Old 10-12-2012, 10:13 PM   #24541
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,245
Originally Posted by xymotic View Post
Well, On the one hand, I now have tons of free time. OTOH, I have no money seing as how I got fired today... so, um dunno!
Fired? That word gives off really bad vibs...
Maybe hitch a ride again.
Plenty of trees to hang a hammock
___________________________________________
So much riding-so little time
Xcuvator screwed with this post 10-12-2012 at 10:19 PM
Xcuvator is offline   Reply With Quote
Old 10-15-2012, 11:37 AM   #24542
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,676
Send a message via MSN to mountain eagle
Hmm, I've dumped this post in a few places now but I'll throw it here too in case other 610 riders are intersected and haven't seen it.
An idea taken from PowerCell in this ADV post though I had done something similar with TE610 tapping and threading the EFI plate. I've had two of the KTM/Husky style petcocks fail now, and I hate not having an easy quick release that stops the fuel flow. I mean I really hate having to deal with gas pouring out, so while this is overkill it's also damn convenient.
I took off one petcock and took some measurements and drew this up. Everything is in mm.
I might adjust the 34.5mm to be a touch wider, and I did adjust the o-ring depth to 1.2mm. The test prototype with the stock o-ring and a plug has been holding fuel just fine.
The part I ordered to work for this was from quick couplings LCD10004V - 1/4 NPT Valved Coupling Body w/ Viton seal and the matching part quick coupling LCD23004V - 1/4 Hose Barb Valved Elbow Coupling Insert w/Viton seals and they had the best prices I found anywhere. To give you an idea, fast by feracci sells the same parts for $29 each......
These are what I came up with using some aluminum and borrowing a friends older mill with homebrew DRO, and small lathe.
The parts
Putting one together, wouldn't want to do it while on the tank so I lugged it down with drywall screws to the benchtop.
Installed right side.
Installed left side.
In either case if the fuel like seems like it is too close to the header I'll get some Fuel Line Heat Shield
And since I was doing this with the 610 I went ahead and did the same thing for the crossovers on the 950SE too.
mountain eagle
08'Husky TE610 = everything a KLR want's to be ,
07'KTM950SE,
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 10-15-2012, 02:34 PM   #24543
1 lunger
1 lunger's Avatar
Oddometer: 805
The parts
Looks really nice! This will do away with the whole bottom plate that bolts to the bottom of the tank?
1 lunger screwed with this post 10-15-2012 at 04:28 PM
1 lunger is offline   Reply With Quote
Old 10-15-2012, 03:03 PM   #24544
xymotic
xymotic's Avatar
Oddometer: 7,755
Originally Posted by 1 lunger View Post
Looks really nice! This will do away with the whole bottom plate tha bolt to the bottom of the tank?
I'm thinking those have to be for carbed bikes...
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 10-15-2012, 04:31 PM   #24545
1 lunger
1 lunger's Avatar
Oddometer: 805
I didn't look at it well enough, he's replacing the petcocks on each side, not the pump mount.
Old 10-15-2012, 06:50 PM   #24546
Rattletrap
When in doubt-Gas it
Rattletrap's Avatar
Oddometer: 302
Yep, on the crossover line, looks like.
Rattletrap is offline   Reply With Quote
Old 10-15-2012, 07:12 PM   #24547
1 lunger
1 lunger's Avatar
Oddometer: 805
I never had any trouble with those and I've had my tank off more times than I'd like.
Old 10-15-2012, 08:01 PM   #24548
mountain eagle
terrorist
Oddometer: 2,676
Well, actually.................
I pulled the plastic 90's. I just know I would manage to break those at some point playing in the rocks. The parts were a 3/8" NPT quick release coupling with a 3/8" barbed 90. You pull out the plastic 90 and tap it out. It was a touch of a scary prospect really. But I did it a couple of years ago and haven't had any trouble with it. Flow volume seems fine.
The motivation for the new work was for the 950SE mostly. But the 610 crossover petcock failed and I didn't feel like messing with it when I had the other system ready to go...... that one uses 1/4" fittings. I might change the left one out to have a street 90 as to allow better clearance to the header pipe.
I think this would work for any bike that has that style of petcock.
The gallery of pictures are here.
mountain eagle
07'KTM950SE,
my smugmug gallery
mountain eagle screwed with this post 10-15-2012 at 08:10 PM
Old 10-15-2012, 11:04 PM   #24549
xymotic
xymotic's Avatar
Oddometer: 7,755
Ahhhh
Albert Einstein
6:10 to Yuma
Old 10-19-2012, 01:53 PM   #24550
KIK ROX
KIK ROX's Avatar
Oddometer: 93
I bent my bar clamps while riding the CDT and need to get replacements. Should I get factory parts or are there universal aftermarket ones that will work for less $$? I will be using them in conjunciton with my ROX risers. Thanks
KIK ROX is offline   Reply With Quote
Old 10-19-2012, 02:12 PM   #24551
BrandonR
BrandonR's Avatar
Oddometer: 820
Did you actually bend the castings, or just the bolts that run through them? You might get off cheap by just replacing the bolts.
Brandon Reed
2009 Husqvarna TE610
BrandonR is offline   Reply With Quote
Old 10-19-2012, 11:45 PM   #24552
KevinMTB
KevinMTB's Avatar
Oddometer: 108
Bar clamps
KIK ROX,
I have an OEM bar clamp that I don't need. If you want it, it's yours. Just pay for shipping (coming from Hawaii).
Aloha,
KevinMTB
KevinMTB is offline   Reply With Quote
Old 10-23-2012, 07:56 PM   #24553
Rattletrap
Rattletrap's Avatar
Oddometer: 302
Maybe this has been discussed before, but after reading up on the new Terra, are we doomed to go the route of the XR650R? I keep up with the Terra thread and no, its not a replacement for the TE line, so where does that leave us? In my opinion the TE's and the XR were THE best dual sports EVER. The Terra is too roadie for me, so where do I go for a bike when it's time to replace the 610? Where's MY new bike? What the f#$% am I gonna do? Who's going to cater to my tastes? No where close to replacing mine, new bike envy maybe? KTM? Just somewhat depressed about it right now, maybe I just need sleep.
Old 10-24-2012, 02:01 AM   #24554
southy
southy's Avatar
Oddometer: 117
Rattletrap, I here what you saying. I think the KTM690 is now the last bike of its kind but the price is way beyond what I am willing to pay for one. Looks like my 610 will be with me for a while to come.
Before the TR650 owners get on and defend its integrity I am sure the TR is a great bike but it is way to road orientated for my riding needs.
Current rides - Husqvarna TE610IE and Suzuki RMX250.
southy is offline   Reply With Quote
Old 10-24-2012, 04:52 AM   #24555
mrkartoom
Lurker Extraordinaire
mrkartoom's Avatar
Oddometer: 827
My thoughts exactly on Husky's shift in emphasis with the Terra. I just don't see it being as dirt worthy as the 610. I also agree the 690 may now be best option. I actually had a down payment on the first 690s coming in, but pulled it after test riding the 610. If I wanted street oriented I would have stuck with the 690. It's sad our options are getting fewer. Luckily my 610 is going strong and I have no plans to get rid of it.
"gotta have more cowbell" C. Walken
"I
spent 90% of my money on woman and drink. The rest I wasted." G. Best
'08 Husqvarna TE610, '11 Gas Gas EC300, '03 Beta Rev3 250
Husky TE/SM-610 Thread Index
mrkartoom is offline   Reply With Quote
Times are GMT -7.   It's 07:27 AM.
