Old 11-04-2012, 09:17 AM   #6226
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 11-04-2012, 09:41 AM   #6227
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,427
Originally Posted by Sutherngintelmen View Post
Sunday morning funnies - for your only.
Heh, Beemer on a tow truck, nothing new there.
Albie is offline   Reply With Quote
Old 11-04-2012, 11:38 AM   #6228
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 959
Originally Posted by Pantah View Post
Nice - I just ordered mine yesterday. Carbon/gripster/orange thread combo. Hope it's the same seat height as stock and the narrow section is far enough back to get my legs down.
Its higher.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 11-04-2012, 12:17 PM   #6229
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 896
Just connected TuneEcu to my 690R and noticed that it has loaded the 2009 stock map., however the bike has akrapovic exhaust, foam aifilter and powerparts airbox cover, does not stall, sputter, backfires, or anything.
Shouldn't it act all fussy with these mods and stock map?
It shakes a bit, nothing excessive, but its a single cylinder...
I'm almost inclined not to touch it rather than loading the akro map. If it gets better, it gets dangerous...
690R
Old 11-04-2012, 01:19 PM   #6230
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
$10 says its lean, especially higher in the revs.
Just say'IN
crankshaft is offline   Reply With Quote
Old 11-04-2012, 02:22 PM   #6231
Gustavo.Ramos
Oddometer: 896
I tend to agree... next weekend i'll give it a try with the akro map then... which one BTW? In the TuneEcu site there is an all years Akro map and a evo1 map..
690R
Old 11-04-2012, 04:21 PM   #6232
Dr LC8
...soon or later
Dr LC8's Avatar
Oddometer: 940
Guys,
Can I fit a 690 enduro 12 light and surrounding plastic to my 690 R 2010?
Nic
Explore Alps Off Road: www.over2000riders.com
2012 Ducati Multistrada 1200
2008 KTM LC8 990 ADV S
2003 KTM LC8 950 ADV
Trips:Europe,Africa,Asia
Dr LC8 is online now   Reply With Quote
Old 11-04-2012, 04:55 PM   #6233
Mini Trail
n°°b
Oddometer: 2,250
OK need some help again. Backstory, I had the fuel pump replaced in March, then it started smoking so I replaced the piston and rings. I rode it about 60 miles and shut it off and it wouldn't restart, then it bound up. I pulled the valve cover and the wheel pin worked its way out of the intake valve rocker and was interfering with the exhause rocker.
I got it back together today and it started quick enough but is running like crap and sometimes won't start at all. When it does start it runs rough backfires a little, won't idle for long and if I give it throttle it bogs like a carbureted bike when it is still cold.
The only thing I know to check is the cam timing for the 3rd time. The engine light is not on.
Your cycle had a bell on it.
Mini Trail screwed with this post 11-04-2012 at 05:01 PM
Mini Trail is offline   Reply With Quote
Old 11-04-2012, 06:42 PM   #6234
LukasM
Oddometer: 5,415
I'd try to get some wideband O2 readings so you actually know what the bike is doing under load at various RPMs.
Running rich can create just as much damage as running lean.
Old 11-04-2012, 06:58 PM   #6235
offworlder
Oddometer: 256
FMF pipe loose ?
I recently replaced the stock can on my 690 with the FMF Q4, and after examining the bike post ride, noticed the FMF was loose, even though the bolts are as tight as they can go. The FMF mounts via only one side of the exhaust mounting bracket. While the rubber grommets in the mounting bracket may introduce some play, they are likely present more so to decouple the pipe from the tank (shock absorption). If memory serves, the stock pipe was rock solid.
Anyone else experience this, and have a working fix ?
Thanks.
offworlder is offline   Reply With Quote
Old 11-04-2012, 07:04 PM   #6236
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Thanks.
Tighten the clamp on the pipe, I have the same exhaust and its solid. Ridden all kinds of nasty with zero issues. You might be doing it wrong
Just say'IN
Old 11-04-2012, 07:18 PM   #6237
offworlder
Oddometer: 256
(as the upper mount is riveted/siliconed to the pipe, and hence cant be tightened) How tight should the lower pipe clamp be ? I cant see the lower clamp being primarily responsible for rigidity, as that would put alot of stress on the header...
Thanks.
Old 11-04-2012, 07:38 PM   #6238
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Thanks.
A loose exhaust is probably worse than a tight clamp, think of the weight of the muffler moving around. Think of it like a slide hammer.
Tight man, can't explain it..
Just say'IN
Old 11-04-2012, 08:26 PM   #6239
offworlder
Oddometer: 256
Tighten I have, and she now feels much firmer. I'll slap myself for thinking the upper mount would/should bear the brunt of the weight....
Thanks Crank.
Old 11-05-2012, 04:45 AM   #6240
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
Start off checking the injector. Sounds like it could be fuel related. is the pump cycling when powered up? I know you replaced the pump already, but I'd start with fuel, and spark.
My bad
Times are GMT -7.   It's 09:48 AM.
