10-15-2012, 07:50 PM
#6001 |
lost in the 690 mega
Oddometer: 316
I've been running a similar setup (purchased from bobzilla) for several thousand miles now and aside from the hassle of removing my tankbag to get under the seat (now just running e-12 saddlebags), it has been just what the Dr ordered! Holds almost exactly 1.25g. I don't see myself getting Rally Raid or Safari tanks until my buddies all have more range than me. |
10-15-2012, 08:37 PM
#6002 |
Dirty Old Man
Oddometer: 774
![]() ![]() does work well
Ride the DEZ 05 FE 550 Husaberg plated 09 KTM 690 |
10-15-2012, 10:14 PM
#6003 |
Oddometer: 528
![]() I think Bob used his for smuggling moonshine....his 690 never went far enough to run out of gas Once upon a time and after some semi-successful wrenching, with some expert help.... ![]() ![]() Bob was happy to hit the dez for some more.... Only to be towed 50 miles in silt and sand.... ![]() It is enough to make a guy want to resort to demon liquor.... ![]() ![]()
Ged Schwartz Kamloops , BC '96 GS 1100 '04 450 EXC '09 690 EXC Baja '05 Baja 06/07 Baja 08/09 BC Alpine Single Track |
10-16-2012, 03:05 PM
#6005 |
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 170
Would a bearing puller and slide hammer not do the trick?
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen) 2008 Yamaha YZ450, 2002 Yamaha YZ426 www.bruneibikers.com www.airborneriders.com |
10-16-2012, 03:48 PM
#6006 |
Dirty Old Man
Oddometer: 774
what I used when I changed my bearings.
10-16-2012, 04:28 PM
#6007 |
Oddometer: 74
10-16-2012, 05:58 PM
#6008 |
Oddometer: 135
No Start
Posted a few pages back on my woes, and they have gotten worse...this is just me venting, more or less
![]() Took my KTM to a Non-KTM dealer to get 15K inspection done (late), thought I'd give em a try and save me time Vavles I were told were good, rode home (New chain, sprocket) and it hesitated at intersections, then stalled when I got home for the first time ever, owned since new. Test rode later, same thing. Called shop and they picked it up for me to give it a look. (They forgot to re-install the front screw holding the airbox lid, but it was secure to the boot) I was gonna do the 15 min reset (never did it before) but could not get it to idle for more than 8 minutes Shop picked up bike, and couldn't find any error, other than at low idle same as me so I said bring her back, I'll put a few miles on it like it is then, benefit of the doubt maybe it'll work itself out, or something will break definatively, and that'll make it easier to troubleshoot ![]() Bike was dropped off while I was at work, went to start it the next day, and NO START, hasn't ran since. They will be picking it up again this week, and most likely trucking it to the nearest KTM dealer (who only deals with smaller bore KTM's, but will take a look at it)( So, to try and make my life simpler, end result uhh, not so much! ![]() I've found 3 wires that had the insulation worn through to the point I can see copper. Wires not looking damaged though, so I taped and reset them in proper places. Pump I'm sure is fine. It sounds the same as always, and is sending fuel properly. No spark methinks somehow. Of course I DON'T HAVE THE PROPER FRICKEN PLUG WRENCH. A problem I will soon rectify. Always assumed one of the many I have would fit. Plug wire is good. May have just fouled the beast? New plug, will try a new battery as this one is crankin soft, but only as a result of trying to start in on and off the last couple days. Have a charger on it, but it is the original battery (2010 690 R) Anywho....not intending to be negative, just posting so that when it does get fixed, by my hand or the next, I'll post what it was so it may help someone, sometime. Have fun riden y'all., I'm not... Bike is awesome, and has never skipped a beat prior to this. That's the gamble of gettting someones elses hands in there, who knows what happened at the shop. A simple remap may be all it needs. Just gotta find someone that can first! Or invest, hmmm.... Not blaming the local dealer either, they seem to be good folk, and part of this experiment was to support the local economy, and hope to find a good shop in the process. Ride safe, MFS |
10-16-2012, 06:29 PM
#6009 |
ya mo be there
Oddometer: 398
yeah thx for the advice WUNDERKINDER, i'll use a blunt wood drift or something....it's not a big deal now that i know it is removable.
ktm 450xcw, ktm 690 enduro r, kawasaki versys 650 "In Europe we ride about eight-tenths. If we really have to, we might ride nine-tenths. The crazy ones ride ten-tenths—but not for very long. In America, they seem to ride eleven-tenths all the time."-- Phil Read |
10-16-2012, 09:02 PM
#6010 |
Oddometer: 1,671
What are the downsides to the air intake being routed like that-affect performance? Watercrossing concerns? What else had to be moved? The stealth gallonage is very intriguing.
Qui Desiderant Pacem Preparate Bellum |
10-17-2012, 12:16 AM
#6011 |
Wanderer
Oddometer: 816
I had 20% less fuel mileage when I had the Unifilter vs the stock air box. The performance was quite nice though. Not as loud as the Twinair filter on the front of the air box.
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting. RTW Ride Report --> http://advrider.com/forums/showthread.php?t=781893 Blog ------------------> http://rtwwithnoah.blogspot.com/ Facebook------------> https://www.facebook.com/RtwWithNoah Open-Exporers----->A collection of travel blogs |
10-17-2012, 03:51 AM
#6012 | |
Dirty_Sanchez
Oddometer: 2,096
The UNI double pod inside of the stock box is the route I decided to take at your suggestion. Good suggestion. Dirty
No, really, the mustache means I love you. '09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167 |
10-17-2012, 09:13 AM
#6013 | |
Wanderer
Oddometer: 816
10-17-2012, 09:30 AM
#6014 |
Torque Stick
Oddometer: 3,856
I ran the Uni foam filter with the stock box/ snorkel, and fmf Q4 pipe. No remap was necessary, just the 15 min reset...
10-17-2012, 10:18 AM
#6015 |
Wanderer
Oddometer: 816
This was the exact setup on my old bike. The new one is the same but it has an LV pipe but I am now running Frankenstein map I put together. A touch richer on the top end but sip sip sip when you are cruising. seems to work out nicely.
