Old 10-07-2012, 03:58 PM   #1
indr OP
Oddometer: 501
Starter Motor
indr screwed with this post 02-22-2015 at 09:51 PM
indr is offline   Reply With Quote
Old 10-07-2012, 04:01 PM   #2
ragtoplvr
Oddometer: 6,307
To the body of the starter.
I would take off the oring and clamp the jumper cable on the mounting nose. And hold the starter tight, they like to jump off tables, and out of hands, and get destroyed when they hit the floor. You drop one, you crack the magnets
Rod
ragtoplvr is offline   Reply With Quote
Old 10-07-2012, 04:18 PM   #3
ragtoplvr
Oddometer: 6,307
How big a supply. Small bike starters can draw over 100 amps inrush, 30 running free. One for a liter bike can be 200, 300 or more amps inrush, 75 amps running free. Your battery charger is not going to cut it.
Rod
Old 10-07-2012, 04:21 PM   #4
buickid
Lets ride!
Oddometer: 310
Well they do take a fair bit of current to turn, so I'd expect a spark caused by large inrush current. How big is the power supply? It might not have shorted, just overloaded. The case is negative, that lug is positive. Make sure you're clamping only to the outer part of the lug and its not touching the casing.
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 10-07-2012, 08:09 PM   #5
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,613
(edit) After a reread this sounded a bit abrupt but wasn't meant to be....... but I cant find better words at the moment.
You realize the potential of what you are playing with.... right?
Why do you need to do this off the bike anyways? It already has everything you need.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 10-07-2012, 09:25 PM   #6
buickid
Lets ride!
Oddometer: 310
I'm not sure the PSU is enough. Use some jumper cables from a car battery. Inrush current on a starter can be huge and the PSU wires are quite small. Also, note that the PSU's 350W is spread across the 12 and 5V rails. You can't get 350W from the 12V rails alone, maybe 200 or so tops. The label on the unit will tell you what it can do.
Old 10-07-2012, 09:48 PM   #7
buickid
Lets ride!
Oddometer: 310
Great :)
Times are GMT -7.   It's 04:20 AM.
