Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 10-08-2012, 07:53 AM   #1471
Kawidad
Kawidad's Avatar
Oddometer: 4,746
Originally Posted by motosickle2000 View Post
I agree completely. A wide ratio tranny is not even needed - the other gears work fine for the dirt as-is, but there is often a need in the gnarlier dirt sections to go slow and the current first gear does not allow you to do this without abusing the clutch.
I have also discovered that the Daytona 675 has a higher first gear than the 675 street triple. All of the other ratios are the same. The Tiger 800 is higher still.
It seems that first gear is the only ratio that Triumph plays with when going from one model to the next. In the case of the Tiger 800, I think that they did a poor choice for first gear.
+1
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 10-11-2012, 01:11 PM   #1472
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,436
I put on a 15T front sprocket yesterday afternoon. What a difference!! No more clutch feathering on take off. I did a short ride in the evening to see how the bike felt.
It runs about 300 rpm higher at any particular speed. I can't report on fuel consumption, but my estimate is that I am getting a little bit less mpg. The bike runs so great now, I really do not care about the mpgs. Maybe if I was doing a long trip with a lot of highway, I would change it back to the 16T.
I know it will be better in the hard stuff now in the Sierra. I hope to find out this weekend...
JG
live2ridetahoe is offline   Reply With Quote
Old 10-11-2012, 01:14 PM   #1473
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,458
JG
Was it a bitch to get the original sprocket off? I know it often is on other makes. I am running a -3 teeth in the back right now. Was thinking of going back to the stock rear sprocket and going up one tooth the in front if I can find an OEM front sprocket with the rubber insert.
swimmer is online now   Reply With Quote
Old 10-11-2012, 07:03 PM   #1474
forkt
Oddometer: 73
Bluhduh front sprocket
It has been for me anyway, I have tried on and off for several days now with no luck. I have tried heat, a 3ft lever, even my neighbors. All we succeeded in doing was bending his 1/2 socket wrench.
I'm taking it in this week have a mechanic with an impact driver take a swing at it. Others, it seems have not had this much issue.
Cheers
forkt is offline   Reply With Quote
Old 10-11-2012, 07:36 PM   #1475
live2ridetahoe
RN
Oddometer: 1,436
I found it easy. Just be sure to bang out the lock washer before trying to spin the nut off. If you don't, I don't care how strong you are... you'll never get it off.
I used a 3 foot long piece of black gas pipe as a breaker bar. It came right off.
I had to adjust my chain slack after also.
JG
Old 10-12-2012, 04:12 PM   #1476
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,152
Cheers
Impact driver is your best bet. I went to my buddy's shop and we used his to get the old CS sprocket off today. No more zinging the engine to 3+ grand to take off from a stop. I can't wait to ride this thing in the woods tomorrow with the new 15T sprocket.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is online now   Reply With Quote
Old 10-12-2012, 04:52 PM   #1477
motosickle2000
Oddometer: 187
A 650 Vstrom has a stock 15T with the rubber inserts. I have seen it posted that it will fit a Tiger, although I have not verified this myself.
motosickle2000 is offline   Reply With Quote
Old 10-12-2012, 05:03 PM   #1478
motosickle2000
Oddometer: 187
Originally Posted by IL8APEX View Post
The Daytona first gear was changed (made taller) from the '06-'08 models to the '09-current models. If someone wishes to dig into it I'd bet $0.25 that they'd find the current Street Triple first gear to be common with the '06-'09 Daytona.
-Tom
You are half right - the Daytona gearing was made taller. The street triple has not and it has by far the lowest first gear. It is 34/13 for a gear ratio of 2.615. The Tiger 800 is 34/16 for a ratio of 2.125 - that is a 20% difference in gearing! Triumph needs to put a street triple tranny into the Tiger 800.
Old 10-14-2012, 09:26 AM   #1479
IL8APEX
Oddometer: 88
Gleaned from the interwebs:
2006-09 Daytona 1st gear: 2.615 (34/13)
2010-12 Daytona 1st gear: 2.313 (37/16))
2007-12 Street Triple 1st gear: 2.615 (34/13)
2011-12 Tiger 800 1ts gear: 2.313 (37/16)
All suspicions confirmed.
-T
IL8APEX is offline   Reply With Quote
Old 10-14-2012, 06:08 PM   #1480
motosickle2000
Oddometer: 187
-T
I checked both Bike Bandit parts and World of Triumph and the Tiger 800XC first gear is 34T - not 37T.
http://www.worldoftriumph.com/triumph_motorcycle_parts_locator.php?block_01=&block_02=100057371-0-2&block_03=560040
http://www.bikebandit.com/2012-triumph-tiger-800xc/o/m154268#sch740798
Old 10-14-2012, 08:45 PM   #1481
burmbuster
burmbuster's Avatar
Oddometer: 1,429
You don't have to have a front sprocket with a rubber insert. You will not notice any difference.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 10-14-2012, 10:52 PM   #1482
forkt
Oddometer: 73
Front Sprocket
Impact driver was the key. New 15t is on, and as others have said, what a difference. It feels like im always in the powerband now and lifting the front is much easier.
Old 10-15-2012, 12:52 AM   #1483
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,691
Originally Posted by burmbuster View Post
you don't have to have a front sprocket with a rubber insert. You will not notice any difference.
+1
2002 black Tiger955i, 72000 miles and counting.
2012 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 10-15-2012, 07:41 AM   #1484
Riot
Tiger Rider
Oddometer: 105
Weird cause http://www.worldoftriumph.com/triump...lock_03=560040 shows a 16 Front & a 49 Rear
Riot is offline   Reply With Quote
Old 10-15-2012, 08:50 AM   #1485
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,691
Er, the 16/34 are the internal gears not the sprockets.
Times are GMT -7.   It's 09:59 AM.
