Old 10-24-2012, 04:35 PM   #16
LandsVW OP
LandsVW's Avatar
Oddometer: 134
Originally Posted by mcma111 View Post
Hey LandsVW
You might take a look at this thread. It might come in handy.
http://advrider.com/forums/showthread.php?t=713831
I absolutely love reading these technical and well written articles! Can't believe how much I learn.
L
LandsVW is offline   Reply With Quote
Old 10-26-2012, 02:15 PM   #17
LandsVW OP
LandsVW's Avatar
Oddometer: 134
torque specs?
I've downloaded a service manual for the bike however it's from 1988 on. Are the torque specs the same as the older bike? If not, what are they? Cylinder head? Cylinder? Crank Nut? Clutch Nut?
Just checking before I start to assemble.
thanks!
L
Old 10-26-2012, 03:24 PM   #18
RFVC600R
SAND EATER!
Oddometer: 524
thanks!
L
From Clymer Honda XL/XR200-600 1978-1985 printed in December '85. Should be the same as '86 and up.
XL/XR 350-600cc torque specs
'83 Honda XL600R valve seat
RIDE RED!
RFVC600R screwed with this post 10-26-2012 at 03:39 PM
RFVC600R is offline   Reply With Quote
Old 10-27-2012, 11:02 AM   #19
LandsVW OP
LandsVW's Avatar
Oddometer: 134
"From Clymer Honda XL/XR200-600 1978-1985 printed in December '85. Should be the same as '86 and up.
XL/XR 350-600cc torque specs"
Helpful, thanks! I noticed that the torque specs are just a little lower than the later bikes on several bolts, so that may save me problems with over tightening. I saw a picture somewhere on the XR600 forum that compared an old lower timing gear with a new timing gear. Anyone know where that link is?
Also, I have the case halves reassembled. I'm going to fit the cylinder, piston and head today and then check my timing chain like the earlier link suggested... If it seems off then I'll order a new set. I figure do that before I get too far along. The right side and chain can be assembled any time w/ the cylinder/head on.
Old 10-27-2012, 05:43 PM   #20
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,180
I assume it test shifts ok?
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 10-27-2012, 07:39 PM   #21
LandsVW OP
LandsVW's Avatar
Oddometer: 134
Forward - then backward...
As long as I'm spinning the clutch input shaft it seems to shift ok, although sometimes hangs a little by 4th and 5th. If I move the shifter shaft up and down and keep spinning it will shift into those gears. I'm assuming that's because it's not a continuous revolution and the cogs aren't smoothly meshing? I remember having to do that with my other bikes by rocking them back and fourth, engine not running, to get them to shift through the gears so I'm assuming it is a similar issue and not really a problem.
My first 'real' problem: Cylinder bolted on and torqued no probs. Went to install head bolts. Not even up to 'hand tight' and I could feel the rear one near the timing chain spinning. Yep. Stripped threads. Trip to Roseburg! I now have in my possession a M8X1.25 Helicoil Kit, courtesy of O'Reilly Auto. I have enough to do all the threads if it comes to that!
I am using Indian Head Shellac Gasket coating instead of RTV or Copper Spray. I've always had good success with it on these kind of projects.
That's it for now! May go on out to the garage tonight and install a helicoil.
Old 10-27-2012, 10:17 PM   #22
LandsVW OP
LandsVW's Avatar
Oddometer: 134
a little more progress! another setback...
I helicoiled 2 of the headbolts. The other bolt on the right side also decided to let go. Lucky I had a helicoil kit with12 inserts! All torqued to 21 ft/lb.
THEN I put the timing chain on. Yep, definitely stretched... Upper gear looks great. Lower gear has a little wear showing on the teeth, kind of a pattern of streaks from the chain. I guess I'd better start saving for a chain. Anyone have or know of something in a reasonable price range?
