Old 11-01-2012, 08:19 AM   #31336
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,755
Originally Posted by ba_ View Post
What options do I have for connecting a relay for use with a fuse block?
I tied into a rear light (blue wire IIRC) under the seat and tied directly into the battery which worked just fine. However, I just recently went with an Eastern Beaver fuse box set-up (#3CS) to make things a little cleaner down there and give me some extra ciruits for lights/heated grips. It came pretty much plug and play, took 10 days or so to recieve it...from Japan.
http://www.easternbeaver.com/Main/Wi...3_circuit.html
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 11-01-2012, 08:22 AM   #31337
ba_
ba_'s Avatar
Oddometer: 2,830
Originally Posted by Scott_PDX View Post
I tied into a rear light (blue wire IIRC) under the seat and tied directly into the battery which worked just fine. However, I just recently went with an Eastern Beaver fuse box set-up to make things a little cleaner down there and give me some extra ciruits for lights/heated grips. It came pretty much plug and play, took 10 days or so to recieve it...from Japan.
You still need to tie the Eastern Beaver fuse box to a wire like the rear light in order for the switched and un-switched circuits to work, correct?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
FS: DID Chain & front/rear JT sprockets WR250R
ba_ is offline   Reply With Quote
Old 11-01-2012, 08:40 AM   #31338
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,764
Been trying to find a video I saw a while ago, and wondered if someone can help me find it again.
It was a short clip of a WR250R that was accelerating through a parking lot, and it suddenly looses power (like the fuel pump quit, or like the ignition stopped firing) for just 2 or 3 seconds, then the problem went away. Just a momentary loss of power from fuel or ignition problems.
Anyone know which video I'm talking about?
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 11-01-2012, 10:09 AM   #31339
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 761
Originally Posted by bigdon View Post
Has anyone else tried to shoot a stream of gas with the fuel pump unhooked from bike?
Did it dribble out maybe a foot or so like mine did or did a shoot a high powered stream like I think it should?
I believe that the fuel pumps are more of a pressure pump than a flow pump due to the low flow requirements during operation. I would think that the fuel hose is a very large orifice (in comparison to fuel jets) which would not allow pressure to increase to a long shooting stream. A smaller opening would probably shoot farther.
On the other hand, I think that this might be a good way to kick start a stuck pump in the field if needed.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 11-01-2012, 10:45 AM   #31340
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,755
Yes. There is a lead ready for you to splice into the line. I think he provides one of those posi-vampire crimp things as well. But I try to solder all my connections.
Old 11-01-2012, 01:18 PM   #31341
NeilW
SomeAssemblyRequired
NeilW's Avatar
Oddometer: 97
heat
Well dang, hadn't thought of it that way. I guess the flip side is - when the fan is not running, the air flow through might be better. The holey shroud theory is probably right up there with those people who swap out a 190° thermostat for a 180° unit thinking it'll run cooler. The thermostat opens sooner but max cooling is not improved.
Oddly enough, the only time my temp light ever came on was when I was on the freeway - doing about 70mph, slightly down hill so not at full throttle. I think the stock fueling is lean at less than full throttle. On the other hand, I've pulled long inclines WFO and the temp stayed in the good range. I have one of those cheesy radiator cap thermometers to help me worry about engine temp.
Originally Posted by pfy50 View Post
Hey NeilW,
I am thinking that the Mod is feeling the extra heat because it is in fact damaging the efficiency of the fan to pull air away from the rear of the radiator. The purpose of the shroud is to direct the air& heat coming thru the radiator to the fan for removal effectively. If you put holes in the shroud it no longer is working as designed. To move more heat away from the engine you make the radiator larger, the fan larger or the same fan faster, or some combination of those three.
