Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 10-18-2012, 05:02 AM   #1501
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,435
Originally Posted by Oshiat View Post
Emailed Leo Vince about a USFS approved spark arrestor for a Leo Vince Big EVOII slip-on for my 2012 Triumph Tiger 800XC. Their reply:
Hey Perry,
Sorry for the delay. I found the spark arrestor for the Tiger 800 pipe. This is a sound insert with a spark arrestor screen in it. We have them in stock. It would be $52 to your door. If you would like to get one on order, just give me a call. Have a great day!
Part # 307587801R
Just thought I'd share.
That sucks. My spark arrestor was included with my LV pipe...
JG
live2ridetahoe is offline   Reply With Quote
Old 10-18-2012, 05:15 AM   #1502
live2ridetahoe
RN
Oddometer: 1,435
Originally Posted by Yankee Dog View Post
it pulls fine with stock gearing on the highway. I believe that it will pull just fine with a tooth dropped as well. Just maybe at 75 instead of 80.
The bike pulls better throughout the power band, in every gear. If you are going 2up and have a lot of gear, change out to a 15T. The bike just rides better, IMHO. There is no lack of power anywhere with this bike with a 15T or 16T.
BTW, it was only $15 for a 15T sprocket from my dealer. When the winter comes and I am not riding dirt anymore for the year, I might change it back for highway/commuting. The 15T is a no brainer if you are riding dirt/rocky jeep trails.
JG
Old 10-18-2012, 05:29 AM   #1503
Chinookmark
Oddometer: 215
Originally Posted by TxLoneRider View Post
Still sadly, I would actually like a tooth higher on the HWY :-) .
I know I've seen somewhere that people have gone up to a 17T in the front and were pleases with the results. This is obviously for highway riding and not single track.
And darn it, I like the idea of the final drive selector.
What about two sets of sprockets mounted, and a slider with a handlebar lever, like the gear change on a bicycle? It would be like a two speed, but actually be a twelve speed.
Chinookmark is offline   Reply With Quote
Old 10-18-2012, 06:42 AM   #1504
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,638
Interesting thought, but let's remember that a bicycle has a tensioner built into the chain drive at the rear derailleur. I'm not so sure that technology would be portable to a system where the chain is much more massive and the power delivery is much greater. And even if it is something that would adapt, there would then be another item on the bike that's got to be maintained. If it's kept at the rear wheel as on a bicycle, that is more unsprung weight.
Yeah, I know. You see blue sky, I see clouds.
Old 10-18-2012, 06:45 AM   #1505
ducnut
Oddometer: 3,295
A bicycle has a rear derailluer that acts as a chain tensioner. I'm not sure you could develop a tensioner that would be tensioned enought to withstand an 800cc motorcycle, yet, be slack enough to allow it the chain to climb to the higher gear. Also, the rear cassette has teeth shaped in a specific way, on a bicycle, to get the chain to climb the gears. Lastly, a motorcycle chain is designed to be ran only in a straight chainline, whereas a bicycle chain is designed to be cross-chained.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 10-18-2012, 06:58 AM   #1506
TxLoneRider
TxLoneRider's Avatar
Oddometer: 343
IIRC there are a few Buells that have a tensioners capable of handling engine braking, but, I would stay for the internal approach and have a sliding transmission gear with a manual dog, instead of one controlled by the shift drum.
That way the extra running gear stay clean inside the enlarged engine cases :-)
TxLoneRider is offline   Reply With Quote
Old 10-19-2012, 05:30 AM   #1507
Chinookmark
Oddometer: 215
I suppose one of us could just email someone like Nova racing and ask them to cut taller 5th and 6th gear for us. Combine that with the shorter first from a 675, and we have a wide ratio transmission. That would probably be a whole lot simpler than adding a derailer and chain tensioner. It worked for the DRZ guys.
