10-14-2012, 11:35 PM
#2791 |
Oddometer: 4
Like I said earlier in the thread - I installed them with the dimmer, and a switch to the "high beam bypass" lead rather than actually tying into the HBB. I'd intended to do the setup you described, but I haven't changed it out a month or so later. The dimmed setting, I have no good reason to ever turn off when the bike's on, and the brights setting is blinding. So having extra control on a switch for "I really want off-road/off-traffic lights" is very nice.
10-15-2012, 01:38 AM
#2792 | |
Oddometer: 795
On a side note, is really a bad idea wire the LEDs from the auxiliary connection in the fusebox? is 10 amp fused and switched but they already power my heated grips. Can I just put a 15 amp fuse?
KTM 990 Adv |
10-15-2012, 04:39 AM
#2793 |
Oddometer: 439
Here is my 640A with four ADVmonster lights ... HAve not tested them on the bike yet but I tested the three of them using a portable battery and boy ... they are something !
The whole post is here ... ![]() ![]() ![]() ![]()
Work like you don't need the money Live like there's no tomorrow ... |
10-15-2012, 11:01 AM
#2794 | |
Westside Trash
Oddometer: 719
Would you say the spot version of your inventory throws a more distant beam than the model 60's ?, If yes , how much further? |
10-15-2012, 09:38 PM
#2795 |
Unseen University
wow - cant wait to see that in operation!
Shane S-43.514872 E172.59602 "We are not at home to Mr Reasonable" - Sam Vimes Adieu Davo, you're on the Far Ride now - missing you already mate NZ Touring pics : Brass Monkey 2009 : Kiwi Sun : Totaranui (no MC) |
10-16-2012, 03:55 AM
#2796 | |||
Purveyor of Light
Oddometer: 3,667
![]() Quote:
No, the Model 30 is down on power compared to the Model 60.
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
10-16-2012, 11:33 PM
#2797 |
Westside Trash
Oddometer: 719
Thanks Sanjoh
As requested, KTM SE , 2 Model 60's on a triple clamp mounting plate
![]() Stock light ![]() Model 60's X 2
10-17-2012, 12:06 AM
#2798 |
Oddometer: 362
Damn thats an impressive pic.
10-17-2012, 01:25 AM
#2799 |
Friggen slow Adventurer.
Oddometer: 86
Repaired Model 44's turned up today
G'day sanjho,
My 44's turned up today in Oz, quick turn around. Have tested them out and they work fine. Will re-install them on the GS this weekend. Just for my interest and others what was the problem with them ?. Is there something I can do to alleviate this problem in the future or will this be a regular replacement item. Great service. Simon.
Tassie, where two heads are better than one. 2010 R1200GS
10-17-2012, 11:10 AM
#2800 | |
Purveyor of Light
Oddometer: 3,667
![]() Keep em away from U know who, they might turn up missing
10-17-2012, 11:24 AM
#2801 | |
Purveyor of Light
Oddometer: 3,667
Glad to hear the lights made it back to you. The lights had been exposed to high voltage. Traces ie circuits on the driver boards were burned. Many of the cheap HID aftermarket lights can cause this, otherwise if your charging system is in good shape, there should be no issues.
10-17-2012, 01:20 PM
#2802 | |
Oddometer: 225
Do you know of a fix or things to check when using an HID kit? I'm using a VVME kit with slim ballasts, and have been trying to figure out why the AdMore kit in my Givi 52 is acting funky, sounds like that could be the problem. Would be nice to determine whether the HID kit is causing it before I buy LED aux lights to replace my halogens.
Kicking ass seems to be THE ONLY solution to life's problems. Kicking ass is the first, second and third option. Plan B and C are also kicking ass. |
10-17-2012, 04:28 PM
#2803 | |
Purveyor of Light
Oddometer: 3,667
10-18-2012, 04:37 PM
#2804 |
Oddometer: 1,091
Damn it's getting dark early! Just ordered a pair of 60 watters for my WR250R. Looking forward to "seeing the light".
2011 WR250R 2009 KLR650 2004 KTM 450 EXC 2000 R1150GS "The older I get, the faster I was" |
10-18-2012, 04:47 PM
#2805 | |
Purveyor of Light
Oddometer: 3,667
Just an FYI, they are model 60s, NOT 60 watts
