10-06-2012, 06:27 AM
#16441 |
Oddometer: 1,291
I've had one for a year and a half. Absolutely no complaints. Single track to interstate highway, it's been flawless. Seat Concepts is good, but SDG works for me.
10-06-2012, 07:22 AM
#16442 |
patty cake champion
Oddometer: 3,393
Thats how the factory tube/grip is. Just buy a new tube.
Unregistered destructive device. |
10-06-2012, 09:23 PM
#16443 |
Quaere verum - Seek truth
Oddometer: 238
OEM speedo unit - reading 0 mph
Quick question for the pros ...
On a ride a few weeks back, the stock speedo/odo unit went partially n/s. All lights and indicators work, but the speedo reads 0, and the odo count stays fixed. I checked - cable and hub unit all seem ok - but I'm thinking cable itself must be damaged? There was no hits or falls on it ... other than that? Thanks, CM
"He is no fool who gives what he cannot keep, to gain that which he cannot lose." - Jim Elliot |
10-07-2012, 06:39 AM
#16444 |
patty cake champion
Oddometer: 3,393
Most likely a broken cable, ive been through 2 in 2 years. They usually break at the hub.
10-07-2012, 09:41 AM
#16445 |
gnardogshredripper
Oddometer: 83
Speedo Hub Dealio
Try repacking the speedo hub assembly with new grease. This summer I took my front wheel off at a buddy's and when I reinstalled it I used the grease he had laying around. His grease wasn't waterproof and for whatever reason the speedo assembly just quit reading mph and all that after a week or two. Eventually I took the wheel off again and it got repacked with BelRay waterproof grease and worked again just like it always had.
10-07-2012, 04:10 PM
#16446 |
Oddometer: 914
Just finished to fix my new decal kit from Uni Racing, the bike looks new!!
I'm also very pleased with the None exhaust. ![]() ![]() ![]()
10-08-2012, 07:31 AM
#16447 |
C3
Oddometer: 104
Would soot build up around the exhaust valves be a sign of the valves starting to excessively wear? I adjusted the valves 15K + miles ago. I set the exhaust valves as close to 30 as possible but they are now reading 25 and 23...the bikes got around 30k miles
I'll adjust the valves now and check them after a few rides, Just wondering if the soot build up is common? ![]() Uploaded with ImageShack.us |
10-08-2012, 08:28 AM
#16448 |
Cavalera Conspirator
Oddometer: 956
Once the valves start tightening up on the OEM valves I would change them to Stainless Wiseco One Piece Valves. The Wisecos hold the settings very well and have been documented to hold adjustments for over 20k miles with no shimming required.
10-08-2012, 08:36 AM
#16449 | |
Oddometer: 1,690
Soot or varnishing? I see the latter which is normal around engine hotspots.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
#16450 |
Oddometer: 214
only when you are running too rich and riding too slow. needs an Italian tuneup every week to keep them clean. try freeway on ramps at full bore.
"Good judgment comes from experience and experience comes from bad judgment." |
10-08-2012, 08:44 AM
#16451 | |
Kitsune
Oddometer: 192
That side up. ![]() '02 FZ1, '02 DRZ400S, '09 TE250 |
10-08-2012, 09:09 AM
#16452 |
Scone Rider
Oddometer: 6,699
One of the local inmates entered his DRZ into the Denver Endurocross this weekend.
While Taddy cleaned up on his Christini 2WD KTM, I can't help but wonder how much better he might have done on a DRZ. We'll probably never find out.
We don't stop riding because we get old, we get old because we stop riding. HellSickle screwed with this post 10-08-2012 at 01:47 PM |
10-08-2012, 10:44 AM
#16453 |
C3
Oddometer: 104
I dont think the soot has anything to do with too much slow riding. I put on 12k in the month of July when i rode the TAT and have been riding hard since. Speedo gear stripped on me at the end of July but i have been ridding hard since
![]() I'm probably running rich, as i've been struggling to get the right jetting since i did the 3x3mod... Anyway, the hole reason I opened her up was to figure out why i've been hearing more engine noise. After watching some Youtube videos I thought I had a loose counter balance nut, but i've already checked that and it's still tight. Next of possibilitys was a stretched cam chain, I am still using the stock 2000 tensioner. After inspecting the cam chain it seemed tight and judging by the soot or whatever crap is all over everything the tensioner wasn't even fully extended. ![]() I've also been getting a bunch of crap in the oil filter. Metal shavings, something red and some black stuff. for scale ![]() ![]() ![]() Any ideas whats going on with my DRZ? how do i check the cam chain guides for excessive wear? My plan as of now is to replace the cam chain and the tensioner with a updated ACCT |
10-08-2012, 11:40 AM
#16454 |
Meanderthal
Oddometer: 1,391
Sharp looking bike there jaumev! I like that rear tire too, what is it?
Tom - '07 DR-Z400S, '05 DL650 Dual Sport Luggage Racks: DRZ400, DR650, KLR650: http://www.moto-racks.com "I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott |
10-08-2012, 11:55 AM
#16455 | |
Meanderthal
Oddometer: 1,391
