Old 10-20-2012, 02:28 PM   #70261
motolab
motolab's Avatar
Oddometer: 2,777
Originally Posted by Rumlover View Post
2) And what I thought was originally a lean issue on the needle and or main (causing surging), is now a rich condition because of the excess tape.
I had considered that, except that he also stated that without the tape, there was no difference in severity when the bike warmed up. Normally if the mixture was lean, matters would improve as the engine warmed up, and he said they didn't. Also consider that it takes a massive change to go from a lean surge to a rich surge. After all, the mixture has to be way, way rich to produce a symptom, whereas it only has to be a little lean (comparatively). To illustrate, the ideal CO% is ~3-5. Lean symptoms will begin to manifest around 2%, whereas rich symptoms won't until somewhere around the 12-13% mark.
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-20-2012, 02:39 PM   #70262
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by maynard911 View Post
I have tried those red EBC kelvar pads also, even new they have 20% less power than the oem stuff.
For the front brake I was referring to the EBC sintered pads. Pretty much their best pad. They are well below the performance of the OEM Nissin pads.
Both are rated HH ... the Nissin is worlds better in my experience, but do wear quickly if used hard.
The red EBC Kevlar ones I use in the rear brake. They are fine for me, don't need a lot of power there ... and can still lock up easy enough. I tend to drag the rear brake, so the hard wearing Red Kevlar ones seem pretty good. YMMV.
Old 10-20-2012, 03:32 PM   #70263
badweatherbiker
badweatherbiker's Avatar
Oddometer: 706
You guys are awesome, thanks so much for the help and all the great info on diagnosing the issue.
I wont have another chance to peel away some tape until Monday when I am back at work (the bike is parked there) but I'll let you know what happens!
It was just confusing because the plugs did not indicate a rich condition.
so the consensus is remove some tape and turn in the mixture screw?
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker is offline   Reply With Quote
Old 10-20-2012, 04:58 PM   #70264
TRAVELGUY
Old Traveler
Oddometer: 699
Originally Posted by Adv Grifter View Post
Sorry for not doing a better update on my Tubeless attempt. I used a 3M
Marine sealer for the spoke nipples and enlarged the valve stem hole for a tubeless valve stem. It would not hold air. I have some valve stems from NAPA that the guy that developed this procedure recommends. Fits stock rim hole.
The procedure I'm am planning on using uses two different materials. The guy that posted the procedure has done several of his bikes and done extensive riding. If I do go with sealing the rims hopefully this will do the job.
I'm not sure of the reason. I think the tubeless Distanzia I used would not butt up close enough to the stock 17" wheel bead to form a seal. Could not air it up ... or .... some how I missed something (quite possible) and didn't seal the wheel good enough?? ?? The originator of the procedure I plan to use says due a bathtub test and reseal any leaks.
The very best option on this, IMHO, is to send your DR650 wheel to Woody's Wheel Works and let him seal it up right to make it a tubeless affair. Have thought of that but don't have the time or money.
But here is my worry:
Lets say you get a flat on the road. You plug the hole ... but lets say the bead has broken (this typically won't happen on a real tubeless rim, but the stock DR rim is NOT a tubeless rim) So if the bead is broken ... how do you re-inflate on the side of the road with CO-2 or hand pump? I have been concerned about that happening, since I have never had a flat tire on the road or dirt 300.000 miles I feel sure it has to happen this trip. My riding buddy will have a large compressed air bottle with him and there is always using a little pour of gas and a match, boom!!!
Woody may recommend you buy a NEW WHEEL that will work tubeless, but that could limit tire choice. So some things to think over.
Anyway, just my thoughts. Not many have done this on a DR650 that I know of. I hope you will follow up with any info you find on this and do a better job than I did documenting.
All the best!
Grifter thanks for your response and input. If I do seal the rims I will try to post results.
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 10-20-2012, 05:16 PM   #70265
motolab
motolab's Avatar
Oddometer: 2,777
You could adjust the pilot screw via the following method:
Start the engine and warm it up. Lower the idle speed below the factory spec. Starting from a setting that is known to be lean (1-1/2 turns is likely but not guaranteed to be), adjust the fuel screw to obtain the highest idle speed. Adjust to 1/8 - 1/4 turn richer than that. Then, adjust the idle speed back to 1500 rpm. Report back with the setting.