Just imho.
aka Boondocker
Uncommonly Sensible
1998 Suzuki DR650
2008 WR250R
2012 Yamaha Super Ténéré
NeilW screwed with this post 11-02-2012 at 12:43 PM Reason: added picture
NeilW is offline   Reply With Quote
Old 11-01-2012, 01:55 PM   #31342
Krabill
Krabill's Avatar
Oddometer: 4,896
Many people, myself included, remove the rear shroud all together. I occasionally ride slow, tight, technical single track in 100 deg weather and have never had an overheating issue.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 11-01-2012, 03:09 PM   #31343
KansasBob
KansasBob's Avatar
Oddometer: 515
Some have found the high speed over heating is cured by cleaning the air filter.
It seems to me the actual surface area of the air filter on these bikes is much smaller than than what I'm used to.
KansasBob is offline   Reply With Quote
Old 11-01-2012, 03:20 PM   #31344
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,501
You're one the money. Velocity is a function of orifice and volume. Increase the orifice and the velocity goes down. Not sure if this system uses a pressure regulator, I haven't studied this bike yet. But the pressure achieve in the manual can only be achieved with some back pressure either through an orifice blockage or narrowing or regulator.
On the bm Dakar the fuel pumps are prone to fail when the tank is allowed to run dry often. The fuel is used for cooling the pump. I guess the materials in the pump overheat and expand in different ratios which would/could result in loss of pressure inside pump. This will move the duty point in and area of the pump curve that will exacerbate the situation until failure. I guess letting it cool back down would correct this, but my guess would be that key materials will fatigue early in its design life cycle.
I'm no pump specialist, but dabbled with it a bit. Centrifugal pumps though.
tmotten is offline   Reply With Quote
Old 11-01-2012, 03:41 PM   #31345
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,684
I have to move so I can have a secure garage. My tools are in storage.
Once move, it will be soon, an R2 will be bought. If I take the 3 month ride a new pump installed and the old unit carried.
The KTM and Husky bikes of '08 had this same issue but fewer are sold than Yamaha and are ridden fewer miles.
Scroll down on page 11 and continue to what he found and how he removed too much material.... http://wr250rforum.forumotion.com/t1...ight=fuel+pump
OldPete is offline   Reply With Quote
Old 11-02-2012, 04:51 AM   #31346
fred flintstone
fred flintstone's Avatar
Oddometer: 539
That is a great thread, thank you.
fred flintstone is offline   Reply With Quote
Old 11-02-2012, 08:38 AM   #31347
ba_
ba_'s Avatar
Oddometer: 2,830
Longer pinch bolts for handguard triple clamp side mounts
ba_ screwed with this post 11-10-2012 at 07:40 PM
Old 11-02-2012, 09:08 AM   #31348
Longboardr
Longboardr's Avatar
Oddometer: 143
I'm trying to find a place online to purchase the longer pinch bolts needed when I mount the Cycra triple clamp side mounts for handguards.
*** Edit:
I found this:
http://www.probolt-usa.com/stainless...l#.UJPrLGl26To
Check McMaster Carr too
Longboardr is offline   Reply With Quote
Old 11-02-2012, 09:16 AM   #31349
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,275
*** Edit:
I found this:
I picked mine up at a ACE hardware store.....same exact bolt/head
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 11-02-2012, 09:17 AM   #31350
Ed@Ford
Oddometer: 1,682
*** Edit:
I found this:
Look for hardware stores that have the assortments in "little drawers"...about 50% of the time they will have the washer head style metric in grade 8,8 and 10.8.....usually an M8 will be 13mm hex in the usa...but sometimes you can find M12 hex. Stainless and stock bolts are unrated so they are weaker than an 8.8....I put on 10.9 when I can get them..often times the 8.8 grade have M10 hex....but these are REAL hard to find. Look for such stuff at Tractor supply, ACE, Valu hardware sections...FORGET finding them at Lowes or Home Depot....McMaster Carr is less than 50% having them.
Oh, yeah...in the little drawers of them, I've never found M8s longer than 60mm
Ed@Ford is offline   Reply With Quote
Times are GMT -7.   It's 01:15 AM.
