Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 10-25-2012, 09:26 AM   #9751
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,555
Does it fit up to the OEM can or do you have to have a FMF can?
Yellow Pig is online now   Reply With Quote
Old 10-25-2012, 10:04 AM   #9752
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,890
I had an fmf can on this header, but that same fmf can fit with the stock header. So to me that = it will fit a OEM can.
c.vestal is offline   Reply With Quote
Old 10-25-2012, 11:57 AM   #9753
AKASY
Noob
Oddometer: 2,170
Bunch of Womens Leather Jackets
Posted over on Flea Market--Gear,
http://advrider.com/forums/showthread.php?t=836638
Don't make the mistake of believing everything you think.
AKASY is online now   Reply With Quote
Old 10-25-2012, 10:28 PM   #9754
El Caballo Loco
Pants-free living!
El Caballo Loco's Avatar
Oddometer: 452
My 1998 Pontiac Trans Am on CL
In no hurry to sell it but it's just sitting and doing me no good. I shouldnt have held on to it this long after losing interest in it.
Pics are not recent. Working on recent pics. http://s253.photobucket.com/albums/h...%20Trans%20Am/
For my asking price I will include EFILive, all cables, up to date with 7 credits.
$6,500 OBO. Trade options listed below. Can do pics upon request until I get them in the ad. I'm not in a hurry to sell it, so please don't think you can low ball your way into a deal. At least attempt to wine and dine me with some good haggling.
Buyer pays shipping, tax, title, license. I have a few people I could recommend for good shipping quotes though.
Clear Kentucky Title in my name
The car runs good and pulls extremely hard, but has been a pain to get started lately. Requires a jump and some TLC.
LS1
85,xxx miles
2,xxx miles since all modifications
Car turned 404hp/391tq AT SEA LEVEL. Numbers will be lower here.
At R.P.M. in Garner, NC, the car was custom tuned by Ryan Robinson who also built the fastest Nitrous LS based car and held the record for three years and also built the fastest SUV in the country at the time.
Has not been on the track since it was stock so no times.
Has been in storage since 2008. It has a few rough spots as well as some dust and dirt from sitting inside a dusty shop.
Engine modifications:
5.3l heads, ported, polished, milled to 58cc chambers
Futral Motorsports F13 Cam, 230/232, .595/.585, 112LSA
Comp 918 beehive valve springs
Comp pushrods
Stock rocker arms
Morel lifters
Cometics head gaskets, .042
BBK intake (powdercoated intake)
Ported and polished LS6 throttle body
MTI induction lid
Later LS6 style valve covers (powdercoated black)
Hooker ceramic coated longtube headers
Dual dynomax bullets, dumped at the back of the trans
LS2 Timing chain
LS6 Oil pump
Trans:
The car was originally a six speed but I swapped out to a built TH350. It still retains the clutch mechanism and pedal for the manual trans.
Does not include manual trans.
Built TH350
Coan 4200 custom spec'd converter. I don't know the STR.
B&M hammer shifter
Trans cooler
Steel custom length driveshaft
BMR transmission crossmember (powdercoated red)
Lokar dipstick
Rearend:
The rearend is a stock GM 10 bolt with 3.42:1 gears.
For an extra $1500.00 - A BRAND NEW Strange GM 12 bolt will come with the car. It is narrowed 3" each side, spooled, 33 spline axles, 5/8" lugs, and has an LPW Ultimate aluminum cover with adjustments for loading the main caps.
Suspension modifications:
QA1 coil overs on the front with 275lb. springs
Spohn adjustable torque arm (powdercoated red)
Spohn adjustable cross member brace (powdercoated red)
Spohn adjustable panhard bar (powdercoated red)\
UMI Performance subframe connectors (painted red)
UMI Performance adjustable lower control arms (powdercoated red)
Softer than stock rear springs (from a V6 car)
Factory rear shocks
Factory rear sway bar
Front sway bar removed (no, I don't have it anymore)
Weight removed and no, I don't have any of this stuff anymore:
Front sway bar
Rear seats
Sound system (head unit, speakers)
Heat, to include all ducting and heater controls
AC unit, to include the AC condenser, AC unit on the firewall, and all controls
Power steering system
Traction control system
ABS system
Airbags
Spare tire and jack
Front bumper support
Rear bumper support
Foglights
Front turn signals
Front inner bumpers have material removed
Misc. mods are as follows:
Line lock
Adj. brake proportioning valve
Nitto 555R rear tires with approx. 60% tread left
Front tires have approx. 80% tread
The only trades (and of course cash to even up the trade, either from my side or yours) I will consider are:
950 Super Enduro
The bad:
It is obviously missing a lot of stuff. On one hand it's light. On the other hand it has no options anymore.
