10-18-2012, 06:58 AM
#70336 | ||
Road Less Traveled
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 457
Edit: I just noticed that the link in my original post is now broken. I've saved a copy of the PDF so I have a copy the whole report if needed. It can also be accessed in the archives. http://web.archive.org/web/201106011...ki-battery.pdf Quote:
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300 Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E 1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale) |
10-18-2012, 11:18 AM
#70337 | |
Oddometer: 2,551
![]() http://www.advrider.com/forums/showp...2&postcount=32 While you're doing that, you could include your earlier info about the clear turn signal lenses with amber bulbs. One of the first mods I did to my DR was to replace the turn sigs with some that have clear lenses/amber bulbs. Problem is they're brittle, break easily, and are no longer available. ![]() Thanks for the good stuff.
10-18-2012, 12:48 PM
#70338 | |
Oddometer: 6,505
10-18-2012, 01:00 PM
#70339 | |
Oddometer: 13
I'm in the process of having mine rebuilt right now. I was having some issues with it falling out of 2nd gear so I decided to just bite the bullet. From the reading I did prior to getting the work done, it seems in 06 or 07 suzuki released a new 3rd gear that replaced the old one. I'm assuming it was done in an effort to address the issues with the gear blowing up. I decided to go a head and replace my gear with the newest one instead of buying the billet unit. Hopefully I don't regret it, but I couldn't justify replacing a $50 dollar part with one that costs $500 when the stock one may or may not blow up at some point. Obviously, If I trash the engine in the bike due to a 3rd gear failure I'll be kicking myself. I may consider doing the nice 3rd gear when I put the 790 kit in the bike as a little bit of extra insurance |
10-18-2012, 01:39 PM
#70340 |
Cogent Dynamics Inc
Oddometer: 429
Cogent Dynamics is still looking to purchase or barter for a good set of DR650 forks...
![]() Thanks! |
10-18-2012, 02:36 PM
#70341 |
KJ4WMZ
New to me '04 model
Totally stock '04 DR with just over 6000 miles. A bit rough cosmetically but will be the base for an ADV style bike. Let the farkeling begin!
Sent via morse code ..-. -.-- ..-. ..-. |
10-18-2012, 02:47 PM
#70342 |
ADV in training
Oddometer: 610
If that's "rough," then my bike is laying beaten in a corner weeping. Nice buy!
_________________________ Ride videos '01 DR650 "The impossible often has a kind of integrity which the merely improbable lacks." |
10-18-2012, 02:52 PM
#70343 |
KJ4WMZ
Thanks! A camera can make most anyone look good. It should clean up OK though.
10-18-2012, 02:54 PM
#70344 |
ADV in training
Oddometer: 610
Any mods planned in the near future for it? I didn't see anything looking broken on it, so at least you might not have to make your first farkles repairs.
10-18-2012, 03:00 PM
#70345 |
KJ4WMZ
Actually, the magneto cover has a repair where the shifter must have punched through, so case savers might be in order. I might work on the front forks, I had to do a panic stop on the way home and thought I was going to go over the bars! Plans are to put an Acerbis tank and an aftermarket seat or foam and cover. Might try to Spencerize the seat, he does a pretty good job. The seat seems wide enough, certainly much wider than the one on my DRZ. Lowered pegs, better handlebar and hand protection, maybe a Vapor bike computer....the list is endless. I often wonder what it would cost to get one of everything on the ProCycle website for a DR...
![]() Oh, the salesman said it was only ridden to church on Sundays by a little old lady!
