Old 10-23-2012, 07:18 AM   #13426
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
Originally Posted by kaukasion View Post
still lost i pulled the carb back off my 96se today and cleaned it good
carefully reassembled everything
and still the same problem
just no top end power
it literally even in neutral feels like its got a rev limiter keeping it at 6-6.5 k u can pin the throttle and thats all it will rev to
i tried with tank cap removed, installed a clear fuel filter to check fuel flow and its staying full and flowing good, i tried without air filter no change, choke on or off same thing, only with it on get exhaust popping on top of it
brand new iridium ngk plug
carb cleanered everything completely removed everything and cleaned and sprayed out with compressed air
i thought it was my slide diaprahgm but i know its seated correctly used some shallac on it to be sure it stayed in place this time
im lost guys any idea's? its a totally stock bike with the stock jet sizes (both jets brand new)
hadnt ran in 3 years, and will only do 50mph grrrrrrr
It has to be something with your carb. What elevation are you running at?
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 10-23-2012, 07:37 AM   #13427
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,878
Are you sure the slide diaphragm doesn't have any holes or splits in it?
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 10-23-2012, 08:16 AM   #13428
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,696
[QUOTE=MadChap;19878725]It wasn't really that hard to build them. I bought some steel tubing at Home Depot. Cut about a 4-5 inch circle out of some 1 inch plywood. Screwed the circle to my bench top, and put a lag bolt next to the circle to hold the tubing tight to the circle. Then simply bent the tubing until I had the shape I wanted. Didn't even have to heat up the tubing. Also bent the cross pieces to stand off from the side covers from the same material. Welded some 1 inch flat bar on the ends to mount under the fender and on the passenger foot peg. I should have used angle iron instead of flat bar. Used U-bolts (cut short) as tie points on to bottom outside corners.
I don't have a welder so a friend welded it up. Truly, it was an easy job that took about an afternoon once I had all the supplies.
Thanks for info! Looks great
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is online now   Reply With Quote
Old 10-23-2012, 10:29 AM   #13429
kaukasion
Oddometer: 24
no holes or rips in the diaphragm i look at it over a light to see and took my time and made sure it was mounted with a good seal
it never bogs out if i ride at wide open so im thinking its not running way rich or anything, and it doesnt appear to be running lean because i dont get surging
also how many turns out should the idle mix screw be? i have it at two and it starts and idles fine till it warms up then it wants to drop and bog till it dies and im thinking i have it too rich maybe?
this is frustrating the crap outta me because this is the third time ive had this thing apart and im running out of idea's on what it could be and im relying on this bike as my only means of transportation to get to work right now :( ive hit a tough spot financially and dumping money into this thing like a pit is killing my savings for a car as well
elevation is around 100 above sea level
kaukasion is offline   Reply With Quote
Old 10-23-2012, 10:38 AM   #13430
MrPulldown
MrPulldown's Avatar
Oddometer: 3,257
DR350 carbs are either BST33 or TM33's. 33 is 33millimeters. Where?
THere was a write up, on here, max or TT, I can't remember or find it now. It compared the two carbs and had measurements of the bores and outside of the intake side, etc. Anyone have a link.
I have a BST (CV) carb that I hope is a 31mm, for a DR250. Don't know how to check unless I pull my carb which I DO NOT want to do jsut to take a measurement .
If anyone has a link to that write up that would be AWESOME!!
MrPulldown is online now   Reply With Quote
Old 10-23-2012, 11:10 AM   #13431
motolab
motolab's Avatar
Oddometer: 2,624
What is (are) the exact throttle position(s) during which the symptoms occur?
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-23-2012, 01:47 PM   #13432
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,465
I don't have a manual. Does anybody have information on quantity and weight for fork oil for a '97 DR350SE?
The future is bright, fruitful, and positive.
Old 10-23-2012, 04:11 PM   #13433
kaukasion
Oddometer: 24
Regards,
Derek
wide open throttle, bike seems to run great in all midrange and pulls well, just will not rev past 6k and in 5th 6th gear doesnt have the power to even pull them out to 6k and im having some idle issues but im sure i just have mixture screw wrong but i have the extended one so i need to tweak it
Old 10-23-2012, 04:56 PM   #13434
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 517
front fork oil type Fork Oil SS05
front fork oil capacity (each leg) *495 ml (16.7/17.4 US/Imp oz)
Sent from my SPH-D700 using Tapatalk 2
tonusmaximus is offline   Reply With Quote
Old 10-23-2012, 05:00 PM   #13435
motolab
motolab's Avatar
Oddometer: 2,624
In a previous post you said that "it never bogs out if i ride at wide open". Which is it?
Regards,
Derek
Old 10-23-2012, 05:01 PM   #13436
tonusmaximus
maximus
Oddometer: 517
10 weight is what manual calls for
Old 10-23-2012, 05:12 PM   #13437
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,465
Thanks for the information.
Old 10-23-2012, 05:58 PM   #13438
kaukasion
Oddometer: 24
Regards,
Derek
i mean that it doesnt feel like its running rich and going to foul the plug at wot
but it doesnt seem to be running lean either it just seems to have no more power at wot as it does at high mid throttle
its the strangest thing but with this being stock and a brand new main jet that is stock size im just scratching my head at this point, im missing 20mph and cant find it, it really feels like maybe the slide cannot come all the way up or something, but when i look it over it appears nothing is wrong with it
Old 10-23-2012, 06:13 PM   #13439
kenaroo
I am because i ride
kenaroo's Avatar
Oddometer: 856
Hey guys.. I have a. Boxed in swing arm and a race tech shock that I never installed on my dr350 before I sold it.. If anyone is interested pm me.
what does your garage look like
http://www.garage-interiors.com
kenaroo is offline   Reply With Quote
Old 10-24-2012, 08:10 AM   #13440
motolab
motolab's Avatar
Oddometer: 2,624
Does the problem change relative to engine temperature?
Regards,
Derek
Times are GMT -7.   It's 11:01 AM.