It's dirty.
Batteries dead.
Slight oil leak, I believe it's the rear main.
There is a few (less than 5) quarter sized spots on the paint where the clear is looking cruddy.
The paint is about 70% gone on the back bumper where someone ran into me. The bumper brace was out so the bumper popped in and then back out. The bumper is still good, it just needs paint.
The right front fender well has this big hole (about 1.5" in diameter) from the previous owner.
It's missing the coolant over flow tank. When it gets hot, it just bleeds off the excess coolant to the ground.
It needs a battery tie down.
El Caballo Loco is offline   Reply With Quote
Old 10-26-2012, 03:14 PM   #9755
terry.mc
Stop ruining my vacation
terry.mc's Avatar
Oddometer: 5,700
Macbook Pro 15" $500
Hello,
I'm selling my Macbook Pro 15" for $500. This computer is great and works without flaw. Intel 2.4 Ghz Core 2 Duo, 3 GB RAM. The battery is in great shape and holds a charge without issue. The mag safe power adapter is new, and is the updated style, not prone to the issues of the previous generation of power cables.
I've just wiped the hard drive and installed a fresh install of OSX 10.6.8.
The machine does have some scuffs on it from normal use and a ding in the corner (show in the pictures below, does not affect use of the video port at all) There is a small mark on the screen about as big as your pinky finger nail, I documented it well in the pictures below. You really have to be looking for it to see it.
Small ding on the corner
Small oddity in the LCD screen
It's almost impossible to see here
Terry Mc
2010 KTM 530 Six Days
terry.mc is offline   Reply With Quote
Old 10-26-2012, 05:12 PM   #9756
_CJ
Retrogrouch
_CJ's Avatar
Oddometer: 1,707
Bronco's tickets
I've got a couple of Bronco's tickets for sale....
Bronco's vs. New Orleans Saints
Sunday, 10/28
Parking pass included - Lot M
Seats are 3rd level - end zone
$150.00 cash for two tickets plus parking pass ($190.00 face value for tickets and parking pass).
pm if interested
Access to public lands is a right, not a privilege.
_CJ is offline   Reply With Quote
Old 10-26-2012, 06:11 PM   #9757
ginslung
It'll take.
ginslung's Avatar
Oddometer: 231
***SOLD to DirtyDR***
Go Broncos! And a bump...
Originally Posted by ginslung View Post
$100
Canyon jacket up for sale, with zip-in quilted liner. Comes with removeable elbow/forearm, shoulder and back tri-armor. Sent it to Motoport to add the velcro arm tightener-thingies.
I'm 6'3, 200 lbs and the jacket fits pretty well. I'd guess that it would be almost ideal for someone a little bigger and less lanky than me.
Pit zips and ports in the back for venting, but it's element is lousy weather. I wear it in the rain and snow and it's waterproof as far as I can tell. It's a burly jacket, I just don't wear it enough.
I'm in Denver and work near C470 and I-25.
ginslung screwed with this post 10-28-2012 at 05:09 PM Reason: More details
ginslung is offline   Reply With Quote
Old 10-27-2012, 08:06 AM   #9758
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,486
PM on the jacket, must have missed the original post.
06 Ural Patrol
03 R1150 GS Sport/ Friendship II
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
http://www.advrider.com/forums/showthread.php?t=592860
http://dirtydr.smugmug.com/
Proud Member of the Patrol Patrol
DirtyDR is offline   Reply With Quote
Old 10-27-2012, 08:41 AM   #9759
hiflynbrd
I know that shortcut
hiflynbrd's Avatar
Oddometer: 90
Motoport jacket
PM sent
_____________________
04 Ducati 999S, 12 Versys, 08 Can-Am Spyder-SOLD, thank God, , 93 ST1100ABS 132K, 99 ST1100ABS project cafe racer, 93 KLR650, 04 XR650R street legal, 04 CRF500R street legal, 98 KTM 620 Supermoto street legal-SOLD at the suggestion of Honolulu PD, 04 DRZ400S, 82 Turbo Seca (x2), -placed in a good home, 04, ~78 Yambulzukisaki hybrid, and oh so many others
hiflynbrd is offline   Reply With Quote
Old 10-27-2012, 05:03 PM   #9760
GTC
GTC's Avatar
Oddometer: 290
Looking for YZ250
Hello all,
I am looking for a YZ 250 two stroke. Looking to stay 2003 and newer (Might be willing to pay more for 05 and newer) Can be well used as long as it has been cared for regularly. Upgrades that would be great are: flywheel weight, 18in rear wheel, v force reeds. Does not have to have all these by any means but it would help. Don't really want to put a price range on because it changes for every machine and condition but defiantly want to stay under $3,000 if it needs work price needs to reflect it.
