Old 10-13-2012, 03:44 PM   #70036
Paddle007
Oddometer: 303
Originally Posted by Adv Grifter View Post
One correction, I would NOT screw the fuel mixture screw in "Snug". It has a very sharp point on the tip which can be damaged from over tightening. Just screw in till it bottoms ... never force it, it will last a LOT longer this way and be more effective when fine tuning.
1.5 turns out works for me too at most altitudes. (I'm at sea level but ride frequently at altitude). When I'm up high I LEAN out the mix and go in a half turn or so on the Fuel mixture screw. Works a treat. At 12,000 PLUS ft. I got the DR idle to smooth out and starting recovered to normal ... and leaner settings save fuel!
I'll back you up on that. I had a friends DR with the TM40 carb that was kicking my behind with running problems. One of the problems was no adapter ring and the second was the tip of the mixture screw was broken and stuck in the bottom of the hole. No air could pass through and it created some strange running problems.
Paddle007 is offline   Reply With Quote
Old 10-13-2012, 04:03 PM   #70037
neo1piv014
ADV in training
Oddometer: 619
So with everything put back together again, jacked up needle and all, I got it back on the bike, and she fired up like nothing had ever happened. I let it warm up, verified that it idled without the choke after a minute or two, and took her for a ride. Knowing I have a messed up needle may be inducing some bias in the testing, but the fueling feels a little odd now. Nothing I can really put my finger on, but that's getting replaced, so we'll see. I've also noticed that it pops a good bit on deceleration/engine braking. It's not terribly annoying, and I might just be noticing it now because I usually ride with earbuds in place. Should I just hold judgement on this thing until I get the needle replaced? Thanks to everyone for chiming in on yet another of my little projects.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-13-2012, 04:10 PM   #70038
motolab
motolab's Avatar
Oddometer: 2,627
Originally Posted by neo1piv014 View Post
You definitely may. Any preferred source that I should snag it from?
Well, http://advrider.com/forums/showthread.php?t=528038.
Regards,
Derek
motolab is online now   Reply With Quote
Old 10-13-2012, 04:12 PM   #70039
neo1piv014
ADV in training
Oddometer: 619
Originally Posted by motolab View Post
If you intend to own carbureted motorcycles in the future, I recommend procuring an angle-drive screwdriver, which will be universally applicable.
Regards,
Derek
What angle-drive screwdriver are you using? A quick glance around the hardware stores in my area showed a few right angle screwdrivers, but they were all quite stubby. If there's a nice, thin one, I'd get that in a heartbeat.
Ride videos
'01 DR650
Old 10-13-2012, 04:45 PM   #70040
BergDonk
BergDonk's Avatar
Oddometer: 3,591
Originally Posted by acesandeights View Post
Typically, as the contact patch decreases the contact pressure increases. As you lose floatation you often increase bite, or traction due to the smaller contact patch. I have more experience in offroad truck tires, but if you want to increase traction, you often need a narrower tire. There are trade offs and conditions can dictate what works in a given situation, but riding desert sand might favor a wider tire, where you need more floatation, and forest single track might favor a narrower tire, where the narrower tire has more traction.
What is interesting about this is that, all other things being equal, which of course they almost never are, if the only change is the tyre width, keeping the same type and construction of tyre, and the same air pressure, as the tyre gets narrower, the pressure at the patch increases, which flattens the contact patch. The net result is that the surface area of the contact patch is more or less the same, but its shape gets progressively narrower and longer. Arguably more relevant when talking about 4 wheeler tyres which of course have a nominally flat tread.
A wider leading edge to the contact patch creates more flotation on soft surfaces. In fact sand is like going up a hill all the time. The tyre sinks in and is always climbing up the front edge. Make it narrower, and its a steeper/deeper face to climb out.
A longer contact patch can add stabilty compared to a wider one. Its why we prefer 21" fronts to smaller ones with wider tyres on our dirt bikes. The contact patch isn't much different in size, but the shape is longer, hence more directional stability.
Make sense?
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 10-13-2012, 04:53 PM   #70041
Tex76
Motersykle Advntyers
Tex76's Avatar
Oddometer: 869
Hey guys, anyone know where I can get a black rear fender? I've been changing plastics and I've ordered the rear black twice and both times they email me a couple days later canceling the order because its not available. What gives?
"We act as though comfort and luxury are the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about."
2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650
30:Unemployed and Homeless (2 months and 10,000 miles)
The Lost Texan, Wanders East
Tex76 is offline   Reply With Quote
Old 10-13-2012, 04:55 PM   #70042
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,949
Procycle?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 10-13-2012, 05:19 PM   #70043
neo1piv014
ADV in training
Oddometer: 619
What he said: Procycle. They do full plastic kits and regularly keep black in stock
Ride videos
'01 DR650
Old 10-13-2012, 05:22 PM   #70044
Tex76
Tex76's Avatar
Oddometer: 869
Thanks ill have to call them. I've seen their full plastics kit but I don't need all that, or want to spend that much lol.
Old 10-13-2012, 05:53 PM   #70045
motolab
motolab's Avatar
Oddometer: 2,627
I use a Kawasaki 57001-1239, which fits in very tight spaces because it has a cable inside a 90 degree bent tube. If you want a cable drive that's more readily available (and really inexpensive) there's the K&L 35-1968, but it's bent just a bit less than at a right angle. Then there is the Motion Pro 08-0229, which is gear driven and therefore not as compact, but has the benefit of using bits, so you can put a variety of different tips on it.
Regards,
Derek
Old 10-13-2012, 06:42 PM   #70046
SingleTrackJeff
Lurker and Hangaround
SingleTrackJeff's Avatar
Oddometer: 684
Jet Kits
I found this Sigma jet kit on eBay. Haven never heard of them but I haven't looked a lot lately.
Has anyone tried it and does it work any better than the Dino jet, I never could get the Dino jet to work with out stumbling off closed throttle. Every one tells me the Dino jet needle is the prob but that is over my head.
Any other suggestions on a jet kit to try that works.
http://www.ebay.com/itm/1990-11-Suzu...8de276&vxp=mtr
SingleTrackJeff is offline   Reply With Quote
Old 10-13-2012, 07:17 PM   #70047
acesandeights
Asperger
Oddometer: 3,949
Originally Posted by BergDonk View Post
Make sense?
It does to me, but you seemed to use more words
Old 10-13-2012, 07:23 PM   #70048
BergDonk
BergDonk's Avatar
Oddometer: 3,591
Yeah, but the point I was trying to make is that the contact patch doesn't necessarily increase in size with a wider tyre, just its shape changes.
Fewer words
Old 10-13-2012, 09:04 PM   #70049
procycle
procycle's Avatar
Oddometer: 2,313
Cheap Chinese jets with questionable size markings on them. No needle, just some washers to shim it up. Not much of a value for $50.
The stumbling just off closed throttle can be blamed on the DynoJet recommendation of running the mixture screw at 2-1/2 turns out. That will be way to rich and cause a rich bog just off idle. Most riders have had good results by setting the idle mixture right on the lean edge of the smooth idle range - usually around 1-1/4 turns out.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-13-2012, 09:36 PM   #70050
motolab
motolab's Avatar
Oddometer: 2,627
I would recommend the non-USA OEM adjustable needle.
Regards,
Derek
Times are GMT -7.   It's 10:39 AM.
