10-12-2012, 05:34 PM
#70156 |
ADV in training
Oddometer: 610
The BST Bible was what I went off of. That was where I noticed that my spring was missing a part. I just didn't see where to get at that float needle thing. After many frustrating experiences, I've learned better than to try forcing small, plastic parts around. Now that I know they come apart, however, I can check them out. I'm also looking at getting a TM40 for this bike before too long anyways, so this might all be a moot point, but it's always good to learn.
_________________________ Ride videos '01 DR650 "The impossible often has a kind of integrity which the merely improbable lacks." |
10-12-2012, 05:35 PM
#70157 |
Oddometer: 641
Lucky you
I have a plan to turn my yellow-that-used-to-be-white IMS tank white again. I found that using a scotchbrite pad with soft scrub with bleach helped quite a bit.....I just didn't want to spend 24 hours scrubbiing on it to get the best results. So I'm going to get some scotchbrite type pads for my electric drill, along with the softcrub, and use a slower speed to scrub the tank beyond belief. Believe me that sob is going to be white again
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
10-12-2012, 05:58 PM
#70158 | |
Oddometer: 2,551
Something like this from the BST-Bible: ![]() Hides in here on our DRs.
10-12-2012, 06:22 PM
#70159 |
ADV in training
Oddometer: 610
Ohhh! Yeah, I saw that part. I guess I just need to pull it out and check it for wear. So I guess I must have put something back together a little incorrectly. I thought it was running well, but now it has a very rough idle if you're not on the choke and pops like crazy on decel. I'm going to order that clip for my spring, and I guess I need to fiddle with my fuel mixture screw. I thought I had measured two full turns, though I could just be a quarter turn or so off when I reset it. Do you back the screw out to richen the mixture a bit?
10-12-2012, 06:33 PM
#70160 |
Oddometer: 2,551
10-12-2012, 06:48 PM
#70161 |
ADV in training
Oddometer: 610
Tell you what, I'm going to devise quick release systems for the side panels, seat, and fuel tank. Even if I don't become a millionaire, I'm sure I'll save about 10,000 man hours per year.
10-12-2012, 07:12 PM
#70162 | |
Oddometer: 1,168
![]() ymmv, doug s. |
10-12-2012, 08:04 PM
#70163 | |
Oddometer: 2,551
10-12-2012, 08:11 PM
#70164 |
ADV in training
Oddometer: 610
I've also learned a valuable lesson about why I need to get that god damned extended fuel screw. So I backed the fuel screw out about 1/2-1/4 of a turn. The bike fired up, with choke, but when I gave it throttle, the engine would sputter and die. Assuming that I had the mixture too rich, I screwed it in about 1/4 turn, put everything back in place, and fired it up again. It's about the same. The idle is still very "chuggy" and dies after about 10 seconds, and now, when I open the throttle any more than 1/3 or 1/2, the engine sputters and dies. I'm assuming that I'm running too rich, but I also know next to nothing about carburetors, so I might be a bad judge here. Does it sound like I'm running too rich?
10-12-2012, 08:40 PM
#70165 | |
Oddometer: 1,110
Low rpm all throttle positions: float height, needle base diameter, emulsion tube outlet size WOT operation overall: main jet WOT operation between HP peak and red line: main air corrector WOT operation below red line: jet needle shape 1/4 throttle opening: jet needle clip position 1/8 throttle opening: pilot jet size 1/16 throttle opening: pilot jet size idle: mixture screw adjustment Realistically, the float needle condition should be verified and the float height set before the idle mixture is adjusted. Procedure: Hold the carb in one hand and hold the base of the float cage tightly against the carb body with the index finger of the same hand. Rotate the carb so that the float tang just contacts the float needle's spring loaded plunger, but does not depress it. With the float height setting tool set to the desired height, use the other hand to drop it down over the float so the tool's posts contact the bowl gasket surface and the posts are square to the body (front to back - the tool takes care of side to side). Flip the tool to check both sides (as the float may have some twist in it). Bend the float tang until the tang on the float height setting tool just contacts the highest point on the float, but does not depress it. Procedure for setting idle mixture: Start the engine and warm it up. Lower the idle speed below the factory spec. Starting from a setting that is known to be lean (1-1/2 turns is likely but not guaranteed to be), adjust the fuel screw to obtain the highest idle speed. Adjust to 1/8 - 1/4 turn richer than that. Then, adjust the idle speed back to 1500 rpm. Once you have the correct fuel screw setting, there should not be too many reasons to have to revisit very often. I'm therefore not a big proponent of extended fuel screws. If you intend to own carbureted motorcycles in the future, I recommend procuring an angle-drive screwdriver, which will be universally applicable. Regards, Derek |
10-12-2012, 08:44 PM
#70166 |
Oddometer: 2,551
Screw it in snug, back it out 1-1/2 turns, ride. Some time ago (39,000 miles or so), I was browsing the internet and I kept seeing 1-1/2 turns. Sounded good to me. I've since bought the extended fuel screw and messed with it. I'm still at 1-1/2 turns, give or take. At my altitude (6000 +), I'm satisfied; although I've heard that riding a TM-40 or FCR will ruin me forever (or until I convert).
![]() ![]() Yesterday, my baby turned 40. ![]() ![]() 205'd by motolab
10-12-2012, 08:49 PM
#70167 |
Oddometer: 739
Thumb screws...made all the difference
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb. 1985 Yamaha CA50 - My Hot Rod 2009 Piaggio BV-250 - Escusi, Babba be bo-bee |
10-12-2012, 08:56 PM
#70168 |
Take it apart
Oddometer: 1,116
got my single track setup. 18" rear wheel with 90/90-18 and drive hub with off road gearing.
I have a street tire for the 17" rear with another drive hub and highway gearing. ![]() I've also made a different dog bone plus the larger wheel gives me about an extra inch of ground clearance. ![]()
1999 Suzuki DR650 1998 Honda VFR800 Interceptor http://share.findmespot.com/shared/f...KJutW9osVpn3hd |
10-12-2012, 09:10 PM
#70169 | ||
ADV in training
Oddometer: 610
#70170 | |
ADV in training
Oddometer: 610