Also, I have a lead on a 1987 XL600 that had the cam and lifters go bad. It's going to have to be a trade type deal,
as my budget is limiting out quickly... But, may be my answer to a street legal bike. Parts parts and more parts...
that's it until a chain is in my possession!
Old 10-28-2012, 04:49 AM   #23
mcma111
mcma111's Avatar
Oddometer: 8,167
If you buy that 87 XL600 I have a cam available.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-28-2012, 10:14 AM   #24
LandsVW OP
LandsVW's Avatar
Oddometer: 134
I'll keep that in mind! We are talking 'bang sticks' and other trade items as of today for the XL. If nothing else it may have a good timing chain/gear set up, and a frame that can be titled.
Old 10-28-2012, 10:51 AM   #25
LandsVW OP
LandsVW's Avatar
Oddometer: 134
part numbers for timing chains?
I'm researching timing chains.
Pro-X seems to be quality. I found one with part number 31.1323 listed as 83-87 XR and XL600's on ebay. However,
It may be NOS as the Pro-X catalog has no listing. Anyone know if this is the right chain? Any other chain part numbers for this bike? I really don't want to spend even more money buying the later chain and sprockets...
Anyone know the D.I.D. part number? how about the Wiseco? Any other brands I'm forgetting?
thanks,
L
Old 10-28-2012, 11:00 AM   #26
LandsVW OP
LandsVW's Avatar
Oddometer: 134
thanks,
L
A german site I just discovered is saying that the 31.1323 is a CRF230 (so Ebay is wrong, imagine that!). The chain that fits a 1983-87 XL600 (and I'm assuming that means 86 XR600) is actually 31.1683... Quest continues!
Old 10-28-2012, 12:10 PM   #27
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 594
Those chains on ebay plus the ones sold by XRsonly are the only new chains I know about. I bought mine from XRsonly back when I was rebuilding my two engines.
Funny, the ebay listing for the PROX has the wrong part number in the photo, but the description states the right number.
http://www.ebay.com/itm/HONDA-XL600R...&forceRpt=true
If you were interested in this brand then I'd send them a message through ebay and make sure about the part number they are selling.
The only other option I could think of for finding decent chains is to do the parts search on those other bikes that supposedly have the same timing chain. I'll eventually need another chain for a third engine build I'm planning but I'm not in a hurry to spend money right now either
Other bikes with same chain as listed on the cheap ebay chain listing:
http://www.ebay.com/itm/Honda-XR600R...4a961e&vxp=mtr
SUZUKIS
LT300EH/EJ/EK Quadrunner (1987-1989)
YAMAHAS
XV500K Virago (1983)
XV535 Virago (1987-1997)
XV650 V-Star, All (1998-2005)
Ghost_Mutant is offline   Reply With Quote
Old 10-28-2012, 12:26 PM   #28
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 214
Why do not want the OEM chain?
http://www.powersportsplus.com/parts...1-MK4-601.html
Ivanych is offline   Reply With Quote
Old 10-28-2012, 12:37 PM   #29
Ghost_Mutant
looking for bionics
Oddometer: 594
I thought Borg Warner made the OEM chains for Honda, and the one at XRsonly is also supposed to be a BW chain relabeled as K&L (or so I thought).
http://www.xrsonly.com/dirt-bike-par...da-xr500-83-84
The prices are close enough without shipping added. How much to ship and how quickly would be the determining factor
Old 10-28-2012, 12:51 PM   #30
LandsVW OP
LandsVW's Avatar
Oddometer: 134
Originally Posted by Ivanych View Post
I probably can afford a 40$ chain, but I'm not really able to swing almost 100$ for a chain right now, just money issues...
I found this part number: 82RH2015-118 which is related to: Regina, Tsubaki, Sudco, Morse and I think Borg-Warner.
This chain fits a bunch of other engines, but I haven't tracked that down yet. Actually this quest is kinda fun...
Times are GMT -7.   It's 12:54 AM.
