Old 10-08-2012, 04:13 PM   #30946
sequent
South Australia's own....
sequent's Avatar
Oddometer: 481
Originally Posted by pfy50 View Post
Dave/Sequent;
Congratulations on your class win!
What tires did you run and what pressure in lbs/sq in. I'm having similar problems with sand. Would you have changed to a different tire make if you knew ahead of time?
Ha, I shouldn't get too cocky about the class win, I was the only one dumb enough to enter a 250cc bike, so all I really had to do was finish. Did beat a few Berg 570s though, so that was good..!!!
I ran Michelin AC10s front and rear, with a Michelin Enduro front mousse and a Michelin Desert mousse rear. I cut both the mousse(s?) down to lower the simulated pressure, and to fit the rear desert mousse (which is a 140/80) into the AC10 rear (which was a 110/100). Seemed to work well, and there were many stages of the rally that I was glad I wasn't running tubes. I would run the same tyres again, no worries. The one set of tyres got me through the whole event (although the rear was buggered by the end of the rally, and could have done with a change halfway through). That's 3,500km (around 2,000 miles) of hard sand and rock racing over seven days, so not too bad.
Originally Posted by AZ TOM View Post
sequent what suspension mods did you have?
I took the bike to Hoey Racing Services, near my place in Adelaide, Australia, and he resprung and revalved it to suit the weight of me (100kg with gear) and all the bits and pieces on the bike. It was seriously the best modification I did. I wound the rebound off the shock slightly and that was the only suspension change I made for the whole event, it was great.
As for other mods to the bike, here's the list:
- 28mm dia handlebars plus a Scotts steering damper set-up
- Barkbuster Storm handguards
- A full FMF header/exhaust with the FMF fuel programmer
- Removed the EXUP and AIS/ICS systems
- B&B bashplate, master cylinder, tail tidy and rear disc guard
- Force radiator guard
- Flatland front disc guard
- Pivot Pegz
- Sandman case caver and countershaft sprocket cover
- RAD Manufacturing front and rear hubs with Excel rims and stainless heavy duty spokes
- Chaingang sprockets (49 rear and a 13 front. I have ordered a 46 rear, which would make a better compromise I reckon)
- HEL braided front and rear brake lines
- Twinair air filters
- Hammerhead +20mm WR250F gearshift lever
- Seat Concepts low seat
- 14 litre Safari tank.
- A high-impact "Screens For Bikes" screen kit
- Acerbis folding mirrors
- Brake snake
- Nomad 4 litre rear tank
- Ariete foam rally grips
- Shorei lithium battery (saves 1.5kg over the stock Yuasa battery!)
- Replaced the stock sidestand with a WR250F alloy sidestand (just need to cut the lug off the WR250F sidestand and use a WR250F spring - saves around 500g).
- Home-fabricated brackets to increase the gap between the screen and the instruments so the front brake line wouldn't snag
- All the usual rally navigation gear (F2R roadbook plus Touratech IMO and Trailtech Vector tripmeters mounted to a Rally Management Services nav gear bracket plus associated hand controls)
In life, if you don't risk anything, you risk everything...
sequent is offline   Reply With Quote
Old 10-08-2012, 11:18 PM   #30947
Llamaha
Oddometer: 853
- Pivot Pegz
- Brake snake
Which nomad tank did you use, also was it easy to install?
Llamaha is offline   Reply With Quote
Old 10-08-2012, 11:38 PM   #30948
sequent
sequent's Avatar
Oddometer: 481
I ran just the standard No.1 tank from Nomad (see http://nomadtanks.com.au/Tanks.php). It fits nicely on the rear guard right behind the seat. The tanks comes with the option to bolt it to the guard, but I chose to just use the supplied 15" rubber tie-down straps, looping onto the subframe just below the seat and attaching to the B&B numberplate mount holes at the rear so I could remove it for the shorter stages and just run it when I thought I might need it (basically any stage that was over 200km between refuels). The tank comes with a foam pad which increases the gap between the tank and the exhaust, but this worked its way out and is lost somewhere in the Western Australian outback, but there was never an issue with the tank and the exhaust even with no foam. At the next service point I glued some high density foam to the rear guard instead and this worked very well and lasted the distance - the tank didn't move an inch during the whole event. I didn't plumb the tank into the main tank, so I had to stop and transfer fuel, but in the context of the whole rally, losing three minutes on two stages wasn't a big deal, and saved any potential problems with the fuel pump pulling air when the rear tank emptied etc etc. Could probably plumb it into the main system with a little thought, but as I said, I didn't bother.
Old 10-08-2012, 11:57 PM   #30949
Gany
Oddometer: 366
Awesome Dave and thanks for all the info. Looking into the pivot levers now. Any more pics of the bike and some in action?
