10-21-2012, 07:25 AM
#14731 | |
Sim Sala Bim
Oddometer: 3,379
I still run a tube in my front and have had the pleasure of fixing a front tire puncture roadside (what a PITA). I did the rear wheel due to the fact that 95% of the unwanted things I usually pick up on the road are with my rear tire. Fixing a tubeless puncture is (IMO) far easier road/trail side than changing/patching a tube. Happy Riding...
Inconsequential Adventurer Upon us all a little rain must fall. L.Z. |
10-21-2012, 07:40 AM
#14732 | |||
Old Guy
Oddometer: 46
more on oil filter covers
It began with a hunt for available materials in my extensive collection of plunder. Once I found the appropriate donor part it became apparent that function and whimsy were cousins here. The item began life as a track-light and has now been hacked to meet another need. It is steel; a bit heavier gauge than an oil filter. Inside I epoxied a 'doughnut' magnet from a junked microwave oven's magnetron tube. They are extremely strong magnets! The acorn nut is on a hex bolt embedded in epoxy in the center of the magnet. I may spray it black someday but look at it now and think a white cover on a white sickle is fine. Click on the image and you will see three photos. [IMG]
10-21-2012, 08:37 AM
#14733 |
Sim Sala Bim
Oddometer: 3,379
Cool. I like the magnet/cover idea.
10-21-2012, 08:42 AM
#14734 |
Once you go Triple...
Oddometer: 20,413
Changed the brake pads on the rear yesterday (so I pushed the piston back in to fit the new pads) and I also fitted new tired front and rear so when I did the front wheel, I did the same with the front brakes to make it easier to get the wheel back on. I also disconnected the battery to take it out and now when the ABS light does not go out when riding
![]() Thoughts ? Brakes appear to be fine although it appears like the ABS is trying to kick in when I brake and are coming to a stop. I say appears since it could be the new tires I fitted which have a much more aggressive tread pattern so the 'judder' I am feeling may just be the tires.
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
10-21-2012, 08:43 AM
#14735 |
Oddometer: 596
I suppose its conceiveable one could 'hole' the oil filter, (with the optional triumph skidplate) but gotta ask: how many folks have had that occur? I have about 10K miles on mine, (about 2500 mi on dirt) and no issues. I carry an extra filter with my tool kit, (they're small) in the event I need to change oil on an extended trip. Perhaps I dont ride the same terrrain as some who use the tiger as a "dirt bike" - but surmise that filter damage, while possible, is an unlikely event for most of us.
10-21-2012, 10:11 AM
#14736 | |
Oddometer: 94
With ABS brakes when youve bled them you need to get the air out using the diagnostic software. More than likely that just needs doing after youve pushed the pistons in.
Present: '06 Suzuki DRZ400SM, '04 Suzuki DRZ400E Past: '09 Buell XB12XT (can I change my name now??) |
10-21-2012, 10:59 AM
#14737 | |
Oddometer: 20,413
I knew ABS was going to be a total PIA
10-21-2012, 11:39 AM
#14738 | |
Old Guy
Oddometer: 46
odds...
What goes through my imagination, beyond oil starvation/engine seizure, is my being unaware of the event temporarily and then losing it in the oil slick following the puncture. I'm done. |
10-21-2012, 02:18 PM
#14739 | |
Oddometer: 173
Have you noticed that you only get about 5Kmiles from your rear pads? I use my rear brakes quite a lot, but it seems I should be getting better mileage. I found when I put on EBC pads, the rears are wearing much better, but the fronts look like they will only go 5K. I am trying some sintered pads I bought on Ebay. $18 shipped for a full set (both calipers) of pads. |
10-21-2012, 03:32 PM
#14740 |
Bring us some fresh wine!
Oddometer: 2,327
No, not really. You got bad info.
If you didn't do anything else other than push the pistons back to fit new pads, ABS doesn't enter into the equation. More likely you accidentally tweaked or otherwise fucked up one of the ABS wheel speed sensors while you were doing the brakes. Check em out and get back to us. |
10-21-2012, 03:50 PM
#14741 | |
Oddometer: 20,413
As I mentioned, the brakes appear to work just fine - manual actually says that if the light doesn't go off after reaching 6MPH, then the brakes revert to being non-ABS so if that's the case I'm not too concerned...
10-21-2012, 03:52 PM
#14742 | |
Oddometer: 20,413
10-21-2012, 03:59 PM
#14743 |
Oddometer: 173
All of my mileage is in-town, short trips - so I am probably harder on brakes than most. I don't drag my rear brake either. The EBC HHs that I put on the rear look like they will go at least 10Kmi, but the fronts probably will not make 5Kmi. I got 8Kmi out of my OEM front pads. I'll let you know how the Ebay brakes work out.
10-21-2012, 05:05 PM
#14744 | |
Oddometer: 237
10-21-2012, 10:17 PM
#14745 |
Oddometer: 102
Rear Tire Sealing Failure
Checked my XC's tire pressure today. Front tire down 1 pound, rear tire....0 PSI. Sealed my rear rim 150 miles ago, a few short runs followed by a 105 mile off road adventure ride last weekend. Used the Seal All x2 / Goop x1 individual spoke sealing method detailed somewhere here earlier. Pulled the wheel, checked with soapy water, leaking from two spoke holes. Dismounted the tire, visible adhesion failures on three spokes, the third one just hadn't leaked yet. Reinstalled the rim band and the tube. Retry again maybe later this winter, but I did prep the rim thoroughly with alcohol. Oh well.
If anyone made a tubeless rim and spoke kit that I could lace to my stock XC hubs for maybe $250 (per wheel) I'd be interested. I've only seen complete wheels, for big bucks(2 to 3 grand). Have I missed anything? Ken |
