Old 10-20-2012, 09:01 PM   #70426
neo1piv014
ADV in training
Oddometer: 610
Originally Posted by PhL0aTeR View Post
All good there.
I spent an hour thinking about getting the vapor before i ordered the cable last week, so I'm already halfway there.... Lol. Honestly,i couldn't find a decent pic of a vapor installed to give me a good idea of what it would look like.
This was just a quick search, but I remember there being better videos out there.
http://www.youtube.com/watch?v=U1KSaYo-Wpk
If I understand the instruction manual for the Vapor unit, it's basically just a handlebar mount. The mounting bracket goes around your handlebar in much the same way you'd install a RAM mount. Then, the vapor bolts up to that, so it sits closer to the bars than the stock unit. However, it looks like they make it very easy to fab up your own mounting system, so you could probably just do whatever the hell you wanted with it.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-20-2012, 09:56 PM   #70427
JTB488
Oddometer: 40
Sorry I don't have a pic, but the Vapor does come with an aluminum bracket that you can use to mount it to the front of the upper triple clamp.
JTB488 is offline   Reply With Quote
Old 10-21-2012, 06:30 AM   #70428
greener556
Oddometer: 92
Highway Dirtbikes has some interesting stuff..
I'm planning on getting a billet Vapor mount from HDB and relocating my key switch this winter.
greener556 is offline   Reply With Quote
Old 10-21-2012, 06:44 AM   #70429
Minsk99
Oddometer: 56
Might want to double check that. Mine did not come with an aluminum bracket, but it did come with a plastic bracket that clamps to the handle bars. I believe that bracket you mention comes with the protective case that many order with the Vapor.
I have been happy with the placement using the plastic clamp. It is actually is a better placement if you intend to keep and use the stock speedo (I like the mechanical odo and trip meeter).
Minsk99 is offline   Reply With Quote
Old 10-21-2012, 08:41 AM   #70430
sandwash
sandwash's Avatar
Oddometer: 837
Vapor home made Alium mount:
97dr650 bad ass FCR-MX pumper,plus other goodies
sandwash is offline   Reply With Quote
Old 10-21-2012, 10:13 AM   #70431
Luisgv
ADVenturer
Luisgv's Avatar
Oddometer: 17
Send a message via MSN to Luisgv
Originally Posted by Motodeficient View Post
So is there any opinions on this? Is this chain movement normal? Sure doesn't seem normal to me. What could be causing this?
Hello friend, i think your DR need a chain adjustment, remember that the chain when is properly adjusted must move about 10 mm. More than that is a loose chain.. if need a better reference, the maintenance manual may be helpfully.
Hope it help.
DR650SE 2009
Caracas - Venezuela
Luisgv is offline   Reply With Quote
Old 10-21-2012, 11:10 AM   #70432
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 143
Eh? Vapor dash
https://www.facebook.com/photo.php?f...0&l=bedbb74d41 shows the dash on my DR which I am still working on with the Vapor installed . From the factory it comes with a little clamp/base that connects to your handlebars. Unless you purchase the high speed bar mount made from alum. I like it the light isnt over poweringat night and its always easy to see unless you are at a realy odd angle from it.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 10-21-2012, 12:49 PM   #70433
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,774
Hope it help.
Actually, the manual says 30-45 mm
NordieBoy is offline   Reply With Quote
Old 10-21-2012, 12:58 PM   #70434
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 4,639
Best carb for the trans-am trail.
My BST has been modded and actually isn't all that bad, but I have been wanting to upgrade to the pro-cycle mikuni pumper.
Doing the trans am this summer, are there advantages to one over the other?
I am thinking I may have to rejet during the trip or have to make fuel adjustments on the road.
B.E. Coyote is offline   Reply With Quote
Old 10-21-2012, 01:00 PM   #70435
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,450
You will not have to re-jet. I ran the entire TAT on a carbed bike. You'll never know the difference.
BTW, 13K I believe was the apex of it.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot is online now   Reply With Quote
Old 10-21-2012, 01:14 PM   #70436
B.E. Coyote
(Super-Genius)
Oddometer: 4,639
On a DR?
Old 10-21-2012, 01:43 PM   #70437
DockingPilot
Oddometer: 7,450
Wont matter, the engine is plenty big enough.
A 610. Carbed I rode
On a carbed 250, maybe you'd feel it , but not on the big bore DR and its not like your living up there, its up and over. Like I said youll never notice, The DR is the perfect weapon for the TAT. If your jetting is dialed in now, it will be fine for the trip Bri.
Frank Reinbold
*2010 FOREVER WEST*
TRANS AM TRAIL WEST
Old 10-21-2012, 01:55 PM   #70438
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 281
Suspension upgrades
For those of you who've tinkered with dr650 suspension mods I've got a question:
If you could have ANYTHING done on yours what would it be; forks from a donor bike, different swingarm and/or shock or would the ultimate fix be too cost prohibitive wherein a prudent person would save the cash and apply towards a different bike altogether?
Slideways#96 is offline   Reply With Quote
Old 10-21-2012, 02:19 PM   #70439
JTB488
Oddometer: 40
That could be it. I did order mine with the "dash", but ended up not using the dash portion.
Old 10-21-2012, 02:34 PM   #70440
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 2,052
I'd buy a different bike, or I'd buy the Racetech rear shock assy and Racetech emulators and springs.
http://breakingbooks.wordpress.com
http://www.kenmarshallmetalworks.com/
2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
acesandeights is online now   Reply With Quote
Times are GMT -7.   It's 02:23 PM.