Gany is offline   Reply With Quote
Old 10-09-2012, 01:14 AM   #30950
sequent
sequent's Avatar
Oddometer: 481
A few more photos courtesy of Ross (ADV name Sylvia) at rbimage.net, who tirelessly followed the event, snapping away.
sequent screwed with this post 10-09-2012 at 04:15 AM
Old 10-09-2012, 04:06 AM   #30951
Joe Watson
Joe Watson's Avatar
Oddometer: 1,033
Good on ya mate!!! Bloody brilliant effort! I have just got back from Cape York on my WRR and was so keen to see how you went. Congrats on the finish, one day, I hope to have one of those finishers medals in my hand!!
Joe Watson is offline   Reply With Quote
Old 10-09-2012, 05:10 AM   #30952
coresports
coresports
coresports's Avatar
Oddometer: 327
Originally Posted by Gfacter View Post
115? I don't think so.
Might just need new tires or even just more air in them?
fyi, mine was set to kmh and not mph from the factory, i drove around the first day amazed at how fast & far i was going until i noticed.
a quick google calc shows:
115 km per hour
= 71.5 mph guessing that how fast the po was really going
i had to look in the manual to figure out how to change it:
press the SELECT 2” button until the display changes after the main switch is turned to “ON”.
coresports is offline   Reply With Quote
Old 10-09-2012, 06:34 AM   #30953
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 589
Originally Posted by sodapop View Post
Hi,
The bike ran OK, but we did a trail section and coming down a hill with the clutch in, the engine just died. I was able to restart it with the starter before climbing back up the other side and it seemed to run fine the rest of the ride. I put about 200 miles on the bike yesterday including some long WOT highway sections with no other issues.
Thanks.
sodapop,
Just addressing the engine dying problem. Do you use predominately ethanol laced gas? I had this problem with my KTM. The dealer mechanic told me that the alcohol causes a film to build up inside the injectors and at low speed and at idle the injectors get starved of fuel enough that it causes your bike to just die. At higher speeds your injector(s) are still getting enough fuel to keep the bike going, but eventually the film will just starve the engine enough so that you will not be able keep it going(this is where I noticed the problem). I do not know why this doesn't happen to all bikes or with certain bikes (BMW's seem to be prone to it) more than others. May be type of driving and where you get your fuel that has some determining factor (or injector design). After I got the injectors flushed out with a high pressure solvent it seemed to take care of the problem(something to keep watch on). I did 26,000 miles in a 5 month trip on the new KTM with no apparent problem. The problem didn't show up until I had near 40,000. May be something to look into.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 10-09-2012, 06:53 AM   #30954
NL-Patrick
NL-Patrick's Avatar
Oddometer: 60
Pimp my ride has begun ........
Handlebar risers 3cm
Handlebar crash pad from Renthal
TV set
Gr Patrick
NL-Patrick is offline   Reply With Quote
Old 10-09-2012, 07:25 AM   #30955
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,273
Another CORE Primm/Bar 10 trip in the books.......the WR250R performed flawlessly.......
Just started a trip report thread here: http://advrider.com/forums/showthrea...5#post19779615
Teasers:
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 10-09-2012, 01:13 PM   #30956
Lima Tango
Lima Tango's Avatar
Oddometer: 66
Question about IMS tank vent
Please excuse my cluelesness, but I was wondering...
The 3.1 IMS fuel tank for the wrr has a vent tube sticking out of the cap. What is this for? Why doesn't the stock tank have this? My wrr is a California model if it matters.
thanks!
Lima Tango is offline   Reply With Quote
Old 10-09-2012, 01:49 PM   #30957
jckid
Oddometer: 325
Want to add power outlet
I want to add a power outlet so I can run a heated vest during the winter. Is there a kit available that comes with everything I would need? And is there a write-up anywhere with step by step instructions on how to do the install? I've found lots of info on how people accomplish this, but nothing that has complete instructions on how to do it. My hubby and I have completely wired two bikes with Baja Designs dual-sport kits, and it was easy, but that was because we had step by step instructions. We've also wired accessories on my Jeep, but again, with instructions.
Current: WR250X (ADV 19"/17" wheel conversion), CT110
Previous: SM610, KLX351
WR250X ride report: http://advrider.com/forums/showthread.php?t=903806
jckid is offline   Reply With Quote
Old 10-09-2012, 01:51 PM   #30958
jckid
Oddometer: 325
thanks!
CA models vent through the smog equipment--charcoal can. My KLX is the same way. When I put an IMS tank on it, I removed the smog equipment, so now it vents through the gas cap that came with the IMS tank.
Old 10-09-2012, 02:23 PM   #30959
what broke now
Petroleum Brother
Oddometer: 1,482
If you use a battery tender, you can use the same pigtail on the bike to power the vest while riding. Just make up an sae to gerbing [or other] adapter, assuming you know how to solder and use shrink tubing.
I am sure there are kits to get as fancy as you want, also.
what broke now is offline   Reply With Quote
Old 10-09-2012, 03:07 PM   #30960
jon_l
jon_l's Avatar
Oddometer: 3,454
Some good info here:
http://www.basherdesigns.com/2010/01/29/3cs-part-1/
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Times are GMT -7.   It's 01:50 AM.
