Old 10-29-2012, 08:13 PM   #6181
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,539
Originally Posted by crankshaft View Post
I drove to Boston this morning to help dyno my 690 and get the base maps built. The results so far are excellent! The throttle off idle is very, very crispy. I've never had it feel that good with TuneEcu or the Vortex, it was amazing.
It made 57HP at 6500 RPM but we encountered a strange problem where the Pulser coil voltage gets a little crazy and throws the timing signal off a bit.
We found the problem, so its getting more dyno time tomorrow to finish up the map.
The power and torque curve is really smooth and parallel, right to 6500. Once the pulser is adjusted, it will pull to redline cleanly and make even more power. My best guess is 60-61 HP at the rear wheel tomorrow. The exhaust is a Q4 with the insert and the simple UNI pod filter, I wonder what we'll make with an open exhaust The motor is bone stock, no cams or big bore kits.
Toying with having mine dyno tuned as well. I'm interested to hear all about it and how much and in what areas they made adjustments.
CanadianX is offline   Reply With Quote
Old 10-29-2012, 08:42 PM   #6182
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
57 hp ??? what is the HP of a stock one ?
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 10-29-2012, 08:58 PM   #6183
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Paul Jr 8
I found 64 HP on Bikez at 7500 rpm and as I recall, rated HP is at the crank. I'm showing 57 at the wheel and I've still got another 1000 rpm to go yet.
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-30-2012, 04:12 AM   #6184
LukasM
Oddometer: 5,415
Everybody rates their engines at the crank, so you are doing very well already. You got a street tire on there for the dyno runs, right?
Old 10-30-2012, 06:02 AM   #6185
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
yup, street tire on the back
Just say'IN
Old 10-30-2012, 08:53 AM   #6186
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Very very nice... I'm wondering what that thing will do with an Evo2 Cam. I saw a sheet from an SMC with 63 RWHP with an Evo2 Cam and DynoJet PCV (which sucks)... You're already there without the cam.
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 10-30-2012, 09:08 AM   #6187
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
What the cam does is take the power off the bottom end and put it on the top end. Good for some applications but not so good for lugging around in the dirt. Leave that cam for the sumo/track guys.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 10-30-2012, 10:28 AM   #6188
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Exactly, I'm looking for mid range and smooth power delivery. The goal has been met, the peak HP is just a bonus.
Just say'IN
Old 10-30-2012, 11:40 AM   #6189
Aaron from Texas
Oddometer: 489
Interesting... Didn't know that.
1987 Honda XL600R
Old 10-30-2012, 11:59 AM   #6190
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
My wild ass guess was correct, 61hp at the rear wheel at 7500 rpm
Linear curve, right to 7500! Now its time to ride it in anger for a bit and make sure everything is good!
Just say'IN
Old 10-30-2012, 12:08 PM   #6191
Aaron from Texas
Oddometer: 489
Post up some fuel tables from the 'squirt system, if you can... I'd be interested to look at that.
1987 Honda XL600R
Old 10-30-2012, 12:41 PM   #6192
cantweallridealong
cantweallridealong's Avatar
Oddometer: 23
Ktm 690 enduro help needed pls
Hi all
i am currently traveling south america on a KTM 690 Enduro and have a problem..
engine noise ticking very rapidly turned into a full melt down from the bike
i am some what mechanically inclined so i set to work.. to try to see what the hell had happened..
I was quite sure that this was a valve issue. took off the head to reveal a super f**ked Valve Rocker Bearing that has stripped its self and seized.. also damaging the Valve Cams too..
As i can tell there dos not appear to be any other damage done to any other parts..
my questions for anyone who can help is would this have done any other damage to the motor... i.e. the piston, cylinder etc... this is not an easy thing too tear down to check..
and other than ordering a new Rocker Arm and Valve Cam what else does anybody recomend i should replace with these..
many thanks
James
cantweallridealong is offline   Reply With Quote
Old 10-30-2012, 12:58 PM   #6193
Bigbugberg
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 324
Aw man, that aint pretty...
I would verify the oil pumps are in spec in terms of pressure and volume.
No use replacing parts if'n the oil ain't gettin there.
Never half-ass anything, always use your full ass
2010 KTM 690 Enduro
2009 KTM 400XCW Plated
Bigbugberg is offline   Reply With Quote
Old 10-30-2012, 02:31 PM   #6194
Mini Trail
nb
Oddometer: 2,247
When my rockers went bad I did some searching and discovered that it wasn't uncommon. I note that you have the newer style rockers not what came with my 2009. On mine one shaft came out and I was able to push the other one out with my finger plus the needle bearing came apart. Yours just looks ceased.
I would replace both rockers.
What is that red oil you are using?
Your cycle had a bell on it.
Mini Trail is offline   Reply With Quote
Old 10-30-2012, 03:15 PM   #6195
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,418
LOL, so the more I tear into my motor the more I find I need to do. So new piston to go along with the new rings, and of course the cylinder needs to be worked over. If the cylinder is worn past spec, then it's going to have to be sent off.
I did pick up a used cylinder and piston with rings with 4.5K miles on Ebay for $100. Figure I'll toss that on for now, and next time I need to do a top end just swap cylnders and pistons.
Times are GMT -7.   It's 02:13 PM.