Old 10-19-2012, 10:43 AM   #1508
Oshiat
Oddometer: 157
Asked Leo Vince about the spark arrestor. They ship with the pipe now. I bought mine in July, they are sending one at no cost. Awesome customer service.
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
Oshiat is offline   Reply With Quote
Old 10-19-2012, 11:30 PM   #1509
live2ridetahoe
RN
Oddometer: 1,435
Glad to hear it worked out for you!!
JG
Old 10-20-2012, 07:26 AM   #1510
Marsh Tiger
Marsh Tiger's Avatar
Oddometer: 550
I like this idea.
Marsh Tiger is offline   Reply With Quote
Old 10-20-2012, 07:28 PM   #1511
live2ridetahoe
RN
Oddometer: 1,435
I really like this idea too. Any ideas of how much this would cost? I'm sure it would really help with first and second gear off road as well as fuel econ at highway speeds.
JG
Old 10-21-2012, 05:58 AM   #1512
Marsh Tiger
Oddometer: 550
I'll bet it would cost as much as $1500...
Old 10-21-2012, 09:13 AM   #1513
Chinookmark
Oddometer: 215
Here's a link to a thread on Thumpertalk about the DRZ transmission:
http://www.thumpertalk.com/topic/914780-drz-400-wide-range-gearbox/
He said it was 1250 GBP for the first one, and 800 GBP for subsequent transmissions. So it looks like our guinea pig would be out close to $2500.
Chinookmark screwed with this post 10-22-2012 at 10:28 AM
Old 10-21-2012, 10:09 PM   #1514
Ian43ktm
Oddometer: 78
Clutch slip
I had a problem with my clutch slipping yesterday which sort of ties in with the gearing conversation. Bike is 15 months old with 14000 klm on it and a bit early to be having clutch problems I thought. We were pushing through an overgrown track I hadn't been on in about 15 years and it was a bit steeper than I remembered. So it was 1st gear moving slowly with a bit of push and shove and a lot of clutch work.The engine never overheated only going 1 bar hotter than normal running temp , I made sure I kept an eye on it. I noticed the lever engaging further out before getting drive and when back out on the road in high gears would rev but not increase speed at the same rate. It was ok if you were gentle on the throttle and rode home no problems. This morning I removed the clutch plates for inspection and found the friction plates still looked perfect but the steels were discoloured slightly black. I shuffled the plates , repacked them and gave the bike an oil change. I've only taken it for a 10 min test ride but there's no slipping and it seems to be back to normal again. What I'm wondering though is what happens if you're out past the black stump somewhere stuck in a mud hole or something and really abuse the clutch . I've treated enduro bikes a lot worse and never had clutch problems. Maybe what's basicly a road bike engine/clutch/gearing isn't up to this treatment . Anyone else had poblems? Still love the bike though, this is my first problem with it and appears to have been solved easily. ....Ian
Ian43ktm is offline   Reply With Quote
Old 10-22-2012, 09:39 AM   #1515
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 293
I had my clutch do the same. I ended up adjusting the cable a bit, then it got worse -- and I ended up having to replace the whole thing as the thing ended up overheating and discolouring. The shop manager at Peter Stevens where I bought the bike, who likes to abuse customers he thinks are inferior to his elite-ness anyway, had a long go at me that it was my fault for being too hard and slipping the clutch too much because I commute with my Tiger and lane split a lot, and also like to practice at the local Uni parking lot doing slow speed figure 8's etc.
I reckon your clutch might be dead like mine.
Oh, then as I got the clutch installed they pointed out that recall on the spring, which I have always wondered if it might have played a part in the issue...
I would have it checked ASAP in order to keep it from getting it too hot. But you sound like you know more than I, perhaps you can just lay it over and open it up and have a look.
Lusting for: Currently Sated with the new XCx
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2015 Tiger 800 XCx -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster, 2011 800 XC
Mr_Chris is offline   Reply With Quote
Times are GMT -7.   It's 02:22 PM.
