10-09-2012, 09:04 AM
#1 |
n00btube
Oddometer: 87
2001 r1150gs slight knocking noise
Hey all. I hear a slight knocking on my bike. If I'm facing the bike it's most clearly heard from the left side.
The valves sound really nice. I've done the chain tensioner mod which is on the other side. Maybe I just need to rebalance and idle the carbs? It's not that there's any problem right now I would just like to prevent a complete rebuild or some kind of worse failure on a trip. Any advice would be appreciated. Thx. |
10-09-2012, 09:13 AM
#2 |
I have little to say
Engine knocking to the untrained ear is deceptive and often misleading. It is rare that the boxer engine blow up after the owner reports an engine noise. You'll need to provide more details regarding the so-called knock so we can accurately diagnosis your issue. So, here are the hints; 1- Frequency of the knock. 2- From what area of the engine does the knock come from? 3- Does it go away with RPM changes? 4- Clutch in or out? 5- Hot or cold? 6- What engine oil is in the engine ans how many miles on this oil? What brand filter? Finally, try this. When you next cold start the engine, let it run for 10 seconds cold and shut it off with the kill switch leaving the key on. Count the seconds from the time you shut it off and when the oil light comes on and report back here.
10-09-2012, 09:41 AM
#3 |
You don't get me
Oddometer: 12,404
It could be the throttle bodies. The shaft wears and allows the butterfly to move in pulse with the intake. I would call that a tapping sound but some might call it knocking. Easy enough to put a finger on the shaft while the bike is running and see if it makes a difference.
A genius is the one most like himself. - T. Monk via S. Lacy Do stand up guys lie? |
10-09-2012, 02:56 PM
#4 |
Oddometer: 631
10-10-2012, 06:31 AM
#5 | |
Oddometer: 1,094
+1
For now, it sounds like a set of false teeth from a trick and joke shop
'64 BMW R50/2 - "Gone but not forgotten" '76 BMW R90/6 '02 BMW R1150 GSA |
10-10-2012, 08:39 AM
#6 | |
10-10-2012, 08:58 AM
#7 | |
You don't get me
Oddometer: 12,404
I second def's suggestions in his previous post. It may help to use a stethoscope/long screwdriver/woden dowel/piece of hose to try to isolate where the 'knocking' is comming from.
10-11-2012, 07:30 AM
#8 | |
Oddometer: 399
As a matter of curiosity I did the cold shut down test you outlined above and got ~12sec. on my bike. I would assume the longer the time, the better the health of the engine. Is there a number which indicates "bad"? Cheers, James |
10-11-2012, 09:32 AM
#9 | |
The trick is to do this occasionally before you change oil and after you change oil. You'll get a reasonable baseline with which you can judge oil viscosity, engine bearing clearance and how temperatures effect oil viscosity and engine clearances. I would speculate that good 15w-50 oil in a boxer with normal bearing clearances at 75 F. ambient, the ~12 seconds cold oil pressure bleed down you observed is normal. |
10-11-2012, 10:07 AM
#10 |
I just did my oil pressure bleed down on my '01 with ~50,000 miles and old 15w-50 Mobil 1 oil. About 10 seconds cold (ambient is 70 F.). I had some errands to run so when I returned to the garage with the bike hot, I did it again. This time about 2 seconds with hot oil and engine. I consider those nominal times. Remember, there are many variables in this test so use caution when evaluating the information.
10-11-2012, 04:21 PM
#11 | |
n00btube
Oddometer: 87
link to video: https://www.youtube.com/watch?v=iVqO...1&feature=plcp 1. frequency seems pretty consistant 2. sounds like just under the cylinder head (if your facing the bike front left) 3. No, it's more noticable when it's idling but I can still feel it (or so I think) when its up around 4000 4. clutch in or out has no effect 5. pretty consistant hot and cold (maybe a little more pronounced when hot) 6. 20w-50 castrol synthetic. almost 3000 on this change (engine has 48,000) filter is bmw, Cold start test was 6 seconds until light came on And thank you!!! |
10-11-2012, 04:25 PM
#12 |
Oddometer: 1,094
I must need new speakers....sounds like an 1150gs boxer to me. Not trying to be funny here, perhaps it is my speakers?
10-11-2012, 04:34 PM
#13 |
MotoOCD sufferer
Oddometer: 572
I agree. I'm no JVB, but that sounds like my 2000 and it was just at the mechanic, not for engine issues, but they checked it over it gave it the thumbs up.
2000 R1150GS- ZenPig 2003 F650GS (sold) formally trained to screw with people's minds.. |
10-11-2012, 04:36 PM
#14 |
n00btube
Oddometer: 87
10-11-2012, 04:37 PM
#15 |
Not afraid
Oddometer: 11,254
that bike sounds smooth and quiet to me, especially when compared to the one I ride daily.
"A little inaccuracy sometimes saves a ton of explanation." - H. H. Munro (Saki) (1870-1916) |
