Old 10-05-2012, 02:07 PM   #61
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 3,075
Sounding like a major step in the right direction! Are the side mounts changed from the SM tank then? If so, where do they attach?
I like the look of that rubber isolated bar mount system. The regular system kind of bugs me since the stabilizer is mounted on the wrong side of the rubber isolation!
Yardstick is online now   Reply With Quote
Old 10-05-2012, 02:20 PM   #62
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,400
We use the same side mounts as the SM, which are approx 6" lower and 2" further forward than the SE side mounts. We also are including a custom stainless steel front mount that is significantly stronger than the stock SM front mount, and threaded to fit the SE.
~ Ken
www.powercellperformance.com
PowerCell screwed with this post 10-05-2012 at 02:29 PM
PowerCell is offline   Reply With Quote
Old 10-05-2012, 03:38 PM   #63
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 3,075
Gotcha! I thought you were talking about something even further forward, closer to the radiator itself. I get it!
Old 10-13-2012, 09:16 AM   #64
Splisken
I'm not dead yet...
Splisken's Avatar
Oddometer: 127
Things are looking very good indeed! The lines of the tank to seat are great and flow well. The shorter filler tower looks much better IMHO and as another said there would be no real loss in capacity there. Any new news?
Hey Ken - You mentioned reaching out to me before manufacturing mine to verify choices...if not too late I'd prefer the black (call me a poser if you will) as the graphics we are working on just don't work on the other colors as well IMHO. I can live with the orange if too late but would prefer the black at this point.
Splisken screwed with this post 10-14-2012 at 07:26 PM
Splisken is offline   Reply With Quote
Old 10-15-2012, 12:25 PM   #65
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,122
Beautiful project!
Love the lines of the design.
Will it fit my 950SM?
THX!!
snowhawk jockey is offline   Reply With Quote
Old 10-15-2012, 02:09 PM   #66
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,400
Originally Posted by Splisken View Post
Hey Ken - You mentioned reaching out to me before manufacturing mine to verify choices...if not too late I'd prefer the black...
No problem Poser...
I'll still reach out to you prior to molding and confirm the black.
~ Ken
Old 10-15-2012, 02:09 PM   #67
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,400
Originally Posted by snowhawk jockey View Post
Beautiful project!
THX!!
Yes it will...
~ Ken
Old 10-18-2012, 10:34 AM   #68
dzrtracin
ride'n 2 live
dzrtracin's Avatar
Oddometer: 2,819
Ken, less than 2 weeks out?
RIDE ON!
Content, NEVER!
dzrtracin is offline   Reply With Quote
Old 10-18-2012, 12:45 PM   #69
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,122
Originally Posted by PowerCell View Post
Yes it will...
I am a happy camper!! Gonna start a savings pile for one! Do you mind if I cross market the tank on the 950SM chronicles?
Old 10-18-2012, 02:02 PM   #70
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,400
Sure... go forth and multiply...
~ Ken
Old 10-21-2012, 01:53 PM   #71
Dan950ser
NW Shredder
Oddometer: 494
So how's production going? Still on schedule for end of October/beginning of November? So excited. Thanks.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR For Sale http://www.advrider.com/forums/showthread.php?t=1046431, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 10-21-2012, 09:03 PM   #72
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,400
Well, as it stands we're running about two weeks behind. As you've seen in the latest pix, we've made quite a few small changes to the tank, and I think all will agree it's even better than before. I'm pretty pumped with the improvements and they're easily worth the short delay. We'll be at the foundry his week and from there the machine shop will install the tooling for the fuel filler and all the nutserts.
On another note, I've been working with Chip Munn to source all the OEM KTM mounting hardware. We've got everything in stock with the exception of the lower tank mounts. KTM has them back ordered until the end of November. I've reached out to all the larger parts supply houses looking for some inventory, but no luck. I'll keep on it and let you guys know if I find another source for these parts.
~ Ken
Old 10-23-2012, 03:38 PM   #73
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 3,075
I've been thinking about how and where to install quick disconnects near the petcocks for quicker/easier removal and install of the tank, but I might have thought of a better way. Better until someone gets in gear and starts making the CPC connector PowerCell showed earlier in the thread that replaces the petcocks entirely, that is!
We need to extend the crossover line anyway. How about cutting the longer part of the crossover line, to the right of the Tee that goes to the fuel pump, and then installing a double-shutoff CPC connector there? You would have to fish the right side line in front of the front cylinder, but it would mean you only have to deal with two quick disconnects to install/remove the tank. One on the crossover line and one to the carbs. You wouldn't have to remove the line from the Tee to the fuel pump each time. The fuel pump and crossover system would come off with the tank.
The only things I'm not sure about with this configuration are:
1. How hard would it be to fish that line through each time?
2. Would a double-shutoff CPC connector flow enough to keep up with the demands of the pump/carbs/engine?
Old 10-23-2012, 03:45 PM   #74
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,400
Hard...
Yuuup...
I never liked the crossover in the first place. I recomend dumping it and running both sides to a Y connector in the valley between the carbs. The fuel pump can lift the fuel the few inches needed.
As a side note, I'm actually getting ready to do a first run build of my quick release connectors. I've worked things out with Colder Products on sourcing the needed parts and our first build will be 100 sets. No price or delivery date just yet...
~ Ken
Old 10-23-2012, 03:49 PM   #75
Splisken
I'm not dead yet...
Splisken's Avatar
Oddometer: 127
Count me in on the quick disconnects when you do get that far...#1 in!
Times are GMT -7.   It's 05:40 AM.
