 1500, 2000, then buffed with buffing compound, then polish. The results are fantastic. The overhead lights reflect almost like a mirror.
Don't drive like my brother!
"I'd rather wake up in the middle of nowhere than in any city on Earth" - Steve McQueen
National Suicide Prevention Lifeline 1-800-273-TALK (8255). DSI #694
100mpg is online now   Reply With Quote
Old 10-07-2012, 12:39 PM   #111
ebrabaek
Oddometer: 4,725
Regarding the acetone spray.... Have a look here.... It about cover many items, as it takes you through a complete cycle....
Erling
Old 10-07-2012, 07:23 PM   #112
therivermonster OP
Oddometer: 322
thanks!
Thanks 100. I want to do a good job on this part. There's a lot left to do, so we'll see how it goes.
I did notice the suction effect with the 2000 grit. It's kind of a funny thing.
Thanks again, earling!
My Virgin ADV Trip
Old 10-07-2012, 07:45 PM   #113
therivermonster OP
Oddometer: 322
Makin' a mold...
I decided to lay up the mold for the exhaust shroud today, but I had a big issue to deal with that I didn't think about before. Holes...
These holes.
So I decided that I would stuff the cavity below the shroud with grocery bags...
And use non drying clay to fill the holes.
Then I waxed the plug with Partall paste wax...
...followed by a couple coats of PVA.
With my workstation all set I got started. I applied the first coat of epoxy...
...and used some of the yarn from the fiberglass cloth to fill the corner between the plywood and the part.
Next I layed up 5 layers of 8.5 OZ 2x2 twill fiberglass fabric over the plug. This is the finished result.
I am really concerned about bubbles. Look at this picture; there's lots of those little guys in there.
Now that I am gaining some experience, I made sure to have an ample supply of Coors Banquet beer with me.
Now we'll let the layup sit for a day or so, then pop it off, trim it up, clean it up, and hopefully lay up a cf part soon.
Thoughts:
Making a quality plug has been a great experience and great practice. I think that the mold will turn out OK, but not great because of bubbles.
I had thought that I would just make molds from epoxy, but the more experience that I get, the more gell coat and chopped strand mat makes sense to me as mold making components.
I think that I'll order up some poly tooling gell coat and some mat for the next mold project.
Anyhow, more to come soon!!
My Virgin ADV Trip
therivermonster screwed with this post 10-07-2012 at 08:00 PM
Old 10-07-2012, 09:30 PM   #114
ebrabaek
Oddometer: 4,725
Thought I'd share this picture. Just today started a new project.....and only used water, and soap to clean the part ( plastic Beak from a F800GS) and then release agent (two layers) then two layers of Max Clr-Hp.... No orange peel, after the two layers of clear coat....... that,s after the beak has seen over 3 years on the road......
Until then....
Erling
Old 10-07-2012, 10:11 PM   #115
therivermonster OP
Oddometer: 322
Until then....
Nice!
What kindo of soap did you use?
Two coats of PVA, right?
How long after application of the resin to the part did you snap this pic?
Did you follow up the resin with glass or carbon?
Is this the 800 beak extension that I have read about? If yes, are you posting a thread?
Also, that resin looks pretty bubble free. How'd you manage that?
Rock on, man!
My Virgin ADV Trip
Old 10-08-2012, 06:35 AM   #116
ebrabaek
Oddometer: 4,725
Nice!
Any household dish washing detergent will do fine.
Right...Two coats.
Couple of hrs.... Did not change from the brush up, and should not.
Nothing yet, as you do not want to disturb The Clear coat.
Yes.
First batch was degassed with the vacuum chamber.... Second layer was set under a heat lamp for 5 minutes with a start temp of 85 deg. F. No degas.... Stubborn bubbles was removed with a spray or two of acetone.
Rock on, man!
Ironically, the first few seconds after acetone spray, it will orange peel, but it auto levels after 30-60 seconds.
Yes... new thread...
http://www.advrider.com/forums/showthread.php?t=678072
Erling
Old 10-08-2012, 07:42 AM   #117
therivermonster OP
Oddometer: 322
Earling, when you degas the resin with vacuum, does it help keep the bubbles out a lot, or are a lot more introduced when you brush the resin on?
Were you in the process of making a mold in the pic you posted?
My Virgin ADV Trip
Old 10-08-2012, 08:15 AM   #118
ebrabaek
Oddometer: 4,725
Yes.......
Just a little, but with care they can be minimized,and acetoned out.
Yes.....
Erling
Old 10-08-2012, 08:25 AM   #119
therivermonster OP
Oddometer: 322
Yes.....
Sweet!!! I can't wait to see more of your process.
I popped the mold this morning and it looks pretty good besides a number of bubbles (now holes) in the surface of the mold. I have some Cabosil on the way, but I may just mix some talc with epoxy to fill the holes, sand, spray with clear coat, sand, polish and then lay up the carbon. Of course I'll post pics of the popped mold and the finishing process...
I need a vacuum pump now...
My Virgin ADV Trip
Old 10-08-2012, 09:26 AM   #120
ebrabaek
Oddometer: 4,725
http://www.ebay.com/itm/Vacuum-Chamb...item20cc241934
Erling
Times are GMT -7.   It's 10:36 AM.
