Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 10-11-2012, 07:21 PM   #5566
TowPro
I want to ride
TowPro's Avatar
Oddometer: 1,761
Originally Posted by Rick001 View Post
It only humms when the GPs talks, and keeps humming until it switches back. does not hum if ear buds are plugged directly into GPS, GPS is plugged directly into the Sena mounting bracket. It only humms when it goes through the SR10.
I don't recall if mine makes any noise. Its not going to be the quality sound you hear when you plug in ear buds, because the SR10 to SMH10 bluetooth connection is low quality audio like used in a phone connection. I can't check mine now, but the GPS only talks while I am moving, then I have wind noise in the helmet and if the noise is there, I don't hear it. but I do hear that Garmin lady tell me when to turn
2010 F800GS Stone Road Touring bike!
TowPro is online now   Reply With Quote
Old 10-11-2012, 07:27 PM   #5567
Rick001
Never too old
Rick001's Avatar
Oddometer: 571
I now its only going to be mono coming out, but it has a very strong background noise that is audible at 100kmh when the GPS talks. Not too bad when there is instructions coming through, but is really annoying when the instructions stop, and you have that delay before the GPS audio disconnects. Will try moving the SR10 to a different location and see if that helps.
Just figured out that the noise is caused by the power cable to it. Run it off the internal battery and it is fine. Plug the power cable in and it gets the humm. Looks like i need a 12v power filter of some kind.
Think Ive fixed it.. Need a Ground Loop isolator...... get one in the morning and pray.............
"ADVENTURE B4 DEMENTIA"
Rick001 screwed with this post 10-12-2012 at 12:33 AM
Rick001 is offline   Reply With Quote
Old 10-12-2012, 05:24 AM   #5568
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 549
Snap a ferrite choke on the cable and see if that helps. Sounds like you have some RF interference.
IBA #33260
cablebandit is offline   Reply With Quote
Old 10-12-2012, 08:07 PM   #5569
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,789
'Ferrite Choke' would be a great name for a band.
Sorry, nothing to report in the gps world today.
"Don't play a lute to a cow" (Old Chinese Idiom)
Emmbeedee is online now   Reply With Quote
Old 10-12-2012, 08:17 PM   #5570
TowPro
I want to ride
TowPro's Avatar
Oddometer: 1,761
He actually needs a 1:1 transformer that stops a "ground loop" which can be caused when you have 2 devices, both running off the same power source that are talking to each other.
Old 10-13-2012, 08:03 AM   #5571
Bill Murray
Bill Murray's Avatar
Oddometer: 79
I just finished a three-day trip to ride on the Blue Ridge Parkway and my Montana 650 performed well. I cannot say enough about how much I like navigating using Tracks versus Routes.
I saw an interesting behavior while using the Track Manager. (I was using the v4.60 firmware.)
I had the Montana in its mount, and my bike was powered off (the CANBus power circuit to the mount was not powered at the time). I started the Montana manually, using its on/off button. I went to the Track Manager, selected an existing Track, and then pressed the Delete button to delete the Track. The unit immediately shot down. I restarted the Montana and returned to the Track Manager. Repeated the deletion sequence with another (different) Track and the Montana powered off once again. I repeated the sequence (powered up the Montana on its battery and entered Track Manager) again and selected a third Track for deletion. The third Track was deleted without the unit shutting down on its own. All three Tracks were created in BaseCamp (converted from Routes) and sent to the Montana's internal storage.
Has anyone seen this Track Manager behavior before?
Otherwise, my Montana performed flawlessly.
Bill Murray
2009 BMW R1200GS Adventure
Me on Google+
Bill Murray is offline   Reply With Quote
Old 10-13-2012, 05:43 PM   #5572
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,789
I have - I've reported recently how my Montana shut down repeatedly as I tried to delete tracks. Otherwise, mine works perfectly the rest of the time. I never have lockups/white screens etc at any time while using it. In fact it's been many months since I've had a lockup.
Old 10-13-2012, 08:16 PM   #5573
Timmer
Timmer's Avatar
Oddometer: 2,008
On my just completed month long ride in Europe, I had the unit lock up on me 3 times. It took a battery removal to in-freeze it. I'm only on software version 4.4 so an update is probably necessary.
Tim in Burien, WA
Tim in Burien, WA
'05 R1200GS (Sleeping in Germany)
'03 F650GS
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 10-13-2012, 08:23 PM   #5574
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,789
Tim in Burien, WA
Removing the battery to unfreeze it is likely to allow it to lock the same way again. The best way to unfreeze it is to hold the power button in for 20 seconds when you have the gps off a powered mount. This seems to clear out caches or something, and is much more reliable.
Old 10-13-2012, 08:59 PM   #5575
Timmer
Timmer's Avatar
Oddometer: 2,008
Thanks for the tip. I think I tried that with no success, but I'll be more conscious about it going forward. I do really like the unit especially after fighting with my 2720 which has a failing touch screen today on a 250 mile rain ride in Western WA.
Tim in Burien, WA
'03 F650GS
'03 Wing
'01 ST1100
Old 10-13-2012, 10:44 PM   #5576
hanksmybuddy
hanksmybuddy's Avatar
Oddometer: 264
Help before I throw this thing. Here's my problem. I have the Montana 600 and am using BaseCamp. I purchased the Topo US 24K yesterday. Loaded it on my computer but can't seem to get the maps to load up to the Montana. I've disabled everything on the Montana Map wise and tried again but still no new maps. WTF? Just noticed on the back of the packaging where it list compatible Garmin units. The Montana is not listed but I can't imagine they are selling software that won't work on their new units. Thanks in advance for any help.
hanksmybuddy is offline   Reply With Quote
Old 10-13-2012, 11:38 PM   #5577
calltrex
calltrex's Avatar
Oddometer: 25
There was a problem with some of the batteries. Mine kept shutting off
They sent me a new one and is all good now
2012 KTM 350 EXC-F
calltrex is online now   Reply With Quote
Old 10-14-2012, 05:08 AM   #5578
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,789
You need to use MapInstall. Make sure you have the most recent version by checking here: Windows Version
Or if you have a Mac, go here instead:
Old 10-14-2012, 08:50 AM   #5579
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 412
Which version of Topo US 24k did you purchase? They should all be compatible with your Montana :)
Nearly everything you need to know about sending maps to your Montana can be found here.
Garmin Montana Wiki Oregon 6xx Wiki BaseCamp Wiki
atlas cached is offline   Reply With Quote
Old 10-14-2012, 02:41 PM   #5580
scotty69
scotty69's Avatar
Oddometer: 826
Got my new Montana to replace my piece of #hit one I got first off. The new one, I am tickled to say, stayed on the bike all day (150 ish miles) without ever shutting off or giving me the white screen! Maybe Garmin fixed the problem.
Orchestrated Chaos!
www.arkansas500.com
scotty69 is offline   Reply With Quote
Times are GMT -7.   It's 06:56 AM.
