Old 10-26-2012, 04:42 AM   #17596
UnsureFooting
Title of User Here
UnsureFooting's Avatar
Oddometer: 6,354
And that torque curve you showed me isn't all that flat. There's a 40 ft-lb difference between those lines. The graphic is being squashed by the scaling.
Because so much is riding on your tires.
UnsureFooting is offline   Reply With Quote
Old 10-26-2012, 04:43 AM   #17597
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,948
Originally Posted by UnsureFooting View Post
Uh-huh. I know. Low rpm is definitely not 4k. If you have to wait until 4k for power, that's not a low rpm engine. The big twins are excellent for riding in situations that require lots of speed changes, because you don't have to shift constantly to stay in the power band. They're not road racing super stars, no. They're for practical riding at a practical pace.
When 4,000 is less then a 1/3 of you tach it certainly is.
...and I just showed dynos for THREE bikes that you don't have to shift much at all. Even on "peaky" bikes like an R6 you run the bike at 9,000-10,000 and pick the gear for the road you are on and you don't have to shift bloody much. That R6 has a 17,600rpm redline.
Like I said its a matter of extreme.
Four grand is a lot if you can only turn 5,500, its nothing if your redline is 5 figures. On my 675 I rarely come out of 2nd gear below highway speeds, and I mean interstate highway speeds.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 10-26-2012, 05:03 AM   #17598
Benesesso
Benesesso's Avatar
Oddometer: 9,898
If you don't believe long stroke twins have a flatter torque curve than short stroke fours, you don't know much about engines.
Short stroke engines have two huge advantages over long stroke ones. Tripped1 has already identified one of them. The other is that larger valve sizes are possible.
The only advantage a long stroker has is narrowness.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 10-26-2012, 05:05 AM   #17599
UnsureFooting
Title of User Here
Oddometer: 6,354
There's a difference between low rpm engines (which is what I said) and low rpm for a particular engine. Bash away all you want on the long stroke twins, it just makes you look like an idiot.
Old 10-26-2012, 05:12 AM   #17600
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Long stroke engines must be respected, they won World War 1 for us.
Old 10-26-2012, 05:19 AM   #17601
UnsureFooting
Title of User Here
Oddometer: 6,354
They have a place. Not everybody wants zip around at 6k rpm.
Old 10-26-2012, 05:28 AM   #17602
dbuzz
Citizen of the world
Oddometer: 1,267
I prefer long strokes over short strokes ....
dbuzz is offline   Reply With Quote
Old 10-26-2012, 05:29 AM   #17603
greasyboy
cur·mudg·eon
greasyboy's Avatar
Oddometer: 1,767
Originally Posted by Fe Man View Post
Clearly, you have never been in a long line of Harleys...
I usually pass em!!!
On my Harley
greasyboy is offline   Reply With Quote
Old 10-26-2012, 05:33 AM   #17604
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,943
But the important question is, what is the airspeed velocity of an unladen swallow?
Ah yes, pictures--
Old pfarts with attitudes:
Apropos, no?
--Bill
'73 R60/5 Toaster
Old 10-26-2012, 05:38 AM   #17605
Jim Moore
Jim Moore's Avatar
Oddometer: 13,910
Originally Posted by Tripped1 View Post
divided by 5250 ...but yes.
Power = torque x rpm
Horsepower = torque x rpm / 5252.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 10-26-2012, 06:26 AM   #17606
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,948
Fair enough.
Old 10-26-2012, 06:29 AM   #17607
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,948
If 6000 is the speed limit its not zipping now is it?
......and where did I bash anything. I stated that long strokes tear themselves apart at high rpm regardless of configuration YOU are the one inferring that I have an issue with this.
The reason that I don't like Harleys is the air cooling, I don't like airheads. That 1050 I noted is a pretty long stroke for a sport application.
Tripped1 screwed with this post 10-26-2012 at 06:34 AM
Old 10-26-2012, 06:33 AM   #17608
UnsureFooting
Title of User Here
Oddometer: 6,354
Sure it is. I wasn't talking about the speed as much as the character of the motor.
Old 10-26-2012, 06:36 AM   #17609
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,948
Less than half of the tach, same as a big twin going 2000.
Zinging is 10 grand, now you are going somewhere.
Old 10-26-2012, 06:59 AM   #17610
DAKEZ
DAKEZ's Avatar
Oddometer: 19,740
Yes they have there place... That place is a firmly established vast majority of bikes on the road over 600cc.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Times are GMT -7.   It's 05:49 AM.
