Old 11-04-2012, 08:10 AM   #6226
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 991
Sunday morning funnies - for your only.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 11-04-2012, 08:17 AM   #6227
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,347
When there is no way out - Find a way further in.
690 DL650 DR350 MMS Edition Past bikes
Buzztail is offline   Reply With Quote
Old 11-04-2012, 08:41 AM   #6228
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 5,061
Heh, Beemer on a tow truck, nothing new there.
Guess what doofus, nobody reads your lame blog.
Albie is offline   Reply With Quote
Old 11-04-2012, 10:38 AM   #6229
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 536
Originally Posted by Pantah View Post
Nice - I just ordered mine yesterday. Carbon/gripster/orange thread combo. Hope it's the same seat height as stock and the narrow section is far enough back to get my legs down.
Its higher.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 11-04-2012, 11:17 AM   #6230
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 427
Just connected TuneEcu to my 690R and noticed that it has loaded the 2009 stock map., however the bike has akrapovic exhaust, foam aifilter and powerparts airbox cover, does not stall, sputter, backfires, or anything.
Shouldn't it act all fussy with these mods and stock map?
It shakes a bit, nothing excessive, but its a single cylinder...
I'm almost inclined not to touch it rather than loading the akro map. If it gets better, it gets dangerous...
690R & 990Adv
Old 11-04-2012, 12:19 PM   #6231
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
$10 says its lean, especially higher in the revs.
Just say'IN
crankshaft is offline   Reply With Quote
Old 11-04-2012, 01:22 PM   #6232
Gustavo.Ramos
Oddometer: 427
I tend to agree... next weekend i'll give it a try with the akro map then... which one BTW? In the TuneEcu site there is an all years Akro map and a evo1 map..
690R & 990Adv
Old 11-04-2012, 03:21 PM   #6233
Dr LC8
...soon or later
Dr LC8's Avatar
Oddometer: 589
Guys,
Can I fit a 690 enduro 12 light and surrounding plastic to my 690 R 2010?
Nic
Explore Alps Off Road: www.over2000riders.com
Road 2012 Ducati Multistrada 1200
2008 KTM LC8 ADV
2010 KTM 690R
Trips:Europe,Africa,Asia
Dr LC8 is offline   Reply With Quote
Old 11-04-2012, 03:55 PM   #6234
Mini Trail
n°°b
Oddometer: 1,840
OK need some help again. Backstory, I had the fuel pump replaced in March, then it started smoking so I replaced the piston and rings. I rode it about 60 miles and shut it off and it wouldn't restart, then it bound up. I pulled the valve cover and the wheel pin worked its way out of the intake valve rocker and was interfering with the exhause rocker.
I got it back together today and it started quick enough but is running like crap and sometimes won't start at all. When it does start it runs rough backfires a little, won't idle for long and if I give it throttle it bogs like a carbureted bike when it is still cold.
The only thing I know to check is the cam timing for the 3rd time. The engine light is not on.
Your cycle had a bell on it.
Mini Trail screwed with this post 11-04-2012 at 04:01 PM
Mini Trail is offline   Reply With Quote
Old 11-04-2012, 05:42 PM   #6235
LukasM
Oddometer: 4,942
I'd try to get some wideband O2 readings so you actually know what the bike is doing under load at various RPMs.
Running rich can create just as much damage as running lean.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 11-04-2012, 05:58 PM   #6236
offworlder
Oddometer: 221
FMF pipe loose ?
I recently replaced the stock can on my 690 with the FMF Q4, and after examining the bike post ride, noticed the FMF was loose, even though the bolts are as tight as they can go. The FMF mounts via only one side of the exhaust mounting bracket. While the rubber grommets in the mounting bracket may introduce some play, they are likely present more so to decouple the pipe from the tank (shock absorption). If memory serves, the stock pipe was rock solid.
Anyone else experience this, and have a working fix ?
Thanks.
offworlder is offline   Reply With Quote
Old 11-04-2012, 06:04 PM   #6237
crankshaft OP
crankshaft's Avatar
Oddometer: 13,783
Thanks.
Tighten the clamp on the pipe, I have the same exhaust and its solid. Ridden all kinds of nasty with zero issues. You might be doing it wrong
Just say'IN
Old 11-04-2012, 06:18 PM   #6238
offworlder
Oddometer: 221
(as the upper mount is riveted/siliconed to the pipe, and hence cant be tightened) How tight should the lower pipe clamp be ? I cant see the lower clamp being primarily responsible for rigidity, as that would put alot of stress on the header...
Thanks.
Old 11-04-2012, 06:38 PM   #6239
crankshaft OP
crankshaft's Avatar
Oddometer: 13,783
Thanks.
A loose exhaust is probably worse than a tight clamp, think of the weight of the muffler moving around. Think of it like a slide hammer.
Tight man, can't explain it..
Just say'IN
Old 11-04-2012, 07:26 PM   #6240
offworlder
Oddometer: 221
Tighten I have, and she now feels much firmer. I'll slap myself for thinking the upper mount would/should bear the brunt of the weight....
Thanks Crank.
Times are GMT -7.   It's 01:02 AM.
