10-05-2012, 05:13 AM
#571 |
I'm Barry F'n Gibb!!
Oddometer: 4,595
what they say about power corrupting is true. I've been using my k1200rs and futura to commute lately, since it's 27 miles each way. Today, my last day here, I set a new personal best, covering those 27 miles in 20 minutes flat. luckily i'm taking a job with only a 6 mile city commute, otherwise i'd probably injure myself on the k bike
10-05-2012, 05:32 AM
#572 |
Oddometer: 457
I saw wet weight listed at 521 lbs, but it's still good...gotta be without bags though! It's actually not as ugly to me now as it was in '05!
Twinz, Montpelier, VT 04 aprilia Futura, Ash Black 94 R1100RS...Sadly sold 73 Guzzi V7 Sport...Sadly sold 80 Guzzi V50 II...when all else fails |
10-05-2012, 06:24 AM
#573 |
Oddometer: 942
I always see people saying that on the internet. But I don't agree. Wet weight is useful to know if a rider is considering buying a new/used bike or about to maybe take a test ride.
But dry weight is actually more of an apples-to-apples comparison of how weight-efficient the bike was actually engineered since it's not distorted by different sized fuel tanks. |
10-05-2012, 06:51 AM
#574 | |
Oddometer: 4,595
10-05-2012, 07:13 AM
#575 | |
Oddometer: 942
You're right that the wet weight is useful to know, but it's not a good way of measuring lots of different bikes against one another. |
10-05-2012, 07:40 AM
#576 |
Oddometer: 500
The best weight is ready to ride MINUS fuel.
2007 FJR1300 2003 Aprilia RST1000 2005 KTM 950 Adventure Black 2005 KTM 525MXC 2006 KTM 200 XC-W |
10-05-2012, 08:52 AM
#577 | |
Oddometer: 808
the only numbers worth anything aren't even given by mfg's, they're found by independent sources rolling the bike onto a scale. It's just as fair to weigh bikes full of fuel and expect people to be able to calculate the weight difference due to fuel capacity, as it is to weigh the bikes empty of fuel and expect people to calculate the weight difference due to fuel capacity. what doesn't make sense is to use the dry weight figures, which are unverifiable unless you want to fully disassemble a bike and clean it of all contamination and weigh all the parts, unless you do this all you're getting is a mfg claim which is pretty much always subject to a good degree of fudging. I personally wouldn't mind if people started measuring CG location and MOI about various axes, and then for giggles measured the MOI's again at various engine and wheel RPMs. a guy can dream
10-06-2012, 03:49 PM
#578 |
Oddometer: 223
Don't really see many sport tourers around here either. If I dismiss all the H-D's and sport bikes, there are few of anything to spot. Dual sports, BMW has that one covered around here. Saw a GS650 just today at Tractor Supply. I'm aware of four C14 riders locally.
- marc |
10-08-2012, 12:29 PM
#579 | |
Oddometer: 223
So to use weights in determining a bike purchase, shouldn't the buyer also straddle the bike considered? ![]() My Goldwing didn't feel heavy as long as I didn't tilt it more than a few degrees but, my C14 at a few hundred pound lighter feels just as heavy. If either were to get past a point of no return, I'm jumping out of the way. Want to experience heavy? Get on a BossHoss.
- marc |
10-08-2012, 01:44 PM
#580 |
Oddometer: 238
I think I get what you are trying to say here and I agree to some degree however I think that the size of the fuel tank and its subsequent weight with fuel should be considered overall when looking at weight since we don't ride without gas in the tank. The manufactures plan and take this into consideration when designing the bike so why shouldn't it be considered. I am sure more then one manufacturer has made a tank smaller just to save weight weight and handling characteristics. Who cares if one bike is 10 pounds heavier then another if it handles better so I agree that the design and center of mass etc...are just as critical. Dry weights are just something the manufacturer puts out to appease us the buyers so we can quote the statistics for our buddies. I understand you are driving at the materials used in the manufacturing process therefore it is a more apples to apples comparison but that really only applies if you are going to set them up for display. The actual rideable weight and pushing it around in the garage is more important............
2008 Yamaha FJR1300 "If you Can't Fix it with a Hammer, it must be an Electrical Problem......" |
10-08-2012, 04:40 PM
#581 | |
Oddometer: 808
2 bikes with the same mass and CG location can still be differentiated by different moments of inertia about various axes, and the spinning crank can change the moment about the two axes around which it doesn't spin and this influence changes with RPM, as does the influence of the spinning wheels and theblahblahblahblahblah. Sitting on doesn't give the same info as riding, and riding in one set of conditions doesn't give the same info as riding in another, and you get used to some things and not to others, and pretty soon the only way to really get to know a bike is to buy it and really get to know it.
10-08-2012, 11:22 PM
#582 |
Oddometer: 238
You know the best part of this wet weight debate is that only 20 years ago everything just about was heavier then what we can buy now. Only a very few riders can even tap into 50% of a motorcycles ability.......we truly live in good times when it comes to motorcycle selection........
10-09-2012, 05:43 AM
#583 | |
Oddometer: 35
10-09-2012, 06:08 AM
#584 | ||
Oddometer: 632
Ride'in on the street, mor weight is better; to a point. I never thought I'd own a 600 lb bike, 'til I dun got me this 660 lb. FJR and am luv'in it. (Just like a big girl, thar's mor ta luv! )It's so versatile, solid, stable, and planted at sane street speeds. Quote:
![]() Just pick a fucking bike 'n ride the thang already.
2007 FJR1300 2007 FZ6 (Dirt bike) |
