Old 10-15-2012, 12:04 AM   #1
indr OP
Oddometer: 501
Battery Charge Q
indr screwed with this post 02-24-2015 at 07:47 AM
indr is offline   Reply With Quote
Old 10-15-2012, 12:38 AM   #2
Sport
Oddometer: 350
Could be toast but I'd have it load tested first. Most places that sell batteries can test it for you for free. If it severely discharges under load and doesn't recover quickly, it's toast.
Sport is offline   Reply With Quote
Old 10-15-2012, 02:04 AM   #3
Tosh Togo
Oddometer: 1,594
What kind of battery is this?.
Tosh Togo is offline   Reply With Quote
Old 10-15-2012, 04:31 AM   #4
buickid
Lets ride!
Oddometer: 310
Leaving a battery alone for 6 months could easily result in it being toast, especially if it wasn't fully topped off before sitting. I try to top off my batteries every couple weeks at a minimum.
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 10-15-2012, 10:42 AM   #5
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,628
Originally Posted by indr View Post
Full disclosure: I tried hooking up hooking up the starter motor (standalone, detached from the bike) directly to the battery just a moment ago before I hooked it up to the charger. There was a loud noise during which I flinched and closed my eyes and found the motor about 4 inches away...
Post 2.....!
http://www.advrider.com/forums/showthread.php?t=832406
Careful using a freshly charged battery to test a starter, doesn't take much of a spark to blow up a freshly charged L/A.Lesson learned a very long time ago.
Have tools, will travel!
H96669 screwed with this post 10-15-2012 at 10:48 AM
Old 10-15-2012, 12:23 PM   #6
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,223
14.4V for fully charged?
12.9V is fully charged. Anything over that means the battery is being actively charged at a high rate.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 10-15-2012, 02:10 PM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,628
Possible just after unplugging the charger.For a few minutes anyway....! Supposed to let them sit for quite a while, as in overnight to let the charge equalize then take a reading.Or put a load on it and wait for the bounce back. Then check against the charge tables for that type of battery, whatever it is.The last is for the ones who like to measure Voltages at 2 decimals.
All out there somewhere. May even be in the C-Tek litterature/owner's manual. Most of it is there:
http://www.batteryfaq.org/
Old 10-15-2012, 02:54 PM   #8
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,258
You are taking the "word" of a charger, without actually trying the battery?
Are you sure this charger is working properly? You're assuming it is, and it might not be. "Rest" the battery as suggested above and check the voltage with a digital volt meter (Harbor Freight gives them away). If it reads low (<12v) you could try a less fancy charger and see what happens. It couldn't hurt.
Really need to know what kind of battery it is (AGM, flooded wet cell). If it is a wet cell, is the electrolyte level correct?
A wet cell battery can be tested with a hydrometer (even the cheap "count the floating balls" version) and that will tell you the state of charge or if you have a weak or dead cell.
With AGM, you can't use a hydrometer, and some form of load testing would need to be done. (Load testing a wet cell is great entertainment, watching the bad cell fizz). Not that I'm their salesman, but HF has a 100amp tester for $25. The 500amp for $60 is overkill for bike batteries, but would let you load test bigger (car/boat) batteries as well.
http://www.harborfreight.com/100-amp...ter-90636.html
We await more info...
HapHazard is offline   Reply With Quote
Old 10-15-2012, 05:30 PM   #9
baloneyskin daddy
bikaholic
Oddometer: 2,102
Why don't you just put the battery in the bike and try it? If it works its good. Make sure to check the charge rate in the bike .
baloneyskin daddy is offline   Reply With Quote
Old 10-15-2012, 07:28 PM   #10
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,628
Harbor Freight....Eh! we are Canadians. Cheap at Canadian Tire and cheap all right I already returned 2 of them.
Funny thing is I was getting abnormaly high voltages out of a battery, did not make sense for that new Odissey. Hum....went inside and got my other exact same meter. Voltages back to normal.
Low battery in the cheap meter was giving me higher voltages on testing.
Can't trust them cheap tools, got to have 2 of them to doublecheck the readings....
