Old 10-12-2012, 10:46 PM   #5956
alpine rider
Oddometer: 29
nasty arm pump
Soooo, a while back there was some discussion about trying to gain a little more controll over the throttle, most notibaly in slower, more techy terrain. Any of you guys had any success? I get some wicked throttle hand/arm pump going, trying to keep this little bitch steady at slower speeds. Seems like its either full on or full off with no middle ground. The whisky throttle comments gave me a good chuckle, as that was all me yesterday, pumped silly unable to shut her down careening through the baby heads.
I have the softest KTM throttle cam installed...not sure that really helped much. I've also messed around with the performance settings a bunch and yes the soft setting (3-?) is indeed a little better, but not better enough to warrant de-tuning this bike that much. The throttle was still super snatchy down low.
alpine rider is offline   Reply With Quote
Old 10-13-2012, 07:36 AM   #5957
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,003
Originally Posted by Gros Buck View Post
We'll come from underground to grab it ...
You're certainly aware Bob entered a pretty intensive love-hate relationship with his fuel pump that affected drastically his average yearly millage ? He's been in the dez often, for sure, but repeating unfortunate events prevented winds to blasts his (pretty well maintained) scalp too often. If you want Bob to test it, you'll most probably have to convince Seth to flushes all of his hopes into that rally car, and take back seriously his duties at figuring out an alternative to our collective pump misery.
Paul Jr
It's not the pump anyway. My Berg has the same pump and it runs great, every time without fail. The Vortex solved my running issue but not being able to tune it myself was a hassle. Seth is inline for a harness but his 690 is apart
I'm trying to convince him to ride the MX1K with me next may
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-13-2012, 10:11 AM   #5958
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 903
How does the MX1000 navigate???????????? maybe a 690 test team:
I do plan on doing KOTW again but on the berg as the course is sussposed to be very tight this year and the milages per day about 1/2 of the last one.Just cant do 500 miles in a day on the 5fiddy
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 10-13-2012, 02:50 PM   #5959
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Well
Come on ... Your 50 lbs heavier then him. A "slap" behind his head should help him forget he's not a hard core enduro rider and join your ride blindingly ... If it does not work with your hand, try with the hockey stick ...
Seriously ??? Bob has no pump problems after all ???
Paul Jr
KTM690r 2011
Gros Buck screwed with this post 10-13-2012 at 02:57 PM
Gros Buck is offline   Reply With Quote
Old 10-13-2012, 03:55 PM   #5960
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 903
I did have two pump problems but only one of them was actually the pump. i have many more problems that were fuel delivery/ecu problems that can not be sorted and definitively fixed. I truly believe most of the problems are not in the hard parts of pump, filter, injector or regulator. I think it is how they are hooked together and the whole fly by wire thing is bullshit you dont need on a dirt bike..
Yes it has significantly limited my millage , having these problems, but when this bike works it works very well for what I like to do and i dont see anything else on the market that will work as well. including building something . believe me i have thought about it a lot.
I would go carb but I dont know how to get the correct cdi box or trigger. I seems to me that a more robust and less sensitive ecu can be made to work easier. basically the hardest part is tuning it on a dyno with someone that knows how to set up spray amounts
If this dont work I know where you can pick up a 690 that is well used but maintained for cheap and Ill be on a xr 600 with a button.
Ride the DEZ
76 CB750
Old 10-14-2012, 04:08 AM   #5961
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 953
Pegs
Anybody got a line on a footpeg lowering kit or a lower footpeg?