In order to determine whether, as Rumlover suggested, the mixture was lean before the tape was applied and is only now rich, you could gradually remove more and more tape, testing after each change. If he is right, there will be a sweet spot where it runs better than it does now as well as how it ran un-taped. If the problem gradually gets better as you untape, but never gets better at any stage than before it was taped or now, then you started out too rich and taping only made it richer.
Regards,
Derek
Old 10-20-2012, 09:01 PM   #70266
neo1piv014
ADV in training
Oddometer: 621
Originally Posted by PhL0aTeR View Post
All good there.
I spent an hour thinking about getting the vapor before i ordered the cable last week, so I'm already halfway there.... Lol. Honestly,i couldn't find a decent pic of a vapor installed to give me a good idea of what it would look like.
This was just a quick search, but I remember there being better videos out there.
http://www.youtube.com/watch?v=U1KSaYo-Wpk
If I understand the instruction manual for the Vapor unit, it's basically just a handlebar mount. The mounting bracket goes around your handlebar in much the same way you'd install a RAM mount. Then, the vapor bolts up to that, so it sits closer to the bars than the stock unit. However, it looks like they make it very easy to fab up your own mounting system, so you could probably just do whatever the hell you wanted with it.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-20-2012, 09:56 PM   #70267
JTB488
Oddometer: 153
Sorry I don't have a pic, but the Vapor does come with an aluminum bracket that you can use to mount it to the front of the upper triple clamp.
JTB488 is offline   Reply With Quote
Old 10-21-2012, 06:30 AM   #70268
greener556
Oddometer: 115
Highway Dirtbikes has some interesting stuff..
I'm planning on getting a billet Vapor mount from HDB and relocating my key switch this winter.
greener556 is offline   Reply With Quote
Old 10-21-2012, 06:44 AM   #70269
Minsk99
Oddometer: 56
Might want to double check that. Mine did not come with an aluminum bracket, but it did come with a plastic bracket that clamps to the handle bars. I believe that bracket you mention comes with the protective case that many order with the Vapor.
I have been happy with the placement using the plastic clamp. It is actually is a better placement if you intend to keep and use the stock speedo (I like the mechanical odo and trip meeter).
Minsk99 is offline   Reply With Quote
Old 10-21-2012, 08:41 AM   #70270
sandwash
sandwash's Avatar
Oddometer: 1,366
Vapor home made Alium mount:
97dr650
sandwash is offline   Reply With Quote
Old 10-21-2012, 10:13 AM   #70271
Luisgv
ADVenturer
Luisgv's Avatar
Oddometer: 19
Originally Posted by Motodeficient View Post
So is there any opinions on this? Is this chain movement normal? Sure doesn't seem normal to me. What could be causing this?
Hello friend, i think your DR need a chain adjustment, remember that the chain when is properly adjusted must move about 10 mm. More than that is a loose chain.. if need a better reference, the maintenance manual may be helpfully.
Hope it help.
DR650SE 2009
M108R 2008
Caracas - Venezuela
Luisgv is offline   Reply With Quote
Old 10-21-2012, 11:10 AM   #70272
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
Eh? Vapor dash
https://www.facebook.com/photo.php?f...0&l=bedbb74d41 shows the dash on my DR which I am still working on with the Vapor installed . From the factory it comes with a little clamp/base that connects to your handlebars. Unless you purchase the high speed bar mount made from alum. I like it the light isnt over poweringat night and its always easy to see unless you are at a realy odd angle from it.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 10-21-2012, 12:49 PM   #70273
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Hope it help.
Actually, the manual says 30-45 mm
NordieBoy is offline   Reply With Quote
Old 10-21-2012, 12:58 PM   #70274
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,575
Best carb for the trans-am trail.
My BST has been modded and actually isn't all that bad, but I have been wanting to upgrade to the pro-cycle mikuni pumper.
Doing the trans am this summer, are there advantages to one over the other?
I am thinking I may have to rejet during the trip or have to make fuel adjustments on the road.
B.E. Coyote is online now   Reply With Quote
Old 10-21-2012, 01:00 PM   #70275
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,826
You will not have to re-jet. I ran the entire TAT on a carbed bike. You'll never know the difference.
BTW, 13K I believe was the apex of it.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Times are GMT -7.   It's 05:21 AM.
