Old 10-21-2012, 02:00 PM   #70276
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,550
Originally Posted by B.E. Coyote View Post
Best carb for the trans-am trail.
My BST has been modded and actually isn't all that bad, but I have been wanting to upgrade to the pro-cycle mikuni pumper.
Doing the trans am this summer, are there advantages to one over the other?
I am thinking I may have to rejet during the trip or have to make fuel adjustments on the road.
You will not have to re-jet. I ran the entire TAT on a carbed bike. You'll never know the difference.
BTW, 13K I believe was the apex of it.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 10-21-2012, 02:14 PM   #70277
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,501
On a DR?
B.E. Coyote is online now   Reply With Quote
Old 10-21-2012, 02:43 PM   #70278
DockingPilot
Oddometer: 9,550
Wont matter, the engine is plenty big enough.
A 610. Carbed I rode
On a carbed 250, maybe you'd feel it , but not on the big bore DR and its not like your living up there, its up and over. Like I said youll never notice, The DR is the perfect weapon for the TAT. If your jetting is dialed in now, it will be fine for the trip Bri.
Frank Reinbold
Old 10-21-2012, 02:55 PM   #70279
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 548
Suspension upgrades
For those of you who've tinkered with dr650 suspension mods I've got a question:
If you could have ANYTHING done on yours what would it be; forks from a donor bike, different swingarm and/or shock or would the ultimate fix be too cost prohibitive wherein a prudent person would save the cash and apply towards a different bike altogether?
Slideways#96 is offline   Reply With Quote
Old 10-21-2012, 03:19 PM   #70280
JTB488
Oddometer: 152
Originally Posted by Minsk99 View Post
Might want to double check that. Mine did not come with an aluminum bracket, but it did come with a plastic bracket that clamps to the handle bars. I believe that bracket you mention comes with the protective case that many order with the Vapor.
I have been happy with the placement using the plastic clamp. It is actually is a better placement if you intend to keep and use the stock speedo (I like the mechanical odo and trip meeter).
That could be it. I did order mine with the "dash", but ended up not using the dash portion.
JTB488 is offline   Reply With Quote
Old 10-21-2012, 03:34 PM   #70281
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,923
I'd buy a different bike, or I'd buy the Racetech rear shock assy and Racetech emulators and springs.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 10-21-2012, 03:50 PM   #70282
Slideways#96
scooter trash
Oddometer: 548
Thanks for the reply! I'll do some research on the racetech mods.
Old 10-21-2012, 03:53 PM   #70283
acesandeights
Asperger
Oddometer: 3,923
It can all be purchased through Racetech, http://www.racetech.com or through one of their distributors.
Old 10-21-2012, 03:58 PM   #70284
Slideways#96
scooter trash
Oddometer: 548
Great, thanks again!
Old 10-21-2012, 04:48 PM   #70285
FlowBee
Just me.
FlowBee's Avatar
Oddometer: 5,754
My DR fully loaded pushes the limits of the OEM sidestand. I adjusted the rear preload but still feel it's too tall and ready to flop over on the right.
How much shorter is the DR650 OEM short sidestand compared to the OEM normal standstand? Would it work for heavily loaded DR650s ?
Thanks.
FB
"And then this one time at banned camp ....."
FlowBee is offline   Reply With Quote
Old 10-21-2012, 04:56 PM   #70286
Sierra Thumper
Oddometer: 641
Yep if your jetting's currently dialed in, you'll be fine...you'll just lose some (or more ) power at the higher elevations.
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 10-21-2012, 05:05 PM   #70287
Fire Escape
Fire Escape's Avatar
Oddometer: 1,572
Sagging springs
Thanks.
FB
I went through that as well. I already had the short stand but had lowered the rear and dropped the front clamps about an inch on the tubes. No amount of preload adjustment (at least up to the manual prescribed minimum) would help the bike stand up (at least not for long, I tightened up on the rear pre-load a couple of times, it would seem better for a short time but the oem spring kept on sagging). I finally gave in and bought springs appropriate to my weight (for me that meant two up with luggage....even though I ride solo). The aftermarket springs haven't shown the same tendency to 'creep', bike height has remained 'normal' and I can be less particular about finding the 'right' spot to try and leave it on the side stand. It probably rides better as well, being as I am now riding in the middle of the shock stroke instead of the bottom. I am not sure that I am qualified to judge that. It certainly isn't all new suspension front and rear but springs are relatively affordable and not too challenging to install.
I know that I have a 'normal' side stand somewhere, if I find it soon, I will get measurements for comparison.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is online now   Reply With Quote
Old 10-21-2012, 08:39 PM   #70288
shu
Oddometer: 999
Thanks.
FB
I had the same problem with not enough lean on my stand.
I'm not sure about the short sidestand- I think it's 1 1/2 inches shorter.
I took my stand to a local welder and had him cut about 1 inch out of my stock sidestand. He welded a pin in for strength and then welded the thing back together. This has worked great for the last 45,000 miles.
..............shu
shu is online now   Reply With Quote
Old 10-21-2012, 09:34 PM   #70289
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
I'd go Ricor front and rear.
Intiminators in the front and an IAS shock in the back.
At the moment the Intiminators are $180 (down from $300) and the shock is $550 (down from $890).
NordieBoy is offline   Reply With Quote
Old 10-21-2012, 10:15 PM   #70290
Kommando
Kommando's Avatar
Oddometer: 7,368
Forks from a donor bike (re-sprung and valved for the weight) and a fully-adjustable shock with appropriate spring. Cogent is usually highly recommended for DR shocks. I'd like to have a remote preload adjuster too.
Note: I'm not riding a 350-400lb adv-thumper like a MX/XC racebike. I'm riding at an exploratory/fun pace when offroad. If I wanted to skim whoops and clear triples, I'd be on a 300lb-or-lighter bike.The DR's thin-wall frame isn't designed to take that kind of abuse with a load of luggage anyway. If I can get 3-4' of air and hit 6-12" ruts without bottoming/wallowing, I call it good enough.
Kommando is offline   Reply With Quote
Times are GMT -7.   It's 05:13 PM.
