Old 10-15-2012, 11:07 AM   #1
WitchKing OP
WitchKing's Avatar
Oddometer: 56
I got spark! Once...
The last couple months I've been trying to get my 1976 Honda MT125 to spark. I has a new coil, new spark plugs, and I set the gap to factory spec. No spark. But then, I widened the gap, and it sparked once and I haven't been able make it spark again. The spark was blue.
Sure it's quiet, for a diesel. But that's like being well-behaved... for a murderer.
-Jeremy Clarkson
WitchKing is offline   Reply With Quote
Old 10-15-2012, 11:09 AM   #2
Reino
Reino's Avatar
Oddometer: 212
It may be your cdi.
"eliminated the impossible, whatever remains, however improbable, must be the truth"
Current bikes 2006 250sx and 1983 tt600
"Nothing makes me smile more than the muscles in my face." - Hendrik Moller
Similar project in the works http://www.youtube.com/watch?v=Y91Jms6MyCY.
Reino is offline   Reply With Quote
Old 10-15-2012, 02:42 PM   #3
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,256
Originally Posted by Reino View Post
It may be your cdi.
Yes it could be, except for the fact that the bike is a old school coil, points, & condenser type ignition and it doesn't have a CDI. Been trying to help this guy on his other thread about trying to get this bike running but he's not answering questions.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 10-17-2012, 08:19 AM   #4
Reino
Reino's Avatar
Oddometer: 212
I was actually doubting my post, I was not actually sure if the bike had a cdi or not. Maybe someday he will respond, hopefully before the world ends .
Old 10-17-2012, 08:09 PM   #5
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,256
He responded in a so, so way, but if you look at his profile you'll see that he's 16 years old, so we need to cut the kid some slack for even trying on his own.
Old 10-18-2012, 01:49 PM   #6
Reino
Reino's Avatar
Oddometer: 212
Reminds me of myself when i first started making threads, o well he will start responding quickly when he finds the subscribe button.
Old 10-19-2012, 04:21 AM   #7
Nomadmax
Oddometer: 68
This isn't correct for a 1976 Suzuki GT250. It has points, condenser and CDI.
If loud pipes save lives, how come so many people that have em' crash?
Nomadmax is offline   Reply With Quote
Old 10-19-2012, 03:21 PM   #8
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,256
Perhaps that is true for a slowzuki but he has a HONDA for crying out loud, You could tell us what a 76 Ford pickup uses too and it would be about as much help.
Strong Bad screwed with this post 10-19-2012 at 03:29 PM Reason: grumble grumble WTF suzuki grumble grumble
Old 10-19-2012, 03:51 PM   #9
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,371
made my day
JeffS77 is offline   Reply With Quote
Old 10-20-2012, 12:39 AM   #10
Reino
Reino's Avatar
Oddometer: 212
Originally Posted by strong bad View Post
perhaps that is true for a slowzuki but he has a honda for crying out loud, you could tell us what a 76 ford pickup uses too and it would be about as much help.
lol
Old 10-20-2012, 04:54 AM   #11
anotherguy
anotherguy's Avatar
Oddometer: 6,381
Here. Read and follow these instructions. BTW magnetos require clean and square point faces to deliver max spark.
Access to breaker point inspection and timing adjustment is provided by removing small cover on left side engine cover. Ignition should occur, breaker points just open, as "F" mark on flywheel aligns with timing mark (TM-Breaker points should just open as "F" mark on flywheel aligns with timing mark (TM). Timing ts adjusted by varying breaker point gap within recommended range of 0.3-0.4Mfyi.). Timing is adjusted by varying breaker point gap. Normal breaker point gap, with timing properly set, is 0.3-0.4MM (0.012-0.016 inch). Breaker points should be renewed if proper timing is not possible within range of 0.2-0.6MM (0.008-0.024 inch). Flywheel must be removed to renew breaker points. Flywheel retaining bolt should be torqued to 1.8-2.3 kg-m (13-16.6ft.-lbs.). High tension ignition coil and ignition
condenser are frame mounted beneath fuel tank. Alternator current is converted to DC by a silicon rectifier and used for battery charging and indicator lights. A 6V-6AH battery and a 10 A fuse are used in the system.
you don't see luggage racks on a hearse..........act accordingly
Old 10-20-2012, 12:19 PM   #12
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,267
i wonder what would happen if you changed the condenser. hmm........................
current bikes
stainlesscycle is offline   Reply With Quote
Old 10-25-2012, 06:34 PM   #13
WitchKing OP
WitchKing's Avatar
Oddometer: 56
First of all
Question 1. How important is it that the flywheel is properly torqued? I don't mind torqueing(?) it, but would that prevent spark?
Question 2. If the rectifier is bad, would that prevent spark? And where is it?
Question 3. I have been adjusting breaker gap by loosening the screw on the points, and gently tapping the assembly in the desired direction, is that right?
Question 4. That description pretty much covers the whole ignition system right?
I apologize for the newbishness, it's a common symptom of being a newb.
Question 5. I see the "F," but no "TM." There is a pointy part poking out about 1/4 inch from the wall and is about in the right spot, might that be it?
Question 6. I've saved the newbiest of all for last. The points gap (.012-.016 inches) is the minimum or the maximum value? Should the points ever actually touch?
Newb,[greek] (-ie) (noun):one who is new, green, or inexperienced
Synonyms: Me, greenhorn, noob, newbie,
Antonyms: guru, expert, the rest of y'all.
eg.The newb proclaimed proudly that he switched his ignition coil from his 76 Ford F150 onto his 76 Honda MT125.
-Jeremy Clarkson
WitchKing screwed with this post 10-25-2012 at 06:57 PM
Old 10-26-2012, 02:02 AM   #14
stainlesscycle
Oddometer: 2,267
First of all
1 if flywheel is not properly torqued it could spin loose/destroy keyway and potentially crank. as long as it's tight and located opn the keyway it will not effect spark, but yes, it should be properly torqued.
2. rectifier will not effect spark
3. the points should have a slot for a screwdriver to gently nudge them wider or closer.
4. kill switch, points, stator plate, charge coil, flywheel, points, condenser, ignition coil, sparkplug wire/end cap/sparkplug is the entire ignition system.
5. dunno haven't even looked to see what kinda bike we are talking about.
6. the value is the range of maximum opening - the maximum they should seperate is between .012 and .016. YES, the points need to touch at some point in the rotation. they need to open and close 1 time total during each rotation.
current bikes
Old 11-08-2012, 07:24 AM   #15
WitchKing OP
WitchKing's Avatar
Oddometer: 56
Thanks, that's very helpful.
-Jeremy Clarkson
Times are GMT -7.   It's 10:20 AM.
