Old 12-27-2011, 03:17 PM   #1
Uncle Pollo OP
Von Hochstaden's son
Uncle Pollo's Avatar
Oddometer: 44,982
Erratic red charging light behavior - 86 r80
Off idle - flickering red.
Sometimes cuts off 1200ish
sometimes higher.
Brush pack?
mikuni vm32-33 both sides :\ 5000 feet altitude/
140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide
35 mpg around town riding like a asno
Uncle Pollo is offline   Reply With Quote
Old 12-27-2011, 03:35 PM   #2
Quasi1960
Quasi1960's Avatar
Oddometer: 405
sometimes higher.
Brush pack?
Probably.
R100 of indeterminate history and model.
Quasi1960 is offline   Reply With Quote
Old 12-27-2011, 04:05 PM   #3
Uncle Pollo OP
Oddometer: 44,982
Originally Posted by Quasi1960 View Post
Probably.
If not; what else?
Old 12-27-2011, 11:52 PM   #4
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,356
Perhaps nothing is wrong. If it goes off and stays off, I wouldn't worry about it. Some of the differences are state of battery charge and temperature. The voltage regulator regulates differently when hot than cold.
If it goes out, and stays out, by 1200 RPM, there's nothing to worry about.
Old 12-28-2011, 05:07 AM   #5
Uncle Pollo OP
Oddometer: 44,982
It's been -7 celcious consistently.
Old 12-28-2011, 06:04 AM   #6
eepeqez
eepeqez's Avatar
Oddometer: 2,031
sometimes higher.
Brush pack?
It's not like its a major voyage of discovery to get far enough in to see what they're like!
Flickering does suggest dodgy continuity which worn brushes will certainly provide.
Other possibilities include:
Field (rotor) or stator winding faults, but these tend to go bad and stay bad, not flicker.
Voltage regulator failing - but it's an electronic regulator, not mechanical, so they're usually pretty reliable.
Loose connection anywhere in the alternator wiring, especially voltage regulator, warning lamp, brushes (ah, we'r back where we started).
Loose battery terminal.
eepeqez is offline   Reply With Quote
Old 12-28-2011, 08:56 AM   #7
Speedzter1969
Ride, wrench, repair
Speedzter1969's Avatar
Oddometer: 24
My experience has been this:
One night, whilst going to meet a friend for a ride down to NYC, the GEN light started to flicker. The diode board had been replaced a year prior, but this was different. Get to his house, pull off the front cover and checked brushes, connections, etc. The voltage also dropped to about 12.5 when the light was flickering. We go off on down to NY, and no problems. Next day same thing. I replaced the brushes, which were fine, and didn't help. Swapped out stator from other bike, as well as voltage regulator. Last thing was the rotor, ordered up a new one, and that was it.
I hear that once rotors "go", they "go". Mine was intermittent, so no one believed that was it. My gut told me it was.
I now have a pretty much new electrical system now that will probably last another 20 years.
When the diode board went, the GEN light glowed dimly at night. I am becoming well-versed in these electrical gremlins. Seems all my bikes have had them at one point or another.
Good luck!
"You live more in five minutes on a bike like this going flat out than some people live in a lifetime." - World's Fastest Indian
Speedzter1969 is offline   Reply With Quote
Old 12-28-2011, 09:28 PM   #8
Uncle Pollo OP
Oddometer: 44,982
Rotor ... mmhm .... where the hell it is?
Old 12-28-2011, 10:26 PM   #9
robtg
Oddometer: 359
Ask Newt.
robtg is online now   Reply With Quote
Old 12-28-2011, 10:38 PM   #10
Uncle Pollo OP
Oddometer: 44,982
Originally Posted by robtg View Post
Ask Newt.
Aw ... I will change my avatar and signature soon.
It's a prank about the least likely and able being my favorite.
Old 12-29-2011, 01:53 AM   #11
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,966
Drink more beer and close one eye:) Your probably fine.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
bmweuro is offline   Reply With Quote
Old 12-29-2011, 07:42 AM   #12
bereahorn
Oddometer: 1,054
bereahorn is offline   Reply With Quote
Old 10-15-2012, 08:45 PM   #13
Uncle Pollo OP
Oddometer: 44,982
It was the brushes
Times are GMT -7.   It's 03:08 PM.
