Old 10-23-2012, 06:44 PM   #4321
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,366
Thick O-Ring
Originally Posted by blake716 View Post
Okay, I had that bass ackwards.
I'm goint to install the kit when I get off of work today.
What about the accelerator pump o-ring.....should I use the thick or thin o-ring?
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 10-23-2012, 07:12 PM   #4322
blake716
nine toes
blake716's Avatar
Oddometer: 12,661
Originally Posted by Indy Unlimited View Post
Thick O-Ring
Thanks.
I set everything up just like the directions said, but I haven't tried it out yet. My air filter was torn. Not sure how that happened.
I have to go to the KTM shop tomorrow to pick up a new air filter and a few more parts, then I'll see how it runs.
_________________________
blake716 is offline   Reply With Quote
Old 10-24-2012, 07:05 PM   #4323
blake716
nine toes
blake716's Avatar
Oddometer: 12,661
I got to ride my bike some today since I re-jetted it. When I turn the throttle real quick, it bogs a little. Even died a couple of times.
I can roll the throttle on a little slower and it comes to life. When the bike is moving and I stab at the throttle and it's pretty crisp.
What should I adjust?
It's set up exactly like the instructions said:
Red needle, 5th clip down, stock pilot, and 170 main.
I put the large o-ring on the accelerator pump, and put the spacer on the diaphragm.
On a side note, my tank came in today. Holy hell, that thing is HUGE.
Here it is from another angle.
Old 10-24-2012, 08:32 PM   #4324
Tusker
Tusker's Avatar
Oddometer: 847
Blake,
I have the 6.6 gal tank, too, and it's really not that big when you get it on the bike. One thing that helps is that it's thin between your legs when standing, so it feels pretty normal.
I noticed in the picture that your chain looks extremely tight. You need to run it quite loose on these bikes or you will run into countershaft problems. Many guys take the shock out and adjust the chain by running the rear wheel through all it's travel to make sure you don't have a tight spot.
'06 KTM 525 EXC
'12 KTM 500 XC-W
'12 KTM 300 XC-W
Ethiopia Trip 2010
Tusker is offline   Reply With Quote
Old 10-24-2012, 09:21 PM   #4325
blake716
nine toes
blake716's Avatar
Oddometer: 12,661
I adjusted it yesterday.
You even had me second guessing myself. It does look really tight in that picture. Maybe the angle...
I just went out in the garage and checked it.
When I first got the bike, I had to pull the shock off to remove the head pipe.
When I did that, I jacked up the swingarm where it was pointing right at the countershaft and adjusted it with 10mm of slack.
After I put the shock back on, I took the bike off of the stand and put 2 marks on my wrench so I'd know how much slack to leave
without having to remove the shock when it was time to adjust the chain again.
Good observation though. I have new sprockets and a chain ordered too, just in case you notice the piss poor condition my rear sprocket is in.
Old 10-25-2012, 11:38 AM   #4326
socaltrailrider
Oddometer: 91
I had the same problem on my 525. Shoot JD an e-mail and he will give you an adjustment. It's been awhile and i can't remember what he told me, but it did work. I'll see if I can dig up the e-mail.
2009 BMW K1200LT
KTM 300XC
KTM 525 EXC
socaltrailrider is offline   Reply With Quote
Old 10-25-2012, 05:53 PM   #4327
Indy Unlimited
Oddometer: 1,366
You need to adjust the timing and duration of the AC Pump"
Here is what works and it is easy to explain:
http://www.thumperfaq.com/mxa_ap.htm
Current Stable:
Old 10-25-2012, 07:19 PM   #4328
blake716
nine toes
blake716's Avatar
Oddometer: 12,661
Lots of good info there. Thanks.
Old 10-26-2012, 09:20 PM   #4329
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,695
wth?
on my 07 there appears to be a decompression lever on the head. no cable attached, no provisions for it on the clutch.
vestigial? or does this actually have some use?
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 10-26-2012, 11:55 PM   #4330
crazybrit
crazybrit's Avatar
Oddometer: 8,559
Originally Posted by clapped_r6 View Post
wth?
You don't really need it (it's not an LC4). You have the Brembo clutch. It's master cyl lacks the mount point for the decomp. For some reason they switched from Magura to Brembo for the 2007. Fiche is wrong, it still shows Magura slave on engine page. Handlebar controls page is correct, shows Brembo. Just remember you *must* use Brake Fluid. If you insist you can install the brembo hot start master cyl cover (oem or hardparts) and hot start lever (pm me if you want part#s) or loop a long zip tie through the connection on the side of the motor.
I put a Magura on my 07 as the Brembo had way more pull effort compared to my old 05 (even with one of the shorter cLever levers). Now have some minor slippage when pulling away in 1st in soft stuff, not sure what's going on. I measured the push rod and it's same as the (incorrect) engine fiche page.
crazybrit is offline   Reply With Quote
Old 10-27-2012, 08:47 AM   #4331
Jackazz
Jackazz's Avatar
Oddometer: 828
Originally Posted by crazybrit View Post
You don't really need it (it's not an LC4). You have the Brembo clutch. It's master cyl lacks the mount point for the decomp. For some reason they switched from Magura to Brembo for the 2007. Fiche is wrong.
My 07 RFS I've had since new has the magura clutch master with a single perch so maybe that was changed to brembo mid year like the locking lever I found out about the hard way (check yours, its a 10$ part that's easy to get to).
The 2007 has the internal auto decompression that's always worked flawlessly for me but some guys have used a zip tye on the engine lever to help clear it out, Maybe they crash a lot or ride in a bunch of water?
Jackazz is offline   Reply With Quote
Old 10-28-2012, 05:45 AM   #4332
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,471
The 525's been surging a bit lately... someone suggested that the front sprocket might be hooked. Doesn't look bad enough to cause that though, does it?
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is online now   Reply With Quote
Old 10-28-2012, 06:47 AM   #4333
blake716
nine toes
blake716's Avatar
Oddometer: 12,661
^^^ Looks fine to me. Barely starting to break in.
Old 10-28-2012, 06:50 AM   #4334
The Bigfella
Big Adventurer
Oddometer: 2,471
Excellent. Thanks mate.
Old 10-28-2012, 07:23 AM   #4335
Indy Unlimited
Oddometer: 1,366
looks fine for a belt drive!
Current Stable:
Times are GMT -7.   It's 04:00 PM.
