Old 10-24-2012, 08:27 AM   #13441
nickgindy
Doing it Wrong
nickgindy's Avatar
Oddometer: 2,571
Pick this up tomorrow.
Comes with parts bike and extra parts.
2003 Sv650s; 2012 BMW F650GS; 1999 Suzuki Dr 350se
The Nightmares of Others
In memory of IMPD Officer Perry W Renn. E.O.W July 5, 2014. "I will always get out of my car."
nickgindy is offline   Reply With Quote
Old 10-24-2012, 08:27 AM   #13442
nickgindy
Doing it Wrong
nickgindy's Avatar
Oddometer: 2,571
Old 10-24-2012, 09:26 AM   #13443
MrPulldown
MrPulldown's Avatar
Oddometer: 3,557
Originally Posted by Klay View Post
I don't have a manual. Does anybody have information on quantity and weight for fork oil for a '97 DR350SE?
Down load the manual from Greg bender's website. It states the oil level shoudl be 5.7 inches from the top.
MrPulldown is offline   Reply With Quote
Old 10-24-2012, 11:29 AM   #13444
kaukasion
Oddometer: 24
Originally Posted by motolab View Post
Does the problem change relative to engine temperature?
Regards,
Derek
the wot problem does not matter to engine temp
the idle gets worse when warm (just figured this problem out, i have the extended idle mix screw and for some reason its backing itself out with the vibration of the motor running it was wayyyyyyy rich and when i blip the throttle i can watch it slowly turn out... hmmmm )
kaukasion screwed with this post 10-24-2012 at 12:28 PM
kaukasion is offline   Reply With Quote
Old 10-24-2012, 12:25 PM   #13445
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,721
Nick nice score!
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 10-24-2012, 03:28 PM   #13446
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,978
pull carb, check your stackup, get a new spring & maybe o-ring
plugeye is offline   Reply With Quote
Old 10-24-2012, 04:40 PM   #13447
LawlerClan
Oddometer: 48
Originally Posted by LawlerClan View Post
Nope, not insulted at all.
Did everything you suggested but need to check the gas to the carb. Tank is full of fresh gas and it was run Sunday so figured fuel was not the problem. Ran smooth and the PO started it right up. He was the original owner and about 8 inches taller so probably had an advantage in both kicking ability and havign the technique down.
Suggestions on how to prime?
Got it started with a little gas straight in to the spark plug hole. Even with that it took a few kicks with each one the "cough" of it trying to start got a little better until it fired up. After that, one good kick would get it going.
Took it around the neighborhood for a couple of laps. Been longer than I realized since I rode a similar bike given the feel. Going to be fun though!
Thanks for all the help.
LawlerClan is offline   Reply With Quote
Old 10-26-2012, 01:52 PM   #13448
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
Bolt Dog taking his first ride on a bike.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 10-27-2012, 04:59 PM   #13449
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,957
Phoi!
I just got done reading this entire thread... took me a couple months (taking time out for meals, of course). Lots of good info here, even for 250's.
Hi.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 10-27-2012, 05:58 PM   #13450
Hawker97
HexHead
Hawker97's Avatar
Oddometer: 64
Question
All:
I purchased a DR200SE this summer so my 17 year old daughter could learn to ride and get her motorcycle endorsement. She likes the 200 but it is only a 5 speed and tops out at 50-55 mph. We live in Alaska and she would like to go on some distance rides with me ..... gravel roads etc. I am looking at options for a different bike for her, maybe a 350? She is 5'7" 100 lbs. I would like some advice from 350 owners. The bike needs to be street legal.
Tom
Hawker97 is offline   Reply With Quote
Old 10-27-2012, 05:59 PM   #13451
RuggedExposure
Oddometer: 1,247
Originally Posted by tirebiter View Post
Too cute!
How'd he like the stock suspension??
He complained about it. Said I need to upgrade to an inverted forks. Typical for a German/Japanese dog.
RE Fotowerks
Old 10-27-2012, 06:19 PM   #13452
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,444
Originally Posted by Hawker97 View Post
All:
Tom
Both my kids learned to ride on DR350's and did great , my son now 18 still loves his 350 and can ride the thing anywhere .
Sure there are better more modern bikes available but for a great reliable ,low maintenance ride she couldn't get much better especially since she is used to the DR200 . Do yourself a favor and find a low mileage 98 DR350SE. It is such fun riding with your kids , some of the best memorizes I have .
It is so easy to gear the DR up and down by just changing the front sprocket when she wants to do a little nasty stuff later on.
They are easy to lower too if she isn't comfortable with the height and at 100lbs you wouldn't need to worry about it bottoming .
The weight thing wouldn't worry me cause it sounds like you will be there all the time to pick it up if it decides to take a nap .
Cheap reliable fun !
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 10-27-2012, 06:26 PM   #13453
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 103,047
All:
Tom
My DR350 is dreamy smooth and really, really likes highway riding. I wouldn't hesitate for a moment to tour on it. It's set up for trail riding now. I would change sprockets to bring the highway rpm's down a little. It's a bit tall...you could perhaps lower the suspension somewhat. But my wife is 5'7" and she has no trouble riding it. I already have a touring seat and aftermarket gas tank for it.
Old 10-27-2012, 06:31 PM   #13454
Hawker97
HexHead
Hawker97's Avatar
Oddometer: 64
350
Are most of the 350's electric start?
Old 10-27-2012, 06:32 PM   #13455
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 103,047
A lot of them are not electric start. Look for a DR350SE.
Times are GMT -7.   It's 10:34 PM.
