Thread Tools Search this Thread Rating: Thread Rating: 430 votes, 4.94 average. Display Modes
Old 10-25-2012, 10:50 AM   #5686
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,839
Originally Posted by Jon_PDX View Post
Maybe you all know this already but I didn't so I thought I would pass along what I discovered.
While I was playing around with Basecamp on my PC I noticed my iPhone was showing up under devices. When I clicked on it all my phone images showed up on the map.
I did not know Basecamp would do that. And the more I zoom in the more images start showing up in the map.
If you click on them it gives the GPS location and will let me mark them as a way point.
I figured images I take with the Montana would do this but was surprised the iPhone images did
Jon...
I don't see my iPhone under devices... and it is connected. Do you have any Garmin software installed on the phone?
Old 10-25-2012, 10:52 AM   #5687
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,839
Originally Posted by cablebandit View Post
You have the shaded relief turned on on the Montana.
I think what he meant was that the map on the gps, as seen in Basecamp, gave DEM data but the one installed on the computer did not. At least that's how I understood the problem. Not that I have a solution, mind you.
Old 10-25-2012, 07:38 PM   #5688
jconly
jconly's Avatar
Oddometer: 425
Originally Posted by DRTBYK View Post
First, can we assume you meant, "Show on Map" vs. "View Map"? Second, how many points are in your Track/s that is "disappearing at one point"?
Have you tried navigating the Track rather than just following one that you have set to "Show on Map"?
Cheers,
Correct assumption yes...
And what i meant by dissapearing at one point.. I meant that the entire track would just disappear randomly from the map.
I haven't tried navigating it no, because I'm navigating a direct route, and am using the track underneath as a more accurate breadcrumb. For some reason today, it showed up just fine, and held all day. I don't think theyre excessively big at all either. They're the track files from the TET, split into days. Only one set to be shown on map at once.
On a side note, is there a way to calculate the distance between points on a track? Or from your current location to the end of that track? That is, not just a direct line, but one that follows that path?
jconly is offline   Reply With Quote
Old 10-26-2012, 06:20 AM   #5689
Jon_PDX
Oddometer: 1,107
Yes that's what I meant.
All viewing was done in Basecamp. I checked my Montana just now and in the map setup / advanced it has "shaded relief" set to "auto".
It would be nice if the map loaded on the computer would show the DEM data too. I was hopping there was a setting in Basecamp to enable that feature.
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 10-26-2012, 06:32 AM   #5690
woodsatyr
Kitty Boy
woodsatyr's Avatar
Oddometer: 495
This happens on mine too. I'll look at the map and the track I just drove will be gone. It'll start showing up again and disappear in random sections. It becomes a problem when you're trying to navigate a track that has disappeared.
woodsatyr is offline   Reply With Quote
Old 10-26-2012, 06:44 AM   #5691
Jon_PDX
Oddometer: 1,107
Nope as far as I know there is no Garmin software installed on the phone.
iPhone 4s - IOS 5..1.1
Windows 7 - Basecamp 4.0.2
I have a lot of images on the phone so it took awhile to load them. But the phone it's self showed up within 1-2 min's after I plugged it into the computer.
Here is a screen shot
Just for fun I plugged in one of my cameras and it also shows up. But..... Basecamp tells me that there is no data available even though there is a DCIM folder.
I suspect since the images on the camera do not have any location data embedded in them like the iPhone does Basecamp just ignores those images.
But that's just a guess.
Hope that helps,
Jon...
Jon_PDX screwed with this post 10-31-2012 at 06:45 AM
Old 10-26-2012, 10:44 AM   #5692
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
I have a lot of images on the phone so it took awhile to load them. But the phone only showed up within 1-2 min's to show up after I plugged it into the computer.
I suspect since the images on the camera do not have any location data embedded in them like the iPhone it Basecamp just ignores those images.
Hope that helps,
Jon...
None of my iPhones are displayed in BaseCamp. I am running the latest firmware and versions on WIN XP.
atlas cached is offline   Reply With Quote
Old 10-26-2012, 11:05 AM   #5693
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,979
My iPhone 4 w/ iOS5 showed on my Windows 7 BC. But now I'm all Mac and of course no Mass Storage Mode allowed for iPhones (at least not my iPhone 5).
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 10-26-2012, 12:12 PM   #5694
BogeyMan
BogeyMan's Avatar
Oddometer: 454
My iPhone 4 w/ iOS5 showed on my Windows 7 BC. But now I'm all Mac and of course no Mass Storage Mode allowed for iPhones (at least not my iPhone 5),
True, but the easiest way to pull images off the iPhone (any version) on the Mac is via Image Capture. When you import, you can import all or just selected and choose whether to leave on the phone or delete.
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 10-26-2012, 12:24 PM   #5695
DRTBYK
DRTBYK's Avatar
Oddometer: 5,979
I'm an iPhoto user. Does the same thing.
Cheers,
Cheers,
Dan
All Things GPS
Old 10-26-2012, 01:59 PM   #5696
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,813
iOS 6
BC 4.02
WIN 8 (just got it loaded up)
I can see my iphone and the pics on the map in Basecamp.
Old 10-26-2012, 02:07 PM   #5697
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,813
Cheers,
As does LR4.
Old 10-26-2012, 04:49 PM   #5698
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,839
Cheers,
I guess that's my problem too - I'm using a Mac. I have Windows machines here too but I don't think it's worth using Windows just for that reason.
I usually use Picasa to import photos from my phone.
Old 10-27-2012, 12:06 PM   #5699
ChadHahn
Oddometer: 262
Whenever I plug in my iPhone Nikon Transfer opens up and I can download the pictures from my iPhone with that. I think it also works with the Canon picture software I have. If you have digital camera the software for managing photos will probably work for getting pictures off your iPhone.
Chad
P.S. This is on a Mac
ChadHahn screwed with this post 10-27-2012 at 05:45 PM
ChadHahn is offline   Reply With Quote
Old 10-27-2012, 01:03 PM   #5700
Jon_PDX
Oddometer: 1,107
Cheers,
Yup, just tried on my Mac and it does not show like it does under Win-7.
Interesting there is no Mass Storage mode for iPhones on the Mac. You would think Apple would allow that for one of their products.
So is there a way to import photos I took on my phone into BC on the Mac? I'm assuming any photos I take with the Montana will show up on the Mac or does the lack of Mass Storage mode also come into play with the Montana on the Mac?
Jon...
Times are GMT -7.   It's 01:16 AM.