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 10-14-2012, 04:22 AM   #5962
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,105
Fastway adventure F6 ? Pivot pegs , ktm hard parts , pro taper , the list goes on ,
Mudguts is offline   Reply With Quote
Old 10-14-2012, 05:22 AM   #5963
690_Mod
Oddometer: 1
heres some pics of when i installed the rally cam and did port/polish with 5 angle valve job
here is the engine fixture i made it can rotate on the bench and its awesome when torqueing bolts
the head off, its nasty because i tuned the bike with the tuneboy to make it rich as hell 10:1. it dirtys the engine fast but its worth it for the power
here you can see the difference in lobe seperation angle and duration of the two cams , the rally cam has mega duration , its worth mentioning that the dynamic compression ratio is dropped enough that the idle needs to be turned up , its also worth mentioning that my lightweight speedcell battery has no problem cranking the engine anymore because of the dynamic c/r, it cranked it before but sometimes it struggled .
here i am checking the piston to valve clearance , there is plenty of room
piston is lubed and ready to go
here is the nice porting work i had a machine shop do it because they had a flow bench , i had a 5 angle valve job done as well
here is the bike after its all put together , minus teh chain
here is my latest mod a JE std bore 13:1 pop up hypereutectic piston, its not installed yet , i will install it over the winter , i cant wait
on a side note i got this brembo master cylinder for the brake and clutch , they are simply amazing , if your looking to upgrade your masters get these because they are awesome
top view with reservoir mounts
690_Mod is offline   Reply With Quote
Old 10-14-2012, 05:59 AM   #5964
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,978
At the point where customers started asking for a "5 angle valve job" I normally say. "I'll take care of it", and use a radius insert.
Rally cam appears to have an asymetric lobe design. Can you confirm, or is that the angle of the photo, combined with the left over spirits in my system this morning
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is online now   Reply With Quote
Old 10-14-2012, 06:00 AM   #5965
LukasM
Oddometer: 5,386
Nice bike and mods, 690_Mod!
Do you have any dyno results before and after? Wondering how much potential there is to improve the stock head, I heard they come rather well done from the factory.
And what offset triple clamps are you running?
Cheers,
Lukas
Old 10-14-2012, 06:54 AM   #5966
daveknievel
daveknievel's Avatar
Oddometer: 416
Yes, do tell about the head. My buddy has a flow bench. Might have to put him to work this winter.
daveknievel is offline   Reply With Quote
Old 10-14-2012, 08:07 AM   #5967
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,197
Gros Buck - Assembler!? I read the manual, once .
Went out for some late afternoon urban dirt yesterday, ended in bed. Started ride with 15 minute idle reset. Thirty mins of city travel had a number of stalls. Got to dirt and stalling / rough running increased to point where I headed back to road after just 15 mins.
Cut the bike off while waiting on a train and wouldn't restart. Let it sit for a bit and try again, nada. Finally got a sign of life but turned into a back fire which separated the throttle body from the motor. I'm not in one of the better parts of town so opt for phone and charge card evac before sun goes down and drug lords come to check on their labs.
Back at the house, refix tb, starts right up. pos.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 10-14-2012, 08:46 AM   #5968
SlowRide13
Veteran n00b
SlowRide13's Avatar
Oddometer: 1,336
Originally Posted by Sutherngintelmen View Post
...Went out for some late afternoon urban dirt yesterday, ended in bed...
I know a guy with a nice XR600R he'd probably sell you. I think you already have his number
p
F800GS Grin Machine
KTM690E Grrr Machine
XR600R Oakey Mtn in the mud http://www.youtube.com/watch?v=bzoU2NpkaoA
www.hoofrehab.com
SlowRide13 is offline   Reply With Quote
Old 10-14-2012, 08:54 AM   #5969
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,351
Got my head back from the guy that cut the valve seats. He thinks that the seats were originally cut wrong on the right side from the factory. The left side exhaust was still at 2 mm which is new spec, while the right side exhaust was 1.1 The right side intake had no seat at all and the left side was at .9 mm. Anyway, all 4 are at 2 mm now so should be good for another 27K miles at least.
He also confirmed the valve guides were good. Now I just have to get around to putting it all back together.
Old 10-14-2012, 08:58 AM   #5970
Bill the Bong
Supern00ba
Oddometer: 953
Thanks, a google search could not help me. Appreciate it.
Times are GMT -7.   It's 01:42 PM.
