11-02-2012, 09:17 AM
#31351 | |
Oddometer: 1,051
Oh, yeah...in the little drawers of them, I've never found M8s longer than 60mm |
11-02-2012, 09:20 AM
#31352 | |
Oddometer: 1,532
I found 10.9 in 50mm and 60mm with a 13mm head at ACE. I will try those first.
Triumph, BMW, Yamaha |
11-02-2012, 09:31 AM
#31353 |
Oddometer: 1,051
#31354 | |
Harvey Mushman
Oddometer: 1,322
The local Ace Hardware has metric flange bolts but they are generic Chinese crap with poorly made threads and rough finishes--not something I trust to hold critical loads or look at and feel like ...Turns out Honda's parts numbering system for bolts is readily decoded, and they use the same parts numbers for both motorcycles and cars. An 8x55 flange bolt is 95701-0805508. High quality Japanese-made, beautifully formed and spec'd. to meet the strength needed here. Call your nearest Honda car parts department, ask for that number, if they don't have it in stock they'll get it usually the next day. I paid about $1.25 per bolt, well worth it. 95701 = flange head bolt 08xxxxx = 8 mm dia. xx055xx = 55 mm length xxxxx08 = thread pitch??? (less certain about this...)
"Coffee first..." Next Trip: didn't get enough...Death Valley "it's a dog's life.............and I love it" HardWorkingDog screwed with this post 11-02-2012 at 09:55 AM Reason: removed fightin' words :) |
11-02-2012, 09:42 AM
#31355 |
Oddometer: 1,051
That is a great bit of trivia to decode honda bolt part #
#31356 | |
Oddometer: 1,532
11-02-2012, 09:54 AM
#31357 |
Saratogian
Oddometer: 146
Lots of discussion regarding the pump being cooled by the fuel...
For those of you that have added a heat shield when installing your aftermarket tanks, what material have you used? Perhaps you have reused the shields that came on the OEM tank? I have some of that tape that is used on HVAC systems that might help...
There's a feeling I get when I look to the West... |
#31358 |
Oddometer: 95
11-02-2012, 10:42 AM
#31359 |
Brett
Oddometer: 4,720
Modern fuel pumps in cars and bikes have the fuel run through the electric motor part of the pump, and the pump itself. The fuel cools and lubes the parts.
It seems crazy to run gasoline through a DC electric motor, but for some reason, they do not explode. Everything I ever looked at had a fuel pressure regulator outside the pump, in some cars its on the fuel rail and excess fuel returns to the gas tank. The pump runs all the time the motor is turning, and runs for a bit with key on to build up pressure. The pump can supply more fuel and pressure then the motor can use at high rpm's, full throttle, cold engine. Once fuel pressure gets past the regulator set point, it pushes the regulator open and fuel returns to the gas tank. Some cars have/had a vacuum assist on the regulator, open the throttle, vacuum goes away, fuel pressure goes up a bit. Bikes have the pump and regulator in the gas tank as an assembly. Run low/out of gas and there is no fuel to lube and cool the pump and its motor, which has a large amount of plastic in it, and the hot spot is the brushes. They tend to melt their holders. |
11-02-2012, 12:42 PM
#31360 |
Oddometer: 697
It turns out the liquid gasoline isn't really as flamable as we commonly believe. It requires the right percentage of oxygen to burn. The 20.2% oxygen in our atmosphere will do it, so we commonly experience flamability. Toss a lit match in an open pool of gas, and it burns. Do the same with diesel fuel, and you get a wet match. This is why many marine engines are diesel engines. They don't catch fire as easily when bad things happen out on the water, far away from help.
However, there are lower and upper limits (LEL - lower explosive limit and UEL - upper explosive limit) of oxygen beyond which gasoline won't burn. Too much or too little, and no combustion. (Of course, too high a % oxygen will "burn" all by itself!) A fuel pump emersed in gasoline provides no oxygen, and so the environment is below the LEL. Hence the liquid gasoline can be pumped as an incompressible fluid, and at the same time can be used to transfer heat generated by friction away from the pump, without the danger of "catching fire" in the gas tank. Despite this, many race cars use external fuel pumps (outside of the gas tank) for ease of maintenance and replacement. They pump higher volumes at higher pressures and have a correspondingly higher failure rate. External pumps have been tried on motorcycles, but they are usually more hassel than they are worth, given limited space to place them where they can get enough airflow for adequate cooling. The internal configuration is just more compact and easier to keep cool - as long as you don't run it dry (very often?).
1990 Honda NT-650 Hawk-GT Never doubt that a small group of thoughtful, committed citizens can change the world; indeed, it's the only thing that ever has. - Margaret Mead
#31361 | |
SomeAssemblyRequired
Oddometer: 65
Stock tank insulation.
![]() ![]() Safari tank insulation. ![]() I don't think you could reuse the stock insulation. It probably wouldn't fit well even if you could get it off. I used the foil-backed plastic bubble wrap type and metal-backed tape to hold it on. It's still holding up pretty well after a couple of years of use. Quote:
aka Boondocker Uncommonly Sensible Goler Canyon ride '08 WR250R 2012 Yamaha Super Ténéré NeilW screwed with this post 11-04-2012 at 04:50 PM Reason: Pictures went missing. I put them back. |
11-02-2012, 02:29 PM
#31362 | |
Oddometer: 745
http://www.heatshieldproducts.com/pr...ield-mat/76/35 I've used it to insulate luggage from exhaust heat.
Dyslexics Untie! |
11-02-2012, 03:52 PM
#31363 |
Professional Trail Rider
Oddometer: 1,725
Discount Honda Parts
http://www.discounthondaparts.com BOLT, FLANGE (8X55) (95701-08055-08 ) Retail $1.22 Your price $0.99 Order at the bottom of the year-by-year list 'Reverse Part Number Lookup' They will have 10 or 12mm hex heads, never 13mm.
11-02-2012, 04:19 PM
#31364 |
Oddometer: 1,532
I ordered those from service Honda earlier. Should be perfect
11-02-2012, 05:15 PM
#31365 |
Any Aussies out there scanning this thread for info because they are looking at buying. I have just put mine up for sale. Check out all the info here:
http://www.advrider.com/forums/showp...&postcount=142 ![]()
