Old 10-09-2012, 11:27 AM   #1
jconly OP
jconly's Avatar
Oddometer: 434
Fuel pump wiring - I've got an extra - Why?
So, I noticed this a while back, but figured I'd ask up.
Looks like my fuel pump has a third terminal that has been taped back out of the way. The bike only has a two terminal connector.
Can anyone tell me what this pump is (can't be stock right?) and what's behind wire #3?
IMG_1316 by justin.conly, on Flickr
IMG_1314 by justin.conly, on Flickr
jconly is offline   Reply With Quote
Old 10-11-2012, 11:41 AM   #2
jconly OP
jconly's Avatar
Oddometer: 434
Bump, anyone?
Old 10-12-2012, 05:44 AM   #3
jclark83
jclark83's Avatar
Oddometer: 393
Maybe someone replaced a broken or chafed wire?
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
jclark83 is offline   Reply With Quote
Old 10-12-2012, 06:45 AM   #4
RozzyCat
Bleeds orange
RozzyCat's Avatar
Oddometer: 542
Fuel pump connector
From the factory - you'll have a three-wire set up on the tank side hooking into two wires. On my 2010 S - Red connects to Black/Blue, Brown connects to Black and Blue doesn't connect to anything. Looks likes maybe previous owner changed to two-wire connector.
KTM 990, 300XC-W, 500EXC
RozzyCat is offline   Reply With Quote
Old 10-12-2012, 10:58 AM   #5
jconly OP
jconly's Avatar
Oddometer: 434
Awesome, thank you so much for confirming that.
Old 10-12-2012, 11:10 AM   #6
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,172
I had posted this earlier also in a couple of threads...
The adventure and super duke use the same fuel pumps. Only difference being that the super duke fuel pump has the low fuel sensor built into it and hence has a third wire in the fuel pump harness as well as the main harness side. The adv's have the low fuel sensor separate from the fuel pump unit hence make do with only two wires on the pump side but still have the three wire connector on the main harness side where one of the wires remain un used.
Building a KTM 690Exc - the ultimate dirt tourer
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally, 2012 KTM Adv990
Vicks is offline   Reply With Quote
Old 10-12-2012, 11:37 AM   #7
jconly OP
jconly's Avatar
Oddometer: 434
Ah that totally explains it.
Looking at the wiring diagram, every drawing of the pump showed that fuel level sensor and I was a little confused, assuming that's what the third wire was for. Oh the redundancy.
I wonder if they activate at different levels?
Old 10-12-2012, 08:43 PM   #8
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,172
regarding levels, yes they do activate at different levels due to the different mounting location (between Adv and SD tanks). However, due to the volume and shape of tanks, there will be close to same amount of fuel left in both tanks (approx 4 litres ?) when the sensor activates.
Times are GMT -7.   It's 10:18 AM.
