Old 10-25-2012, 08:28 PM   #3766
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,144
Is the bike actually running?
Doesn't sound like the doo to me, if that goes, it usually takes out the top end and nothing runs.
My KLR650
Matt's Trippin' in Peru
sandalscout is offline   Reply With Quote
Old 10-25-2012, 08:38 PM   #3767
FJracer
FJracer's Avatar
Oddometer: 77
Motor humming along smooth. Just no gear to find in tranny. I'm thinking maybe a shift rod, 'cause I'm not sure I got a solid downshift into 4th. Seems like it disengaged as I powered up a steep hill. I rolled to a stop at the top and tried to find a gear. None.
FJracer is offline   Reply With Quote
Old 10-25-2012, 08:42 PM   #3768
sandalscout
blah blah blah
Oddometer: 2,144
Yeah, definitely not the 'doo then. I know next to nothing about motorcycle transmissions, any chance it's clutch related?
My KLR650
Old 10-25-2012, 08:43 PM   #3769
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,260
Probably the shift fork if I were to guess.
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 10-25-2012, 08:44 PM   #3770
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,430
Stripped your counter shaft splines.
Where the fuck...
Where the fuck is the bike?
You gotta be shitting me.
Where the fuck is the road?
Old 10-25-2012, 09:03 PM   #3771
FJracer
FJracer's Avatar
Oddometer: 77
Bluhduh
Well that doesn't sound good at all! I thought these Bikes were suppose to be "Bulletproof"!!!
Old 10-25-2012, 09:32 PM   #3772
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,430
There is no such thing.
I know in the 10,000 miles that I had my KLR the counter shaft splines showed a decent amount of wear. Some of the Single 650 GS's have stripped their countershaft splines and place the blame on aftermarket sprockets that are too hard and wear the shaft splines down instead of wearing the sprocket splines.
I'm just guessing though, but it's pretty easy to determine if the counter shaft is turning, just pull that sprocket cover off.
Where the fuck...
Old 10-25-2012, 09:32 PM   #3773
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,260
"Bulletproof" cracks me up. Most everyone says every bike they own is "pretty much bulletproof".
Old 10-25-2012, 10:26 PM   #3774
Aprilia
Oddometer: 673
Sounds like the shift pawl spring. I've replaced two of them this year in my shop for other riders. No big deal...removed right side cover to verify. You'll need outer case and waterpump gasket as well. Good time to clean the oil screen too.
Just in case did you get down on your hands and knee's and carefully look over your shift lever and its attachment point to the shift lever. I've seen quite a few factory lever's crack at the weld and not allow enough leverage to turn the shaft.
Aprilia is offline   Reply With Quote
Old 10-26-2012, 08:12 AM   #3775
FJracer
FJracer's Avatar
Oddometer: 77
Daylight Diagnosis
In the daylight, it turns out, I broke the drive chain. Problem solved..........................kinda! I guess this engine IS "Bulletproof"!!! So powerful it can break a perfectly good chain at full power up a steep hill.
Old 10-26-2012, 09:19 AM   #3776
CA Stu
CA Stu's Avatar
Oddometer: 47,108
Change your chain out sooner next time!
At 23000 miles, I'd be thinking about chain number 3!
To be honest, I broke a chain on my KLR once, too. 13,000 miles on the chain and a nice big rock between it and the rear sprocket and ka-pow!
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 10-26-2012, 09:22 AM   #3777
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,260
23k on stock chain and sprockets? Yes you need to change sooner. Get new chain and sprockets.
Old 10-26-2012, 09:28 AM   #3778
Aprilia
Oddometer: 673
Good grief...really? Thats 5 min of my posting life I'll never get back.
On a serious note...engine that is 'bullet proof' is a direct correlation to the owners ability to properly maintain much less just keep oil in it.
Old 10-26-2012, 11:34 AM   #3779
FJracer
FJracer's Avatar
Oddometer: 77
Thanks for the advice BUT I don't remember telling anyone that was the original chain. In fact it was reasonably new EK as well as the sprockets. I bought the Bike in Aug. with 22K on it. Previous owner stated chain fairly new. And that was verified when the front sprocket was swapped out. The 15T I put back on was the original and it looked good to me ........... at the time. In retrospect, I may replace that one..................or both. I recovered the Chain just a moment ago when I came back for Dr. appointment. One link just broke.
Old 10-26-2012, 11:36 AM   #3780
CA Stu
CA Stu's Avatar
Oddometer: 47,108
Master link?
Times are GMT -7.   It's 03:23 AM.
