Old 10-06-2012, 06:06 PM   #5926
benno.h
cageracer
Oddometer: 437
Originally Posted by lookfar View Post
Does the stock speedo unit still work? I am after one for my resto.
The one that I have is buggered.
Not sure mate - it stopped working last year when I was up your way ;-)
I think it was probably the cable. I have gutted the old one to remove the light bulb holders and warning lights but I'm happy to send you the left over bits if you want.
Originally Posted by GodSilla View Post
I'll step out on a limb here and state that bikes without kick starters are just plain gay, for pansies, ladyboys, and suchlike. Furthermore, they should have to ride at the back, not speak until spoken too, and set everyone else's tents up, then cook and wash up afterwards, before sitting up all night guarding the real men's bikes.
benno.h is offline   Reply With Quote
Old 10-06-2012, 06:12 PM   #5927
Dino3310
Oddometer: 673
Originally Posted by Mike the Yank View Post
New problem, just started to act up. I don't have a temp gauge but it could be only when it gets hotter as it doesn't seem to do it when it is cold.
has it still got the original stock choke plate?
Dino3310 is offline   Reply With Quote
Old 10-06-2012, 06:29 PM   #5928
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,411
Originally Posted by Royal Club View Post
watch out with milling down stems..
Heeded. Happen to know what the sitchvis with that stem? I have a few thou pretty hard miles on mine.....
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 10-06-2012, 06:34 PM   #5929
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,558
FUG! That could leave a mark!!
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 10-07-2012, 01:11 AM   #5930
benno.h
cageracer
Oddometer: 437
FINALLY got the bloody dash finished off, bolted up the few remaining parts and went for my first ride in about 12 months! I can't believe it's been that long! Unfortunately it was only a quick ride on tarmac but fun nonetheless.
Unfortunately I'll be away for most of the next month or so, but hopefully sometime after that I'll get out for a decent ride.
Old 10-07-2012, 04:21 AM   #5931
Royal Club
Royal Club's Avatar
Oddometer: 392
he used a KTM stem and milled it down to fit the fork in the cr250. Went to Germany for a supermotoweekend (training, erzgebirg), after a few table jumps it broke..
I'm not saying it cant be done but you should know what you are doing. moreso with aluminium stems.
Royal Club is offline   Reply With Quote
Old 10-07-2012, 02:07 PM   #5932
Mike the Yank
Oddometer: 424
not positive but I assume so.
I did think of one thing, I put the baffle back in the muffler, would that screw with the mid-range?
Mike the Yank is offline   Reply With Quote
Old 10-07-2012, 09:49 PM   #5933
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Putting the baffle back could make it run richer.
I had a similar issue. Start up and off idle, fine.
WOT, fine. Would blubber and stumble at certain points mid throttle. Chased it around with main jets with little change. Dropped the needle 1 or 2 notches (can't remember) and it cleaned up.
Might be worth a try.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 10-07-2012, 10:33 PM   #5934
Mike the Yank
Oddometer: 424
Thumb
Thanks, I can do that. I completely forgot about the baffle.
Sounds like the same thing, starting better than ever, take off is good, full throttle good, just when cruising along in the lower gears.
It's a lot easier to apologise than to ask permission
Old 10-07-2012, 11:21 PM   #5935
lookfar
from the land of OZ
Oddometer: 634
PM Sent.
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 10-08-2012, 07:12 AM   #5936
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
And....Like Dino mentioned, check/replace that choke plate once you have it opened up.
1991 Honda XR628R
1978 Yamaha XT500
Old 10-08-2012, 12:18 PM   #5937
kubiak
Oddometer: 4,829
i dug up a old pick of my 89 xr600 with rear disc conversion,usd forks,aloop tank,sm wheels and dual stock mufflers.
Old 10-08-2012, 02:13 PM   #5938
elsalvadorklr
southern xr rider
Oddometer: 4,154
alright dudes!
finally got my stator, geeze
so I got the rikcy installed and followed their instructions
I got a green to to the frame...
yellow white to harness and red black to the harness/cdi
however in doing this, it leaves me with a disconnected regulator? whats missiing here?
regulator has green and white yellow...however I dont see how to connect these together
Am I supposed to have one green from the regulator go to the frame as well as the green from the ricky?
please help, as Im about to start this again
well at least I can see if I can get it to start with just the red and black and ground...
Ill keep you guys posted
thanks
SHE LIIIIIIIIIIIIIIIIIIIIIIIIIIVEEEEEEEEEEEEEEEEEEEEEE EEEEEEEEES BIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIITCHEEEEEEEEEEEEEEE EEEEEEEEEEEEEEEEEEEES!
IM BACK!
now who can set me straight on the wiring for the regulator? so I can have some lights?
thanks
elsalvadorklr screwed with this post 10-08-2012 at 02:24 PM
elsalvadorklr is offline   Reply With Quote
Old 10-08-2012, 02:31 PM   #5939
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Tape a flashlight to the bars and go ride! Congrats.
1991 Honda XR628R
1978 Yamaha XT500
Old 10-08-2012, 02:47 PM   #5940
mcma111
mcma111's Avatar
Oddometer: 12,403
Originally Posted by elsalvadorklr View Post
alright dudes!
thanks
IM BACK!
thanks
It's about freeking time.
I think you have a spare leg that you don't use.
Here ya go: http://www.rickystator.com/04technic...ll_inst01.html
Looks like both greens join together to ground. Bottom right diagram.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 11:20 PM.
