10-14-2012, 05:18 PM
#1651 | |
Stuck @ Home! >=^(
Oddometer: 1,091
The 160 on my bike is one of the narrowest available.I'll have to give the 150 a try.
Manic Cycles=My Facebook Page |
10-15-2012, 03:44 PM
#1652 |
Oddometer: 3
OK I am hooked. Going to start collecting parts for my own build. I took invintory of my parts pile and found I have a front end from a 92 YZ125 with I believe a 17mm axle and a slightly beat up DL650 front rim, also 17mm axle. My concern is the YZ forks won't be up to the task on the heavery Versus, even if built up.
Anyone have any thoughts? Find a better front end or try to build up the old YZ forks ? Like most cost is a concern but I am OK with spending some if its for a good cause.
10-15-2012, 05:41 PM
#1653 | |
Gravel Runner
Oddometer: 2,773
plenty of reading in a good selection of build threads on the forum, so by the time you get through those, you'll have a good handle on the issues |
10-16-2012, 08:46 AM
#1654 | |
Oddometer: 3
The DL650 wheel is a little beat up but good enough for what I need right now. Been reading all night on things, just need to pick a path now. Thanks for your detailed write up, it was an awesome read! |
10-16-2012, 12:57 PM
#1655 | |
Gravel Runner
Oddometer: 2,773
a little reminder, it's tough to find a 20x40x12 bearing to fit a DL650 wheel if you wanted forks which use a 20mm axle, and even if you did, i'm not sure how rugged it would be for use as a wheel bearing. |
10-18-2012, 09:00 AM
#1656 |
Oddometer: 3
Only question right now is how to be patient trying to find a decent donor bike!
I agree the 17mm axle is not idea but a machinist friend seems to think he can make a different bearing work if needed. We will see if I go that route or find something different. |
10-22-2012, 06:44 AM
#1657 | |
Gravel Runner
Oddometer: 2,773
there was a set of used Dl1000 wheels for sale in the ADV flea recently if anyone wanted matching three spoke cast wheels in 19/17 for their build. don't know if they were sold or not. there are still many people who don't think cast wheels should be the choice for these bike builds, but these wheels work great if you're building a gravel runner. just home late yesterday after after a 1400 mile ride through northwest Virginia, western Maryland, and eastern West Virginia with hundreds and hundreds of miles of gravel roads, some very rough 4x4 only conditions and the V649HP ran flawlessly, cast wheels and all. slab home at 80+mph cruise, try that on a 650 thumper loaded down with gear.
10-24-2012, 11:37 AM
#1658 |
Oddometer: 144
JD - You are in and travel in 2 of the top 10 states (VA and WV): http://www.statefarm.com/aboutus/_pr...inia-again.asp
Oh deer! er . . . ah . . . dear!
2004 V-Strom 650 2nd time 'round 2006 Tiger - sold 2004 ST1300 - sold 2005 V-Strom 650 - sold 1985 Honda V700 Magna - sold |
10-24-2012, 01:11 PM
#1659 | |
Gravel Runner
Oddometer: 2,773
traveling a wide area like last week, it's interesting to see very different color on the deer, with deer in one area very dark charcoal gray, while deer in another area are sandy brown. |
10-24-2012, 03:40 PM
#1660 |
Gravel Runner
Oddometer: 2,773
10-26-2012, 11:02 AM
#1661 | |
Oddometer: 155
to hold a few extra liters of gas. I haven`t looked in to it yet, just thinking about it. What do you think? |
10-26-2012, 01:40 PM
#1662 | |
Gravel Runner
Oddometer: 2,773
i already have a design and parts, i just need the time to get going on it. |
10-27-2012, 11:46 AM
#1663 | |
East Coast Rider
Oddometer: 482
10-27-2012, 04:41 PM
#1664 | |
Gravel Runner
Oddometer: 2,773
if ya need something specific, i can try to get a photo. |
10-27-2012, 05:05 PM
#1665 |
Gravel Runner
Oddometer: 2,773
when i said the OEM fender assembly isn't up to the pounding it gets on rough gravel roads, here's why.
the left and right seat covers are connected to the tail light with plastic dowel tabs that slide into rubber grommets on each side of the tail light. these eventually shear off because the assembly flexes too much. ![]() the dowels are supposed to slide into these grommets. ![]() when the dowels break, pairs of plastic tabs on the bottom of the seat covers have to carry more load, and eventually these break too. broken tab on the seat cover ![]() all the plastic pieces around the tail light have to be securely anchored so that the plastic trim piece over the top of the tail light aligns with it's own tabs, impossible with all the other broken tabs and dowels. ![]() so the dowels break, the tabs break, the trim won't fit, and the whole freakin' mess starts lookin' like it's going to crack in half after just one more rough road. time for something new. |
