10-09-2012, 04:41 AM
#5491 |
Oddometer: 568
I think some of the problem with existing routes is waypoint related...I've got dozens of routes that go back several versions of City Navigator..I always reload them in the latest CN and regenerate the route before loading on my Montana, but I've had several routes that give me the " maps don't match the route" message and a subsequent refusal to recalc. I'm too lazy to look at the GPX file and see if there is any version related info hooked to the waypoints that won't update unless you regenerate the waypoints in the same version of CN (on the GPS) that you have in Mapsoure or Base camp...
10-09-2012, 07:42 AM
#5492 | |
Long Haul Adventurer
Oddometer: 3,182
If GPSBabel finds an error it will show you where the error is. At that point if you are comfortable at editing GPX data, then open the file in your XML editor and fix the bad syntax or data. Here is where you will have to understand what valid data looks like in a GPX file as well as the different GPX XSLT's that Garmin has used over the years for their Extensions. In the past some of the early Garmin GPX syntax's were not read by BaseCamp: i.e, cause an error. I don't know if they fixed all of that. Cheers,
Cheers, Dan DRTBYK screwed with this post 10-09-2012 at 07:56 AM |
10-09-2012, 08:03 AM
#5493 | ||
Oddometer: 3,182
Cheers,
Cheers, Dan DRTBYK screwed with this post 10-09-2012 at 08:29 AM |
10-09-2012, 09:13 AM
#5494 |
Pretty Dogged
Oddometer: 442
It is good to have a sense of humour when dealing with gps issues
2007 BMW Dakar & 2009 Ducati Multistrada entering the middle of the in-land sea called Saskatchewan Canada http://s737.photobucket.com/home/OceanMtnSea |
10-09-2012, 10:13 AM
#5495 |
STILL Jim Williams
Oddometer: 5,957
My Montana is hooked into switched power on my bike. I noticed the other day that it only had 1/2 battery charged even though it showed the lightning bolt. When I turn key off it always asks me if I want to run it off battery or let it shut down. It seems to be acting "normal".
I leave the Montana in the cradle and key in ignition in my garage. Today it was completely dead. Of course, when turning the key it fired up like normal. Does this use up battery even when shut down? It's not a huge problem, just a minor annoyance. I used the same switched source on my zumo with none of these shenanigans. Is this another Montana quirk? |
10-09-2012, 10:24 AM
#5496 |
Deputy Cultural Attaché
Mine does not, but I never leave it in an unpowered cradle.
Successfully surviving motorcycling since 1976. |
10-09-2012, 11:58 AM
#5497 |
STILL Jim Williams
Oddometer: 5,957
I guess that's the confusing part to me. There is no power going to it while the key is off. It seems odd that the battery would drain while sitting in the cradle with no power going to it. I don't have the problem if I take it off.
#5498 | |
Oddometer: 3,182
The unit does not use much power when truly Powered Off. If the Montana is in the Mount and the Mount is hot all of the time the unit will continually charge the battery (very small amount of current) even when the Montana is Powered Off. Just saw your post above...I'd say you have a connectivity issue with your switched power to the Mount. I would recommend removing your Montana from the Mount when you are not using it. Cheers,
Cheers, Dan |
10-09-2012, 12:03 PM
#5499 |
OX Ambassador
Oddometer: 430
Sounds like you have a complete circuit somewhere, even with the key off.
10-09-2012, 01:27 PM
#5500 | |
Back Home
Oddometer: 1,545
I'm guessing there is something in the mount that is drawing power.
10-09-2012, 01:40 PM
#5501 | |
STILL Jim Williams
Oddometer: 5,957
10-09-2012, 02:06 PM
#5502 | |
Procrastinators
Oddometer: 5,819
This would tell us if it's the mount, or the connection to the bike's electrical system which is the problem. I don't leave my Montana in the garage, though, normally.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
10-09-2012, 02:14 PM
#5503 | |
Back Home
Oddometer: 1,545
10-09-2012, 02:17 PM
#5504 |
Web Adventurer
Oddometer: 561
I don't think the Montana is ever truly "off".
IBA #33260 |
10-09-2012, 02:19 PM
#5505 |
Back Home
Oddometer: 1,545
Maybe, but why can it sit on my desk for weeks without draining it's battery but only a few days on an unpowered mount?
