Old 10-15-2012, 02:38 AM   #2791
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,233
Originally Posted by NormanH View Post
Like I said earlier in the thread - I installed them with the dimmer, and a switch to the "high beam bypass" lead rather than actually tying into the HBB. I'd intended to do the setup you described, but I haven't changed it out a month or so later. The dimmed setting, I have no good reason to ever turn off when the bike's on, and the brights setting is blinding. So having extra control on a switch for "I really want off-road/off-traffic lights" is very nice.
If I understand correctly, your LEDs go to 100% at high beam only if the switch is on, right? Nice, but my bike has an useless high beam (because of the brightness of the low beam HID) so I think the HBB will work for me.
On a side note, is really a bad idea wire the LEDs from the auxiliary connection in the fusebox? is 10 amp fused and switched but they already power my heated grips. Can I just put a 15 amp fuse?
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 10-15-2012, 05:39 AM   #2792
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,610
Here is my 640A with four ADVmonster lights ... HAve not tested them on the bike yet but I tested the three of them using a portable battery and boy ... they are something !
The whole post is here ...
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is online now   Reply With Quote
Old 10-15-2012, 12:01 PM   #2793
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,035
Originally Posted by sanjoh View Post
Should be right around the corner. You can check the tracking number received in your email.
And you are correct, arrived Saturday and have since installed them. Nice Lights!!. Thank you for the great service and prompt shipping.
Would you say the spot version of your inventory throws a more distant beam than the model 60's ?, If yes , how much further?
pfdskipper is offline   Reply With Quote
Old 10-15-2012, 10:38 PM   #2794
Shaggie
Unseen University
Shaggie's Avatar
Oddometer: 2,622
wow - cant wait to see that in operation!
Shane
"We are not at home to Mr Reasonable" - Sam Vimes
NZ Touring pics:Brass Monkey 2009:Kiwi Sun:Tiki-touring: Daytrips in NZ
Shaggie is offline   Reply With Quote
Old 10-16-2012, 04:55 AM   #2795
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
Should work fine.
WOW! Beautiful setup, that should really make some daylight. A night pic would be great
Thanks for your business. How about a pic? Now for that other SE dude Safari should be going on this week.
No, the Model 30 is down on power compared to the Model 60.
Old 10-17-2012, 12:33 AM   #2796
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,035
Thanks Sanjoh
As requested, KTM SE , 2 Model 60's on a triple clamp mounting plate
Stock light
Model 60's X 2
Old 10-17-2012, 01:06 AM   #2797
gunnabuild1
gunnabuild1's Avatar
Oddometer: 748
Damn thats an impressive pic.
gunnabuild1 is offline   Reply With Quote
Old 10-17-2012, 02:25 AM   #2798
OzRider64
Friggen slow Adventurer.
OzRider64's Avatar
Oddometer: 90
Thumb Repaired Model 44's turned up today
G'day sanjho,
My 44's turned up today in Oz, quick turn around.
Have tested them out and they work fine. Will re-install them on the GS this weekend.
Just for my interest and others what was the problem with them ?.
Is there something I can do to alleviate this problem in the future or will this be a regular replacement item.
Great service.
Simon.
Tassie, where two heads are better than one.
2010 R1200GS
OzRider64 is offline   Reply With Quote
Old 10-17-2012, 12:10 PM   #2799
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
Stock light
Model 60's X 2
Looks like more night riding in your future
Keep em away from U know who, they might turn up missing
Old 10-17-2012, 12:24 PM   #2800
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
Originally Posted by OzRider64 View Post
G'day sanjho,
Great service.
Simon.
Hi Simon,
Glad to hear the lights made it back to you. The lights had been exposed to high voltage. Traces ie circuits on the driver boards were burned. Many of the cheap HID aftermarket lights can cause this, otherwise if your charging system is in good shape, there should be no issues.
Old 10-17-2012, 02:20 PM   #2801
SV_Dwayne
SV_Dwayne's Avatar
Oddometer: 302
Hi Simon,
Hey John,
Do you know of a fix or things to check when using an HID kit? I'm using a VVME kit with slim ballasts, and have been trying to figure out why the AdMore kit in my Givi 52 is acting funky, sounds like that could be the problem. Would be nice to determine whether the HID kit is causing it before I buy LED aux lights to replace my halogens.
Kicking ass seems to be THE ONLY solution to life's problems. Kicking ass is the first, second and third option. Plan B and C are also kicking ass.
SV_Dwayne is offline   Reply With Quote
Old 10-17-2012, 05:28 PM   #2802
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
Originally Posted by SV_Dwayne View Post
Hey John,
Best fix I found is to remove them from my bike.
Old 10-18-2012, 05:37 PM   #2803
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,126
Damn it's getting dark early! Just ordered a pair of 60 watters for my WR250R. Looking forward to "seeing the light".
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 10-18-2012, 05:47 PM   #2804
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
Thanks for your business!
Just an FYI, they are model 60s, NOT 60 watts a pair will pull 56 watts on full power.
Old 10-19-2012, 06:53 AM   #2805
Return to Riding
Oddometer: 1
Great driving lights!
I got the Model 30 LED spot driving lights from Sanjoh and I received them on the third day. I polished the stainless steel brackets so they look really cool. I installed them low where there used to be reflectors. Easy install because my bike (Yamaha Raider...gasp) has an auxiliary driving light switch already wired in the headlight bucket. I aimed the lights so that I can leave them on all the time but they still outshine my Ultrastar bulb low beam. I'm very happy.
Here are some shots of the lights:
Mounted:
http://i784.photobucket.com/albums/y...30LEDFront.jpg
http://i784.photobucket.com/albums/y...LEDDriving.jpg
Polished Brackets:
http://i784.photobucket.com/albums/y...ountedRear.jpg
http://i784.photobucket.com/albums/y...untedFront.jpg
Comparing low beams, low plus spots, high plus spots:
http://i784.photobucket.com/albums/y...otLowBeams.jpg
http://i784.photobucket.com/albums/y...usLEDSpots.jpg
http://i784.photobucket.com/albums/y...sLEDSpotsC.jpg
What someone coming might see pulling out from a side street:
http://i784.photobucket.com/albums/y...adePullout.jpg
http://i784.photobucket.com/albums/y...PulloutLED.jpg
Return to Riding is offline   Reply With Quote
Times are GMT -7.   It's 02:12 AM.
