Old 10-07-2012, 07:48 PM   #69871
poppawheelie
poppawheelie's Avatar
Oddometer: 565
Originally Posted by canoli View Post
Since I tend to ride to far out of the way places that are devoid of fuel stops, I REALLY do need every last drop of gas in my Safari tank. So my question for those of you that have done this mod to the carb, is it REALLY as easy as the video shows? Is there a special "trick" to not breaking off that elbow that the video doesn't show? I don't own a bench vice and because of my lack of mechanical skill, would rather not remove the carb.
Thanks,
Canoli
It didn't work that easy for me. Tube started to kink, so I left it alone. As a test, with the pig tail, I ran the tank dry. Curly Q did not air lock. Ran the tank bone dry, including sloshing fuel from the right side.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Old 10-07-2012, 07:50 PM   #69872
poppawheelie
Oddometer: 565
Originally Posted by procycle View Post
This procedure will work for most other bikes but on the DR650 setting the mixture screw this way will often result in a slight "rich bog" just off idle. If you aren't going to make other changes to avoid the rich bog most riders have good results turning the mixture screw about 1/4 turn leaner than the highest idle.
Wait a minute. Which way is leaner, turning in? Thanks.
Old 10-07-2012, 07:50 PM   #69873
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
My experience as well. I gave up and lived with it the way it is.
Old 10-07-2012, 08:19 PM   #69874
motolab
motolab's Avatar
Oddometer: 2,728
In is indeed leaner.
Regards,
Derek
motolab is online now   Reply With Quote
Old 10-07-2012, 09:50 PM   #69875
Thumper Dan
Oddometer: 325
the other option is to to buy a TM40 pumper carb
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 10-07-2012, 10:35 PM   #69876
acap650
acap650
acap650's Avatar
Oddometer: 711
Thanks,
Canoli
Been there. With carb on bike and heated got about 20 deg. rotation. Tried for more and the tube kinked. Still runs fine 6K miles later. I'd probably leave it be or pull the stock tube and drill/tap for a straight fitting.
acap650 is offline   Reply With Quote
Old 10-08-2012, 12:06 AM   #69877
canoli
human
canoli's Avatar
Oddometer: 1,730
For now I'm just going to leave it alone and before I head out to the middle of nowhere try to run my tank dry.
Thanks guys for the info. You just saved me from screwing up my carb.
Cheers,
Canoli
canoli is offline   Reply With Quote
Old 10-08-2012, 03:20 AM   #69878
pzs
pzs's Avatar
Oddometer: 208
Put a adjustable shifter spanner on pipe and twisted, some force needed but all good.
pzs is offline   Reply With Quote
Old 10-08-2012, 05:09 AM   #69879
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,383
Originally Posted by disconnected View Post
sounds good, I will look this up too. :()) Im 6'2" so I would like a tall seat.
greg
I posted pics of my Tall SeatConcepts seat here:
http://advrider.com/forums/showpost....ostcount=68917
I love it. I'm 6'1" and it helped a lot. I did 1500 miles in 7 days and it was the difference between torture (stock) and not even thinking about discomfort. Most days we rode 250 miles. (the first and last days were very short)
I got the standard vinyl because the gripper mat'l on my KTM pulls at my pants too much when sliding around. A wise decision on a bike that I tend to sit much more while riding.
Do yourself a favor and get a tall one.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket screwed with this post 10-08-2012 at 05:16 AM
Rusty Rocket is offline   Reply With Quote
Old 10-08-2012, 07:42 AM   #69880
Ren20
Finding Touge
Oddometer: 111
Hi guys,
Is a 2001 dr650SE with 7000 miles for $2000 Fair? Seller wouldn't go down in price. It's a clean bone stock example. I think nada value is about $1600 for that year. Been looking for one for a while. But no luck. Not many people selling. And ppl want $4500 + for newer years in North east.
updated info, it does have extra gas tank and skid plate. I think that's about it.
Thanks in advance
Ren20 screwed with this post 10-08-2012 at 09:05 AM
Ren20 is offline   Reply With Quote
Old 10-08-2012, 07:50 AM   #69881
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,196
Originally Posted by Ren20 View Post
Hi guys,
Is a 2001 dr650SE with 7000 miles for $2000 Fair? Seller wouldn't go down in price. It's a clean bone stock example. I think nada value is about $1600 for that year. Been looking for one for a while. But no luck. No many people selling. And ppl want $4500 + for new years in North east.
Doesn't sound bad to me. I've found that DR's tend to hold their value more the older they are, assuming they're in good condition. Not because they're any better, but because the bike hasn't changed in sixteen years. So if it's in real nice condition, I say grab it.
FWIW, I paid $2200 for my '96 DR650 two years ago. But in my case it had a ton of mods on it, all of which I wanted, that would have cost me at least $2000 to buy myself. So I called that a good deal.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 10-08-2012, 11:17 AM   #69882
Thanas
Oddometer: 75
Thanks a lot for the info regarding the rear wheel bearings.
Here's what my original bearings looked like after 28.000 km (12.700 mi)
I guess i was lucky i found out they were crap now, instead of finding out during saterday's off-road ride and getting stranded away from home. To bad i wont be riding this saterday, but instead i will be doing an off-road course the 27th.
I've got new bearings ready. Will update during the week when i get it sorted out.
Another question:
The new bearings will be double-seal versions. Is it still necesary to use the extra seals?
Number 4 and 21.
Regards,
Thanas
Suzuki DR 650 SE 2006
Thanas is offline   Reply With Quote
Old 10-08-2012, 11:35 AM   #69883
procycle
procycle's Avatar
Oddometer: 2,375
IMO the NADA prices are not realistic. I've never seen a clean 96-up DR around here for anywhere near $1600.
$2K for a clean 2001? I'd buy it in a heartbeat.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-08-2012, 03:39 PM   #69884
BergDonk
BergDonk's Avatar
Oddometer: 3,711
Originally Posted by Thanas View Post
Another question:
Regards,
Thanas
Can't hurt, unless you want to cutback on some friction.
I always use double sealed bearings, and then pack grease betwen them and the outer separate seal. Means that anything that gets past the seal, still has more work to do to get to the bearing.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 10-08-2012, 03:41 PM   #69885
barko1
barko1
barko1's Avatar
Oddometer: 3,380
Regards,
Thanas
I think that is 17,400 miles
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Times are GMT -7.   It's 09:59 PM.