10-18-2012, 05:13 PM
#70346 | ||
Oddometer: 1,168
there is also no info confirming that the "new" suzuki 3rd gear was anything more than a vendor change. there's no evidence of its being strengthened in any way, and there's plenty of "post-'06-'07" dr650's that have had 3rd gear grenade on them. that said, the "plenty" i am referencing is something on the order of 1 in a 1000, so i am really not sure it's a potential problem that is worth addressing. there is no way i would be paying $600 for a pair of matched third gears, when you can get a factory pair for a fraction of that price. especially since there is no data that it's even a fix for the problem. if i were into my engine for any sort of major refurb, i would have my stock 3rd gears professionally checked/magnaflux'd, to be sure they're ok and then have the entire gearset cryo'd, replacing the existing 3rd gearset w/factory parts if there were evidence of wear on them. (whatever you do, if you are replacing 3rd gear, be sure to buy the pair, not yust the one gear, if you go for replacement w/stock parts.) ymmv, doug s. doug s. screwed with this post 10-18-2012 at 05:15 PM Reason: clarification |
10-18-2012, 05:30 PM
#70347 |
Butler Maps
Oddometer: 14,428
Interesting comment about the Deka being actually higher CCA than the rated @ 120. i've always had nothing to top service and life out of Deka and will continue to keep buy $60 http://www.tristatebattery.com/produ...roducts_id=973 for my DR.
After 4 yrs i just pay another $60 and have peace of mind for another 4yrs. Easy as pie. Saving a few lbs on a Shorai when used in a heavy DR seemed more like a waste of $ IMO, but i know alot of guys love em. Sure on a light dirtbike where every lbs counts it makes sense, but the DR is heavy and not a dirtbike. Crazy how Yuasa is getting those larger batteries in the same size and still using AGM. If you look at Deka sizing is does go up and what i'd expect. http://www.etx9.com/ http://www.etx12.com/ http://www.etx14.com/ In the end, my $ is on a new Deka and 60 bones too. ------------------------------------------------------------------ Originally Posted by GaThumper View Post There are some more powerful batteries that will fit our battery box. I haven't tried one yet, but when my Deka battery needs replacing again (in a few years!) I might try one of the "bigger" batterys. Here's some info I picked up when I was looking at replacing the battery on my '09. I'm using a Deka battery made by East Penn Mfg. Their replacement for the standard Yuasa YTX9-BS is the ETX9. I haven't tried it myself but I have found out that there are three Yuasa Batteries that are almost exactly the same physical size, but more Amp Hours/Cold Cranking Amps. I was really tempted to try one in my '09 when I replaced the battery this spring, but ended up going with the Deka. The stock YTX9-BS-BS is 150x87x105 mm and 8AH/120CCA The YTX-12A-BS is an AGM battery with the same dimensions and 9.5AH/175CCA The YTZ 12S is an AGM battery that is 150x87x110 (5mm taller) and 11AH/210CCA The YTZ 14S is an AGM battery that is also 150x87x110 and packs 11.2AH and 230CCA I went to pick up 2 of the YTZ14S for me and my riding buddy and when tested one of the only two in stock had a bad cell. That made me uneasy, so I had him bring out a Deka ETX9 and test it and it exceeded the CCA of the YTZ14S so I bought the American made Dekka this time. (the salesperson told me Deka is known to be conservative in rating their batteries) I'd still like to do a side by side comparison of the YTZ battery and see if it spins the DR any better, but I've always had good service from the Dekka, so I'm not sure if I'll switch next time or not. It sure looks like the YTZ14S might be an interesting replacement for the YTX9. It;s only 3/16" taller (5mm) and with a couple of washers under the battery retainer it apparantly fits under the seat just fine. However, if you are really concerned about weight, it does weigh about 2 pounds more than the stocker. The only concern I might have is that there are probably more plates in the higher capacity battary in the same (relatively) size package. I've read before that this could cause a problem due to the plates being closer together. Having said all that, I'm REALLY satisfied with the Deka ETX9. Also made in the U.S. of A. if that matters to you. I can't take credit for this. Here's the article I found this info in and a big THANK YOU to "Scott", wherever you are! http://www.cs.clemson.edu/~westall/8...ki-battery.pdf
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
10-18-2012, 05:43 PM
#70348 |
Oddometer: 650
its the same, still did it after I got home from a 65 mile ride.
1996 Kawasaki KZ1000P (currently being rebuilt) World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements! Earn extra income, become a distributor or just purchase: Advocare products-www.advocare.com/12084065 |
10-18-2012, 05:45 PM
#70349 | |
Oddometer: 650
10-18-2012, 05:47 PM
#70350 | |
Oddometer: 650
I need to post a pic but don't have a smugmug or anything.
