Old 10-17-2012, 03:51 AM   #5986
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 3,031
Originally Posted by RoninMoto View Post
I had 20% less fuel mileage when I had the Unifilter vs the stock air box. The performance was quite nice though. Not as loud as the Twinair filter on the front of the air box.
I remember you mentioning the mileage drop while running the open UNI POD in a PM response to me, but do you think the mileage drop was due to having a thirsty map loaded?
The UNI double pod inside of the stock box is the route I decided to take at your suggestion.
Good suggestion.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 10-17-2012, 09:13 AM   #5987
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,695
Good suggestion.
Dirty
With the open Uni Pod you pretty much have to have a thirsty map otherwise you will run her too lean. With the stock snorkel you can keep her close to stock on the map if you want the efficiency.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 10-17-2012, 09:30 AM   #5988
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,897
I ran the Uni foam filter with the stock box/ snorkel, and fmf Q4 pipe. No remap was necessary, just the 15 min reset...
BK.RD.RNR is offline   Reply With Quote
Old 10-17-2012, 10:18 AM   #5989
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,695
This was the exact setup on my old bike. The new one is the same but it has an LV pipe but I am now running Frankenstein map I put together. A touch richer on the top end but sip sip sip when you are cruising. seems to work out nicely.
Old 10-17-2012, 03:34 PM   #5990
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 785
Air filter discussion
There is some recent airfilter discussion here too
http://www.advrider.com/forums/showt...57040&page=260
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 10-19-2012, 06:04 PM   #5991
motoged
motoged's Avatar
Oddometer: 908
What kind of oil do you think is best?
No recent posts.....have we solved all the 690 issues?
C'mon, somebody out there have a complaint or a pic of their new rally fairing held on by industrial velcro?
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 10-19-2012, 06:16 PM   #5992
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 931
waiting on Crank. dont want to give up on the 690 but................
Im sure this will fix the problems............throwing money away anyway if I dumnp it now
and
there is nothing out there I want to replace it with...........bikes and beer are my only vises that cost $$ so I can have almost anything ....just dont see it.
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 10-19-2012, 06:47 PM   #5993
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,070
front tire quandry
Okay, I've got a complaint...
I have been through a metric shit ton of tires on my bikes and usually once I find a set that works for a particular bike, that is all I will ever buy for it again. Here lies the problem: I've run all sorts of non-dot tires on the 690 and the michelin HP4 front was the only one I ever truly liked (yes Bobzilla I ran an m12 already and it chunked like none other). I've run quite a few DOT fronts including: mt21, d606, k760, motoz h/t, motoz s/t, motoz x-circuit and probably more that I can't remember... ALL of the DOT tires sucked!
Being that my current motoz s/t (my least favorite tire in any on or offroad situation) is ready for the dumpster, it is time to experiment some more. I've been really curious about the pirelli 486 https://www.denniskirk.com/front-sco...re.p643248.prd and have found no reviews/ input whatsoever, anyone here ever run one?
I ride the 690 like a dirtbike and don't care too much about mileage (as long as it last at least as long as a non-dot knobby on the rear does) and very little about onroad handling. The vast majority of the terrain that I ride is very hard packed with sharp/loose rocks on top and coarse desert sand. The only front tires other than the 486 that are currently on my radar are the dunlop 908 and the michelin desert and I've never run any of these.
So what says the 690 brotherhood? Stick with the non-dot HP4 or try the p486/ d908/ or m desert?
P.S. somebody buy my uprated (9.0) rear spring in the flea market so I can afford a new tire!
The Letter J is offline   Reply With Quote
Old 10-19-2012, 07:05 PM   #5994
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
I ran the MotoZ HT's front and rear in MX and they worked well.
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-19-2012, 07:32 PM   #5995
The Letter J
Oddometer: 1,070
I've run the H/T's already and while the rear worked pretty good, the front just didn't seem to have enough "bite." The rear worked good for the wide open stuff but the x-circuit rear had the advantage in both cornering and longevity so that will definately be my next rear tire.
I've pretty much narrowed it down to (keep in mind this is only in regards to the front tire) pirelli 486, michelin desert, or dunlop 908. Of these tires, how do they fair for my described terrain?
Old 10-20-2012, 02:34 AM   #5996
Evil Invader
Evil Invader's Avatar
Oddometer: 699
I say Michelin Des. Expensive, but a good one. Ever looked at Mitas?
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 10-20-2012, 05:16 AM   #5997
SKINNY
SKINNY's Avatar
Oddometer: 668
Bridgestone ED 78 rear / Maxxis Desert IT front
Works very well in hard/ rocky desert stuff
Great in sand...
Readily available and cheaper than Motoz/Michelin
SKINNY is offline   Reply With Quote
Old 10-20-2012, 05:17 AM   #5998
Tootega
Tootega's Avatar
Oddometer: 8
Mitas
MITAS work well for me. Ive used the EF07 and the CO2 do.t with 18mm knobs on the rear. The best value for lots of pavement/rocky is the Army tyre.
Tootega is offline   Reply With Quote
Old 10-20-2012, 05:37 AM   #5999
karinjtimoyht
Oddometer: 12
i do not have an ignition switch itself
Just two kill switches One kills all power and the other is just an engaine kill
my well have a look at the switches
karinjtimoyht is offline   Reply With Quote
Old 10-20-2012, 05:57 AM   #6000
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 190
+1. A lot of Dakar pedigree on the Michelin Desert. Isn't the HP4 a motocross tyre? How long did it last?
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Times are GMT -7.   It's 10:18 PM.