Old 10-15-2012, 08:58 PM   #11
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,258
I'm no Thomas Edison, but I've never noticed a difference in the meters - I have a decent but rather low-end Circuitmate and a drawerfull of HF meters I got free with coupons. I'm intrigued (and a little worried). I'll have to do a test on them.
At work they sent some of our people to a troubleshooting class, and they were given some of the saddest tools and meters I'd ever seen - HF meters are like Flukes compared to those things - most of them broke during the class and none lasted more than a few months afterwards.
Old 10-16-2012, 07:10 AM   #12
scapegoat
Pushin forward back
scapegoat's Avatar
Oddometer: 2,881
Every battery charger including the three battery tenders I use take a battery to 14.3 which is considered max voltage. From there its switches back and forth like your seeing. After a charger is unplugged it will come back to 12.6 or 12.8 (which is correct for a 12v battery) sooner than later. the 14.3 is considered what a good charging system will create at full service,below 12.6 after sitting its questionable of its serviceability. Stick a DVM on it while cranking the bike over for several seconds, if it falls below I wanna say 10.5 volts then its pretty much spent.
Reality is merely an illusion, albeit a very persistent one.
scapegoat is offline   Reply With Quote
Old 10-16-2012, 10:51 AM   #13
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,628
That:Yuasa YTX9-BS
Buy a Hydrometer and....safety glasses....rubber gloves....and a big box of baking soda. Keep water hose handy and wear your old clothes just in case.
Trust me on the safety part....I use to fill batteries in my youth, nothing to be complacent about those however harmless they may look to some.
$20.00 meters from CT are more than good enough for what most of us will do with them. Good warranty anyway at CT.... I think they do have a low battery warning, I guess I'll have to read the manual(s) if ever again I get strange readings. Or ride next door and borrow his really good one.
Mind you....I have never counted my meters, I have a few, one permanently with the bike's tools. All good enough for what they are.And one to mount in the dash, very bad things can happen on my bike if attempting to start it with a low battery. Bad as in....very expensive to fix.No letting that "Magic Smoke" escape....
Not much need for them with an Odissey battery altough I have done the tests with the battery left connected untendered for 5-6 weeks. All good....! And much safer to handle.
If, and only if, you go for the cheap(er) CT meter, try the switch in the store, that's what broke on mine twice. One never even worked right out the box, the other one failed early but you can tell if the switch action isn't smooth at first. The other twos.....no problems in 3+ years just have to remember to keep a good battery in there and turn them off after use.
Motors....batteries.....and maybe even meters, nothing should really sit for a long time and yes 6 months is a long time, without some preventive maintenance, much cheaper and lots less aggravating that way.
Old 10-16-2012, 02:00 PM   #14
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,694
If you're going to buy a meter for shop use, spend the bucks and get a Fluke. It'll outlast you and possibly your kids. No need to go nuts and get one cal'd to NIST standards unless you're building a nuclear reactor in your garage.
For travel, I picked up an Extech DM110. Its small - about the size of a smartphone, accurate and easy to use.
Twilight Error is offline   Reply With Quote
Old 10-17-2012, 12:38 PM   #15
gn77b
Oddometer: 147
most likely it's normal.
I have an "intelligent" charger too, manual says once the battery is fully charged it switches to maintenance mode, which is described as light discharging, followed by recharging etc.
this doesn't mean that yours is the same but there's a high probability. as long as it doesn't overcharge or anything, it's most likely ok.
one way to check it is by connecting a multimeter in series and one in parallel and measure current/voltage. normally it should first charge with a constant current equal to rated Ah/10 (for instance if it's 10Ah it should use 1A) or less (mine uses 0.6A since there's no way of knowing the rated Ah) and then switch to constant voltage (current drops exponentially) when a certain voltage is reached. this is the proper way of charging a lead-acid battery. if it's indeed an intelligent charger, chances are it does it this way. what should never happen is to have a voltage across battery higher than ~14.7V. and this figure should be even lower if the charging current is higher than Ah/10.
later edit: looked at the Ctek website, looks like it works just as I described (at the price, it really REALLY should, mine was much cheaper): http://www.ctek.com/Archive/ProductM...S%200.8_EN.pdf
gn77b screwed with this post 10-17-2012 at 01:06 PM
gn77b is offline   Reply With Quote
Times are GMT -7.   It's 01:58 PM.
