Old 10-31-2012, 11:34 PM   #11
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,236
Originally Posted by joatmoa View Post
Hi Zombie Stomp
Before you get all excited about your fabulous output from the alternator you need to consider the following...
The engine needs 35 watts to run or 3 Amps
The headlight, if it's an H4 bulb, is 55w or 4.6 Amps
The instrument lights (on when you have the lights on) are 3.4w each and there may be 4 of them = 13.6w or 1.13 Amps
The tail light is 5w or 0.42 Amps
the brake light is 21W or 1.75 Amps
The indicators (only on for a short while obviously) are 21w each with a 5w instrument panel light = 47w or 4 Amps
You've just fitted heated grips that are 36W or 3 Amps (less than a pair of moulded ones and nowhere near as warm - I've had both types)
So, if your engine is running and you have your lights on whilst braking and indicating you're using 176.6w or 14.72 Amps - your generator is roughly 187w if it's the same as mine, an 600E 2003.
If your heated grips are on then you will be running a deficit until you knock off your indicators and brake lights.
I'm fitting a front CREE LED lamp that draws 10w or 0.83 Amps so I don't have to run with my headlight on when traversing Europe, Asia, Alaska and Canada next year. Then I can run my 40w heated waistcoat as well as my 50w heated grips. I have already cut down my energy usage by fitting a 35w HiD headlight unit which is 3 times brighter than the H4 and uses 20w less on dip and 25w less on main beam.
I have not bought them yet. Where do you get these molded ones you speak of? I am picturing something that has the heat element closer to the surface of the grip and is integrated into it? As for the wattage, I'll replace tail lite and turn signals with LED to save as much power as possible. Also, where do you get the LED HID headlight? I bought the bike with a Lithium Ion battery, should I add the relay after the fuse? Thanks!
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Times are GMT -7.   It's 11:21 PM.
