Old 10-10-2012, 08:14 PM   #1
kellymac530 OP
motorcycle addict
kellymac530's Avatar
Oddometer: 897
Corbin heated seat ?
My '96 R 1100 RT has a Corbin heated front and rear seat on it. Not my favorite, but it is what it is.
My question is, does anyone know how the heating elements are in the seat?
I am thinking about shaving a few spots of the seat and recovering it and I just do not want to cut the heating element. I am guessing the heating element is a wire that runs thru the foam and heats up like a heat blanket does. I can shave the seat foam I think unless the element is near the surface. There is a huge lump right under my berries that make my nads go numb after a 100 miles or so. There is also kind of a berm around the back of the seat that is too wide or wraps around too far under my thighs. I just want to trim those spots some and do a leather/suede seat cover or something.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 10-11-2012, 09:06 AM   #2
bigdon
Oddometer: 2,073
More than likely the heating element is glued to the foam and just under the seat cover. You should be able to remove cover then element from the foam and then carve away.
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 10-12-2012, 10:39 AM   #3
kellymac530 OP
motorcycle addict
Oddometer: 897
Thanks big dog. That is where I will start, pulling the cover and having a look.
Old 10-12-2012, 10:47 AM   #4
bigdon
Oddometer: 2,073
Not Big Dog, bigdon!
Ride Pooie Ride
Times are GMT -7.   It's 12:17 AM.