Let me know what you have,
George
1998 KLR650 (Road Warrior)
1997 XR 400 Sadly For Sale
2002 WR 426
GTC is offline   Reply With Quote
Old 10-27-2012, 05:04 PM   #9761
Megadeus
Motorcycles are therapy
Megadeus's Avatar
Oddometer: 221
Aluma trailer
I have the possibility of acquiring an enclosed trailer but the open trailer has to go first.
It's in locked storage ATM but it's in 8/10 condition with upgraded LED tail lamps and wiring.
Super useful. I welded in a 6' track of L-track on the centerline so I can strap down 2 bikes side by side. Includes 4 ramps that can load from the back or side. Super useful for ATV's and Motorcycles.
Model : A212 ATV trailer - 2002 year model.
• 1-3000# Rubber torsion axle - No brakes - Easy lube hubs
• Aluminum fenders
• Extruded aluminum floor
• 6" Front retaining bumper
• A-Framed aluminum tongue, 48" long with 2" coupler
• safety chains
• Swivel tongue jack, 800# capacity
• 2) Rear ramps (12" x 41"), 2) Front ramps (12" x 69"), optional ATV Ramp
• 8) Tie-down loops + center E-track - will include 4 tie down clips for track.
• Overall width = 85"
• Overall length = 195"
• Length between fenders = 62 1/2"
I've pulled 2 bikes easily with a Honda pilot. Easy to push around the yard empty.
Asking $1600 - Have Clear Colorado Title in hand.
Not MY trailer but the exact same model.
portion of track I have welded to trailer floor center line for 6'.
Located in Aurora, CO.
Text or call 70347376nine7 - Jason
Megadeus screwed with this post 10-28-2012 at 03:21 PM
Megadeus is offline   Reply With Quote
Old 10-27-2012, 09:20 PM   #9762
hyperboarder
Potato Farmer
hyperboarder's Avatar
Oddometer: 1,024
FYI, that's not E-Track, that's L-Track/Airline Track. Just bought some for the motovan, solid stuff and much less intrusive than the E-Track. If you decide to cut the price in half and can hold the trailer until spring, I'll happily take it off your hands. Something tells me that's not going to happen though . GLWS!
Current: 08 Yamaha WR250R, 05 Suzuki DL1000, 92 Ford E250 Motohauler
Gone but not forgotten: 2008 KLR650, 2000 GSXR1000, 1999 ZX6R, 2000 GSXF600, 2004 Ural Tourist, 99 Suzuki DR650
Quarter Life Crisis 2011 Ural National Rally
hyperboarder is offline   Reply With Quote
Old 10-28-2012, 07:15 AM   #9763
mpatch
Oddometer: 1,022
Danner logger, fire boots size 12 worn a few times $80 ftf $90 shipped located in Fort Collins
mpatch is offline   Reply With Quote
Old 10-28-2012, 07:40 AM   #9764
mpatch
Oddometer: 1,022
AGV Kevlar cargo pants 32x32 worn maybe 6 times $50 ftf $60 shipped
Located in Fort Collins
Used jetboil and pot support no pot included $30 ftf $35 shipped
Well used (probly shoulda washed the bugs off first those are mostly bugs not chips or scratches) Hjc is16 helmet with built in sunscreen XL $40? Won't ship
Icon magnetic tank bag FREE ftf won't shop
Joe Rocket jacket size L has pads and liner. $29.99 OBO won't ship
DID 520 roller chain 110 links brand new. $35 ftf also have a barely used renthal non O ring chain that ill throw in
Garmin 276C w/ TT locking mount for cheap PM for more info
Open to trades on everything listed. Whatcha got?
also if you have a WR250R and need any stock parts let me know I have a pile of them
mpatch screwed with this post 10-28-2012 at 08:20 AM
Old 10-28-2012, 02:53 PM   #9765
Desert Scoundrel
Oddometer: 131
I'd be interested in both of these. Any chance you get down towards Golden often? I'll take them both and I'll figure out how to get ahold of them.
Desert Scoundrel is offline   Reply With Quote
Times are GMT -7.   It's 08:55 PM.
