10-23-2012, 10:35 AM
#25741 |
Aven'Tourer
Oddometer: 9,704
thats another good point... I dunno what bike you have, but if it came with 35c tires, its likely some sort of hybrid? it probably doesn't have the best of rims unless it was a rather high end hybrid. 110 or 120 psi may be more than those rims are designed to handle (since a 35c tires is more like 70 psi). another factor is, the hybrid probably rides a little 'heavy', so its not as easy to 'unweight' (half jump) going over cracks, bumps. the worst, IMHO, are uneven pavement blocks, where you're hitting a sharp lip thats maybe 1 inch high, if you don't bunny hop over those, you can flat almost anything short of a big mountain tire, and maybe even taco your rim.
Experience is what you get when you don't get what you want. |
10-23-2012, 12:41 PM
#25742 |
Oddometer: 2,442
Be sure to rotate your tires front to back (rear wears faster), as well reverse the rotation (left side wears faster, due to crown in the road), to get the most mileage out of them.
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
10-23-2012, 12:54 PM
#25743 | |
Iron toocus
Oddometer: 927
I have been running the Michelin 700x25 slicks at 116 psi since having them on. Ducnut, thanks for the rotation info. I had no clue! Wish I had not bought a replacement rear now that I want a bigger tire. Maybe the LBS will take it back.
2009 Aprilia SR50 R Factory 2012 Bont Vaypor Custom 2pt My drivel \/ http://chillislives.blogspot.com/ |
10-23-2012, 01:02 PM
#25744 | |
Aven'Tourer
Oddometer: 9,704
CX rims are usually more like 18mm inner. I'm kind of amazed someone spooned a 35mm wide tire onto a 14mm wide rim.
10-23-2012, 01:08 PM
#25745 | |
Iron toocus
Oddometer: 927
The 700x35 were knobbied at the edges and less so in the middle. So 28 instead of 32?
10-23-2012, 02:00 PM
#25746 | |
Aven'Tourer
Oddometer: 9,704
right now, I'm on 35's, I'm 210 lbs (down from 230), overweight /and/ lazy... when I get in better shape and wear out these 35s, I'll probably go 32 for one set, then if/when I get new wheels with better rims, I'll maybe end up on 28s. or get a new bike, I dunno. I like the 35s off pavement too, they aren't as likely to go nuts on a rock or whatever on a fire road.
10-23-2012, 02:45 PM
#25747 | |
Obstacle Allusion
Oddometer: 5,150
10-23-2012, 03:00 PM
#25748 | |
Once you go Triple...
Oddometer: 20,409
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
10-23-2012, 03:58 PM
#25749 | |
Obstacle Allusion
Oddometer: 5,150
![]() Get a few more miles out of the tires that way. I noticed that the Schwalbe Marathons are directional, but I don't know if reversing the tread would have any major effect. I did the swap on my Gatorskins and damn near wrecked trying to stop fast. Once they're worn now, I just replace them. But I've been able to extend the life on a many a set of Hutch's, Mich's and Conti race tires by swapping front to back and flipping the tire on the wheel. |
10-23-2012, 04:05 PM
#25750 | |
That's MR. Toothless
Oddometer: 25,549
![]() Did 4:25 on the bike today. 2 assholes. Both in/near Warrenton. That last 90min was teh suck. Legs are VERY tired after the week I've had. M
There. I've moved back to VA. Can you PLEASE change the weather?! |
10-23-2012, 04:14 PM
#25751 |
Aven'Tourer
Oddometer: 9,704
tread on bicycle tires does zilch on the pavement. you don't need rain grooves with a skinny round profile tire, you aren't going to hydroplane.
heck, slicks even work pretty good on hardpack dirt. they only suck in soft or loose stuff. so "directional" on bike tires, which are bias ply, is purely cosmetic.
10-23-2012, 04:39 PM
#25752 | |
Obstacle Allusion
Oddometer: 5,150
10-23-2012, 04:41 PM
#25753 | |
Obstacle Allusion
Oddometer: 5,150
I'll just continue to ignore it. |
10-23-2012, 04:49 PM
#25754 |
Aven'Tourer
Oddometer: 9,704
he's got a point., a front blowout at speed is skeeery, especially in a turn. I left quite a bit of road rash on Laureles Grade near Carmel Valley once when my front sew-up ("tubular" to you kids) came unglued at speed.
10-23-2012, 09:46 PM
#25755 |
Ancien
Oddometer: 16,345
| Thread Tools | |
