10-09-2012, 01:27 PM
#13321 | |
Retrophilic Rambler
Oddometer: 1,050
Sandlapper Braaaappper - Savannah River Rambling - SC Dirt! - On a perpetual dirty road tour in the land of Hicks and Nothing... |
10-09-2012, 03:15 PM
#13322 | |
almost gnarly
Oddometer: 1,479
T-Vent Mod is cheap and easy - suggest you do that and go for another ride. Let us know how you make out.
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
10-09-2012, 03:29 PM
#13323 |
almost gnarly
Oddometer: 1,479
Just a little note regarding all the clutch / finding neutral issues.
On my '99 DR350 clutch cable adjustment is critical. And, it has to be adjusted when the bike is warm/hot. If my cable gets a little loose I start getting a little clutch drag, and any little drag makes finding neutral difficult, if not impossible. I keep the cable adjusted so that it seems pretty tight when cold and have no problems at all finding neutral or shifting thru the gears - like buttah as previous poster said.
10-09-2012, 08:09 PM
#13324 | |
Oddometer: 192
Yep. the "T" vent should solve your starting issues.
Some part of our beings longs to join a band of brothers on a daring and intrepid quest. ~Carl Sagan |
10-09-2012, 08:19 PM
#13325 |
Oddometer: 192
Decal
Just installed an acerbis tank and it looks pretty plain compared to the stock tank. Anyone know where to get decals?
10-09-2012, 09:17 PM
#13326 |
wandering the desert
Oddometer: 679
I figure I would give you guys first dibs on this if anyone wants it, if not its going into the for sale section or ebay.
$30 + shipping takes it. Light works, fairing is in great shape, decal still looks new, rubber straps are still stretchy ![]()
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
10-09-2012, 09:24 PM
#13327 |
Oddometer: 479
Clutches and other Ramblings
I see that Kientech sells a longer clutch arm to make the pull easier. Except mine is really easy to pull and I'm not exactly a strong guy, so I don't know why you'd need it easier at the expense of loosing stroke length. Looks like that would make the problem worse. I thought about cutting the arm shorter, but you shouldn't have to do that. From what I've read, people who replace the clutch discs with new ones (maybe oem ??) report no more problems. If Suzuki got the expansion and friction properties wrong, then the question remains, why Suzuki didn't get it right on this one. Don't guess we can answer to that one. It's not like Motorcycle manufactures have any respect for intellectual property. If they do one thing well, it's copy stuff and smooth clutches and shifting has been available to copy for a long time. But then they can't seem to get gearing on a lot of models right either. Really all we need is a Trials bike low gear and a Road Racer top gear and just space out the rest of em. Well, maybe it's not that easy, but just sayin, by now you'd think they'd be better at it. Maybe it's an international thing. Maybe if they gear one for Japan and Europe, it's not right for US. But then how do you explain the DR650 ...too big for Japan? Still, it could have had a sixth gear. I think they use to make 50cc 12speed race bikes in Europe(maybe still do), so a six speed (KLR/DRZ/DR650/etc) shouldn't be a stretch. I know our DRs (and there clutches) are old and an extra gear on those other bikes would cost more $$$, but who here wouldn't be willing to pay a "little" more.
And no, I don't really want a KTM.....Yet.
2bold2getold screwed with this post 10-10-2012 at 07:05 AM |
10-10-2012, 05:25 AM
#13328 |
almost gnarly
Oddometer: 1,479
Based on the popularity and reliability of the DR350 & DR650 I'd say Suzuki got it right. You can't please everyone, but they've sure made a lot of people happy for a long time.
10-10-2012, 06:03 AM
#13329 | |
Oddometer: 201
___________________ 1999 DR350X 1982 GS750T |
10-10-2012, 09:44 AM
#13330 |
Oddometer: 54
The disks in my clutch, along with the pressure plate, spacer and thrust washers are new - put in maybe 100 miles ago by the PO. I don't know whose disks they are, so maybe they aren't OEM. After snapping off the shift drum bolt, the bike suffered a small setback in its riding season so I know I don't need to rush this. I armed myself with some left-turning bits, EZ outs, rags and magnets to catch chips in preparation for surgery and contacted Jesse at Kientech, looking into the larger diameter shift drum bolt in expectation that I could use it if I bunged up the threads in the drum in the course of repair.
Turns out, the rumors are true. He's as helpful as people say, and his estimate for the work on the drum (new 8mm hardened bolt and re-bore on the "gearshaft cam stopper plate") and on the crank (to fix the possibility of counterbalancer/crankshaft violent interaction) was less than I'd spend on parts to do it myself (maybe not if I include what I buy to reassemble the engine, but I file those under tuition costs). I'll be pulling the drum and crank and shipping them off, cleaning up everything in the clutch I can and taking the time to go through the bike head to toe. I need to go back through the thread to see if there's a write-up of breaking down the engine to get those parts and reassembling it. I'll be taking pictures anyway, so there may be one soon in any case. That's mostly for myself to keep things straight, as I'm not a writer, but I'm pretty sure I'd be posting anyway with more questions as the surgery gets underway as this is new to me. Here's hoping I've already seen the only broken bolt of this whole adventure. - Spad
___________ 06 Wee Strom 82 CM450E 99 DR350SE |
10-10-2012, 02:17 PM
#13331 | |
Oddometer: 479
Thanks DisTech. If it was mine, I'd be trying to drill and tap that hole, or get some help if you need to. |
10-10-2012, 02:35 PM
#13332 |
Oddometer: 479
Oooh, I agree. Love the DR350, but they did quit making it ???? and the DRZ needs another gear (which is probably why most of us got the DR350)....the Dr650 is probably the best of the bunch if you don't get one of the older ones ('06 & older I think) with the exploding third gear. Sorry, I'm just old and cranky and lament the demise of the old, simple, XRs & XRL 250s and 400s and the like. Can't seem to warm up to the Versys, Vstrom types, etc.
2bold2getold screwed with this post 10-10-2012 at 08:27 PM |
10-10-2012, 03:02 PM
#13333 |
Dodgin' the Ditches
Oddometer: 1,156
I have a buddy who wants to start riding and is on a very tight budget. He's a total beginner, so I'm going to get him started on a little CFR150F beater. Then I have an XT225, which has to be the easiest to ride dual sport made, so it'll be perfect for him to get street legal and build up a bit of experience on. After that, he'll be ready to shop for his own dual sport and I'm trying to think of what bikes to steer him towards. He's about 6' 1" or 2" and about 175-180 lbs. I know the XT225 can carry his weight fine, but I'm thinking he might fit better on a DR350.
I'm curious about the fuel milage of a DR350. What's a "real average" that most folks get? |
10-10-2012, 03:20 PM
#13334 |
-Devo
Oddometer: 2,905
I'm 200lbs and average 60mpg on the street with stock carb setup. I'm light on the throttle. It dips to 50mpg when doing trail riding. I'm 6'0" and started on an XT last year. I loved it but was a tad too short for me. The extra 50lbs is noticeable however.
06' Wee 99' DR350 |
10-10-2012, 03:48 PM
#13335 |
Dodgin' the Ditches
Oddometer: 1,156
50 lbs?
I thought that the XT225 is 267lbs and the DR350 287 lbs, if that's right it just 20 lbs. If the DR350 is top heavy, like the DRZ400S, it probably feels like 50 lbs on the trails. 60 mpg sounds pretty good. |
