Old 10-14-2012, 12:04 PM   #70066
procycle
procycle's Avatar
Oddometer: 2,375
Originally Posted by motolab View Post
There should be no need to do this if the rest of the circuits are tuned properly. The only legitimate reason I can see is if the bike will be used much higher altitudes than it is set up at.
In a perfect world that would be true but the fact is that the DR650s that people on this forum ride every day do not have "all circuits tuned properly". The original poster commented that he had a rich bog after installing the DynoJet kit. DynoJet's instructions tell you to adjust the mixture screw to a position that is too rich. In almost all cases the off idle rich bog can be cured by setting the idle mixture at the lean edge of the 'smooth idle range'. This is a practical solution that anyone can use.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-14-2012, 12:15 PM   #70067
motolab
motolab's Avatar
Oddometer: 2,714
Anyone can also refrain from installing a DynoJet kit.
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-14-2012, 01:21 PM   #70068
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by AJxr View Post
desert ripping dr riders i need your help
i will be dragging my DR650 cross country next month to ride the LAB2V and spend some time riding around moab, ut and around the ridgecrest/dv/palmdale area of california. my dr650 is 100% stock and i was wondering if i should change the jetting for this trip? i dont care about power gains or loss to much just want it to run good the whole trip.
2007, 15k miles, bone stock, bike lives in NY
Stock jetting will be fine. I've ridden Ridgecrest and the Mojave for over 30 years. Death Valley too. Great area. Try to find locals to guide you.
You will need better tires than stock. I'd go with TKC's or D606 or what ever you can find, especially up front.
November can be changeable weather. Be prepared for Cold and Rain. But mostly ... November is ideal for the area. Have fun. There are two decent bike shops in Ridgecrest.
Hope you get a chance to explore the area ... it's great riding. Husky Monument, Cuddyback lake, Charlie Manson's house ... and lots lots more.
"The Fun House", two miles out of Ridgecrest.
The Pinnacles, near Trona, CA.
Heading into Death Valley and over to Goler Wash.
Old 10-14-2012, 01:27 PM   #70069
neo1piv014
ADV in training
Oddometer: 619
Originally Posted by Tex76 View Post
So my bike decided to take a nap last night and won't start this morning. It was laying on its left side and could obviously smell fuel. What should I be looking to fix?
Was there any fuel visible on the ground? You might have just dumped some from the breather hose. If you're not using the stock tank with the vacuum operated petcock and you left the manual petcock in the ON position, it's conceivable that the carb got flooded when it was on it's side like that. You might be able to just let it sit for a while and try it again. Alternatively, you could turn the petcock to OFF (if it's manual), then use the drain screw at the bottom of the carb to drain the fuel out. Use some tupperware for this as there is a good bit of fuel saved up in there. Once that's done, tighten the screw back up, turn the petcock to ON, and try again.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-14-2012, 01:28 PM   #70070
neo1piv014
ADV in training
Oddometer: 619
Those last two are front page candidate material right there.
Ride videos
'01 DR650
Old 10-14-2012, 01:57 PM   #70071
JTB488
Oddometer: 152
Isn't there like indians behind those rocks
JTB488 is offline   Reply With Quote
Old 10-14-2012, 03:40 PM   #70072
AJxr
#395
AJxr's Avatar
Oddometer: 950
this is what i am after! i have a fresh set of mt21s mounted with heavy duty tubes. do you have any gps tracks or maps/guides. looking to make the most of my time out there
12 CRF250X - 01 CR250R
Help Plan the Toughest offroad route across the USA
AJxr is offline   Reply With Quote
Old 10-14-2012, 06:53 PM   #70073
badweatherbiker
badweatherbiker's Avatar
Oddometer: 705
Originally Posted by neo1piv014 View Post
I did forget about the cash part. That'd leave you with money in hand to farkle the daylights out of it, which is what dual-sports are actually for anyways.
Yep, new DR owner here!
Traded my FZ6 for that 03 today with 18,000 miles and a good bit of $$$ too!
The guy has not ridden it much in the last couple months and on the ride home (65 miles) it did studder a little bit so I assume it has some trash or gum in the carb, I'll get that cleaned up hopefully next week but I have to say it is way more comfy than the FZ was.
Like it so far!
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker is offline   Reply With Quote
Old 10-14-2012, 06:55 PM   #70074
Tex76
Motersykle Advntyers
Tex76's Avatar
Oddometer: 870
Thanks Neo, I'll try draining the carb. Sat all day and still wouldn't start tonight.
"We act as though comfort and luxury are the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about."
2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650
30:Unemployed and Homeless (2 months and 10,000 miles)
The Lost Texan, Wanders East
Tex76 is offline   Reply With Quote
Old 10-14-2012, 07:11 PM   #70075
ER70S-2
ER70S-2's Avatar
Oddometer: 6,705
thank you. i am devising a plan using a baclava and zip ties to keep my jaw closed while riding canyonlands.
Use the 1/2" wide zip ties.
Originally Posted by Ren20 View Post
Just rode 90 miles on the dr 650 for the first time. So different than my sv650. Feels light. Have to get used to bike. The way it handles.
It should turn like it's on rails, thinks it's a sport bike.
Quick feedback.
The seat is torturing device. I've read about how bad it is. Oh my, it was bad. I had to stand up for a few times because I couldn't feel my butt. Need to do something about it soon.
Do not buy the Zuki gel seat, it only delays the pain by 10 minutes. But it is a bit shorter.
It was still fun.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-14-2012, 07:29 PM   #70076
ER70S-2
ER70S-2's Avatar
Oddometer: 6,705
Mine gets flat on the ground more than I'd like to admit. Up to this point, it will always start () by holding the throttle wide open until it fires. Worked again today, flat front tire dropped me in a nanosecond, turning into a dirt parking lot.. Lucky for me I was going under 20. Probably on the ground for 15 minutes, I really like the stock vacuum petcock.
If that doesn't work, remove the tank, using air or a hose, blast the area around the spark plugs (always full of debris that you don't want in your cylinder, like sand or gravel), loosen the plugs a bit (half turn?, this will loosen any thing wedged against the plug), blast with air or water again and remove the plugs. If you have air, blow out the cylinder to displace the fuel vapors. If you don't have air, hold the throttle wide open (fuel won't flow at cranking speeds with an open throttle), crank the starter 'for a bit', to purge fuel vapors. Replace plugs, start motor. Maybe.
2013 WR250R
Old 10-14-2012, 07:36 PM   #70077
neo1piv014
ADV in training
Oddometer: 619
Hit up RideFreak on these forums. He does rides up in UT pretty often from what I understand. He might have some tracks you can follow.
Ride videos
'01 DR650
Old 10-14-2012, 07:41 PM   #70078
Ren20
Finding Touge
Oddometer: 111
Here she is. The virgin!
2001 with 7700 miles.
Ren20 is offline   Reply With Quote
Old 10-14-2012, 07:42 PM   #70079
neo1piv014
ADV in training
Oddometer: 619
She looks good!
Ride videos
'01 DR650
Old 10-14-2012, 07:46 PM   #70080
Ren20
Finding Touge
Oddometer: 111
I have a rm250 1990s Donor bike. Almost complete bike without the cylinder head and seat. Everything else is there. USD forks, bigger rear wheels(19" ??) etc.
I am wondering what kind of parts I could fit onto the dr650. Is it even worth it?
Is it a rm250 by the way? :)
Ren20 screwed with this post 10-14-2012 at 08:52 PM
Times are GMT -7.   It's 10:25 PM.
