Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 10-20-2012, 07:26 PM   #14671
T
stay classy
T's Avatar
Oddometer: 5,266
Originally Posted by Chinookmark View Post
Could you direct us to your posts describing how you did that?
Sent ya a PM w/pics.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 10-20-2012, 07:53 PM   #14672
E-town dirt dude
E-town dirt dude's Avatar
Oddometer: 201
C'mon...don't be shy...share with all of us
All it takes for evil to triumph is for good men to do nothing
E-town dirt dude is offline   Reply With Quote
Old 10-21-2012, 04:09 AM   #14673
bluesman
Oddometer: 3,302
Wait....it looks like Tiger have tubeless-compatible rims despite they use tubes? Or it just looks like it?
This can be a great news for me...
I mean - there is ridge as I can see typical for tubeless?
Here is tubeless rim - typical, I saw same on Caponord
Compare...
bluesman is offline   Reply With Quote
Old 10-21-2012, 07:43 AM   #14674
Riot
Tiger Rider
Oddometer: 105
Compare...
Thats a KTM rim not sure if its an aftermarket or OEM.
I posted a link to that image on another forum in response to people trying to do dodgy stuff to their rims so they can attempt to run tubeless on a rim not actually designed to be tubeless. This was an example of a better idea of how to safely run tubless on spoked rims. BMWs do somthing similar I believe. Also there is a conversion kit that uses your hub and a aftermarket rim http://alpinawheelsusa.com/products/...it-conversion/
I dont believe the XC has the correct rim profile with a lip to seat and hold the bead.
Riot is offline   Reply With Quote
Old 10-21-2012, 08:02 AM   #14675
bluesman
Oddometer: 3,302
That's Caponord/BMW rim that Woody uses for conversion kits...I know those well - used one to convert my friend's Strom to spoked wheels.
You right, I was just specifically about tubeless "lip" profile.
It's just looks so much like it...I really do not want to do conversion if rim is not suitable at all for tubeless
Old 10-21-2012, 08:06 AM   #14676
ABHooligan
The Flying Mythos
ABHooligan's Avatar
Oddometer: 1,123
For any that may be interested.
Rear wheel spoke seal on 800XC (w/3M 5200) after 7500 miles. Going strong.....
I just did mine Thursday night. Waiting on the goo to dry for a few more days...
"I tried to move my mind there and nowhere else and imagine a single detail that, if I didn't see it that weekend, I never would... The world is easily lost."
James Dickey
ABHooligan is offline   Reply With Quote
Old 10-21-2012, 08:25 AM   #14677
T
stay classy
T's Avatar
Oddometer: 5,266
Compare...
Rear rim has the raised "lips". Front 21" does not (when I pulled my frt. tire off they were not as pronounced).
I still run a tube in my front and have had the pleasure of fixing a front tire puncture roadside (what a PITA).
I did the rear wheel due to the fact that 95% of the unwanted things I usually pick up on the road are with my rear tire. Fixing a tubeless puncture is (IMO) far easier road/trail side than changing/patching a tube.
Happy Riding...
Old 10-21-2012, 08:40 AM   #14678
motonut
Old Guy
Oddometer: 62
more on oil filter covers
Originally Posted by KildareMan View Post
You can get a triumph one cheaper. Not meant for 800 but works perfectly.
Sent from my Tiger 800
Due to the coverage here, relating to oil filter covers to protect against stone damage/perforation of said filter, combined with some friends noticing my Tiger's vulnerability... I have taken action.
It began with a hunt for available materials in my extensive collection of plunder. Once I found the appropriate donor part it became apparent that function and whimsy were cousins here.
The item began life as a track-light and has now been hacked to meet another need. It is steel; a bit heavier gauge than an oil filter. Inside I epoxied a 'doughnut' magnet from a junked microwave oven's magnetron tube. They are extremely strong magnets! The acorn nut is on a hex bolt embedded in epoxy in the center of the magnet.
I may spray it black someday but look at it now and think a white cover on a white sickle is fine. Click on the image and you will see three photos.
[IMG]
https://picasaweb.google.com/s/c/tra...background.gif) no-repeat left">
Tiger oil filter cover
[/IMG]
motonut is offline   Reply With Quote
Old 10-21-2012, 09:37 AM   #14679
T
stay classy
T's Avatar
Oddometer: 5,266
Cool. I like the magnet/cover idea.
Old 10-21-2012, 09:42 AM   #14680
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,071
Changed the brake pads on the rear yesterday (so I pushed the piston back in to fit the new pads) and I also fitted new tired front and rear so when I did the front wheel, I did the same with the front brakes to make it easier to get the wheel back on. I also disconnected the battery to take it out and now when the ABS light does not go out when riding
Thoughts ?
Brakes appear to be fine although it appears like the ABS is trying to kick in when I brake and are coming to a stop. I say appears since it could be the new tires I fitted which have a much more aggressive tread pattern so the 'judder' I am feeling may just be the tires.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Old 10-21-2012, 09:43 AM   #14681
jphish
Oddometer: 617
I suppose its conceiveable one could 'hole' the oil filter, (with the optional triumph skidplate) but gotta ask: how many folks have had that occur? I have about 10K miles on mine, (about 2500 mi on dirt) and no issues. I carry an extra filter with my tool kit, (they're small) in the event I need to change oil on an extended trip. Perhaps I dont ride the same terrrain as some who use the tiger as a "dirt bike" - but surmise that filter damage, while possible, is an unlikely event for most of us.
jphish is offline   Reply With Quote
Old 10-21-2012, 11:11 AM   #14682
DavidXT
DavidXT's Avatar
Oddometer: 94
Thoughts ?
With ABS brakes when youve bled them you need to get the air out using the diagnostic software. More than likely that just needs doing after youve pushed the pistons in.
Present:
'06 Suzuki DRZ400SM, '04 Suzuki DRZ400E
Past:
'09 Buell XB12XT (can I change my name now??) , '99 Suzuki Katana 600, '97 Honda Shadow VT 750 ace, '?? Kawasaki 250 quad, '96 Suzuki TS50X
DavidXT is offline   Reply With Quote
Old 10-21-2012, 11:59 AM   #14683
Mercury264
Mercury264's Avatar
Oddometer: 22,071
Really ? Damn, all I did was push the pistons in I didn't crack any lines or anything.
I knew ABS was going to be a total PIA
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-21-2012, 12:39 PM   #14684
motonut
Old Guy
Oddometer: 62
odds...
I totally agree that the probability of a stone flipping up and punching a hole in my oil filter is slim, very slim. However, I do an awful lot of "looking around corners" trying to prevent or be ready for what may happen. The odds are higher that I may crash or be hit so I wear a Roadcrafter. I've had a few nail punctures of tires over the years so I always have the means to fix, inflate and get back on the road with me as 'just another tool'......
What goes through my imagination, beyond oil starvation/engine seizure, is my being unaware of the event temporarily and then losing it in the oil slick following the puncture.
I'm done.
Old 10-21-2012, 03:18 PM   #14685
motosickle2000
Oddometer: 187
Thoughts ?
You should check your ABS sensors - maybe you bumped something loose. I doubt that your ABS needs bleeding - I have changed my front and rear pads and have had no such problem.
Have you noticed that you only get about 5Kmiles from your rear pads? I use my rear brakes quite a lot, but it seems I should be getting better mileage. I found when I put on EBC pads, the rears are wearing much better, but the fronts look like they will only go 5K.
I am trying some sintered pads I bought on Ebay. $18 shipped for a full set (both calipers) of pads.
motosickle2000 is offline   Reply With Quote
Times are GMT -7.   It's 12:20 PM.
